Geometry node rendering issue (fixed in 3.0 - unclear if backport to LTS should be done) #89926
Reference: blender/blender#89926
Graphics card: NVIDIA GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.77
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
1b8d33b18c
Works in 3.0 (where it was "fixed by
5cf6f570c6
), question is if this should be backported to 2.93?Short description of error
when rendering a scene with geometry nodes, the render preview and final render both fail to render the result of the geometry node modifier
in the attached blend file, rendering in object mode creates a flat plane surface under the chest object, with a shadow under the chest. this is not the expected result. however, selecting the plane and tabbing to edit mode, then rendering, does create the expected result, of the plane being modified around the base of the chest object. this discrepancy can clearly be seen in wireframe, solid, and material preview render modes of the 3D viewport. the only way to make the deformation render in object mode is to apply the modifier stack, which is not ideal.
Test File:
Chest.blend
Added subscriber: @Ragnarok_UKL
Added subscriber: @lichtwerk
Can confirm in 2.93.
There is the Cycles issue, but also normals in the viewport seem not to be from evaluated mesh.
@Ragnarok_UKL : please check a fresh 3.0 build from https://builder.blender.org/download/daily/ (it is fixed there for me).
Will check which commit needs to be backported...
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscribers: @JacquesLucke, @Jeroen-Bakker
I am not sure why
5cf6f570c6
fixed this (but apparently it did).So question remains: is Geometry Nodes stuff like this a candidate for LTS?
Assume it is not, but will @JacquesLucke or @Jeroen-Bakker decide.
Geometry node rendering issueto Geometry node rendering issue (fixed in 3.0 - unclear if backport to LTS should be done)This specific commit should not be backported, because it was quite a big refactor that we intentionally did not in 2.93. I can look into an alternative fix though.
Seems to be fixed by P2309. Looks like
CustomData_duplicate_referenced_layer_named
was called on layers that it should not have been called on. Didn't go into more detail as to why duplicating a referenced layer is a problem yet.Might be a bit too risky to backport to 2.93, because (1) it's not entirely clear what the issue was and (2) we can't test the fix in 3.0 to make sure that it doesn't break other stuff.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
