Ambient occlusion node doesn't apply to beveled edges #90134
2 Participants
Reference: blender/blender#90134
Operating system: windows 10
Graphics card: rtx 3060
Broken: at least since 2.8
Worked: never?
Ambient occlusion node doesn't apply to beveled edges. As you can see on the picture below, the bevel is just white and the surrounding dark. I've tested mainly in cycles.
edit: I've tested a bit with the math node and i got a good result yet now i can't get rid of those thin lines around the bevel on the out edges
edit:
I've tried a test blend file Philipp Oeser provied in an arhcived thread and it clearly shows the problem. The beveled areas should be dark too but instead they are bright. This makes it close to impossible to use the ao node for a crease or edge mask (for edge wear or dirty creases).
Low poly (no beveled edges) models work ok but even a small bevel breaks the mask.
This can't be a wanted behavior. Or does it?
I know there is still the pointiness option in the geometry node but that usually doesn't work that great too. Like those faces on the bottom cylinder are bright and the side facing faces of the other cylinders are black. Weird.
Use the bevel modifier (or create a bevel on an object/mesh via edit mode) and use the ambient occlusion node + color ramp to create a mask for inner edges. The AO node doesn't work on the bevel.
Added subscriber: @Harti
Closed as duplicate of #88292
Added subscriber: @lichtwerk
The other task is reopened, no need to have this duplicate around.
