Thread race condition with lock interface enabled #90043
Reference: blender/blender#90043
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.2 Release Candidate, branch: master, commit date: 2021-07-07 05:52, hash:
9e64fd461a
UI redraw is still taking place in the render_init and render_complete handlers when use_lock_interface = True. This lock was only implemented for 3D viewport, but this is not mentioned in any of manuals.
Adding lock to node editor seems to resolve the issue:
Trace:
Open below file, run the script and then press f12.
ui lock ignored on some handlers which are not on the main thread.blend
Added subscriber: @3di
#90079 was marked as duplicate of this issue
Added subscriber: @iss
Seems to work fine in 3.0. Not sure if this would be possible to fix in 2.93 would have to check which commit fixed this
Morning @iss I've just tested with today's 3.0 build, and it's still crashing Blender with ACCESS VIOLATION. Render a few times and it should crash (it just depends on what the main thread is doing with memory at the time I believe). One thing I've just noticed is that it only crashes if you have the compositor visible, even if lock interface is set to true.
My guess is that lock interface is ignored during the render_init and render_complete handlers, which causes the crash as they're still not on the main thread. This would explain why it always happens during UI drawing:
ExceptionCode : EXCEPTION_ACCESS_VIOLATION
Exception Address : 0x00007FF742D015C3
Exception Module : blender.exe
Exception Flags : 0x00000000
Exception Parameters : 0x2
Parameters- [x] : 0x0000000000000000
Parameters- [x] : 0x0000000000000010
Stack trace:
blender.exe :0x00007FF742D01560 UI_block_end_ex
blender.exe :0x00007FF742E038A0 node_draw_basis
blender.exe :0x00007FF742E06630 node_draw_default
blender.exe :0x00007FF742E03450 draw_nodetree
blender.exe :0x00007FF742E06D70 node_draw_space
blender.exe :0x00007FF7429F5B20 ED_region_do_draw
blender.exe :0x00007FF742513680 wm_draw_window_offscreen
blender.exe :0x00007FF7425134D0 wm_draw_window
blender.exe :0x00007FF742512FD0 wm_draw_update
blender.exe :0x00007FF7424EEC00 WM_main
blender.exe :0x00007FF742182EA0 main
blender.exe :0x00007FF747025F08 __scrt_common_main_seh
KERNEL32.DLL :0x00007FFBC0537020 BaseThreadInitThunk
ntdll.dll :0x00007FFBC2502630 RtlUserThreadStart
So perhaps an easier solution would be to have render_complete respect the lock interface setting? Although that would still leave render_init open to problems if it's also not on the main python thread?
Access Violation due to some handlers not running on the main thread (Speak to Pedro, he mentioned he'd moved all python code to run on the main thread, maybe some slipped through the net?)to Access Violation due to some handlers not running on the main thread and still updating the UI even when lock UI is set to true.Here's a simple example file showing how to force all render handlers onto the main thread:
force render handlers onto main thread.blend
INSTRUCTIONS:
Access Violation due to some handlers not running on the main thread and still updating the UI even when lock UI is set to true.to Thread race condition with lock interface enabledChanged status from 'Needs Triage' to: 'Confirmed'
@3di can reproduce in 3.0 too, I think I was lucky on first try. Issue here seems to be, that
use_lock_interface
property is used only by 3D viewport. I don't know why more editors don't use this property though.I think It's best to add this to description too.
@iss You're a legend! Could you tell me when you're fix will be applied to master, and which versions it'll apply to please? Does it stop the image editor opening during render, and can the user still press escape to cancel a render?
I did find a workaround of:
overwrite default keymap on addon initialisation so that render.render would be called from an operator in my addon (so that I could handle render_init code before the render.render call, instread of using the render_init handler), and then using a queue to do move the render_complete code to a function run by the main thread once the rendering thread had closed down.
Do you know if it's possible to cancel a render from the render_init handler by the way?
I will leave this decision on nodes & physics module owners, because I don't know why this is implemented this way, nor can I say that this would be a good change. Even though it looks safe...
ah ok, got you. Thanks 👍
