Rigify UI throws an error ('thigh_fk' cannot be found) #89910
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#89910
Graphics card: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
blender/blender@1b8d33b18c
Worked: 2.92
Behavior changed in blender/blender@afa5da9ce0
fm 001.blend
N
panelAdded subscriber: @Rolinga
Can please add a simple test file with steps to reproduce ? Issue is possibly related to rigify addon so changing the tag
Hi there, this is the same file that I've using when the problems appears.
fm 001.blend
Thanks and sorry my english, I'm from Chile... but I try hard to make me understand!
Insert keyframe for all bones selected doesn't work with the "n" panel shown... I hace to close it to go on.to Insert keyframe for all bones selected doesn't work with the "n" panel shown... I have to close it to go on.Added subscriber: @lichtwerk
Think the keyframes are actually inserted correctly.
Rigify has a problem though [which was still possible in 2.92, only 2.93 onwards has this problem]:
Added subscribers: @Mets, @angavrilov
@Mets , @angavrilov : does this ring a bell?
Insert keyframe for all bones selected doesn't work with the "n" panel shown... I have to close it to go on.to Rigify UI throws an error ('thigh_fk' cannot be found)Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
In the attached file, the properties in rig_ui.py are defined using the old
assignment, but looking at the git blame of the code that generates that code, it has been kept up to date immediately with Blender 2.8, and changed to the new:
annotation syntax.So this means your rig was generated with a version of Rigify and Blender that are more than 3 years old, and that's why it's no longer compatible with current Blender.
The ideal solution here is to find the metarig that generated this rig, and re-generate it with the current Rigify. If that's not available because the rig's author has made the huge mistake of discarding the metarig (which should never ever be done) then your best bet is to simply go into rig_ui.py and replace the
signs in the operator class definitions with:
signs, as per Blender 2.80 Python API requirements.Thanks for the report, but there's no bug here, so closing. Hope the above info will help with the problem though.
thx looking at this @Mets !
Thanks a lots, and sorry for reporting a non bug issue!
Cheers... and also thanks for all your work!!
