Landscape add-ons not working properly. #90171
Closed
opened 2021-07-26 16:50:59 +02:00 by juned · 8 comments
System Information processor-Ryzen 7 3700x, 8gb ram
Operating system: Windows 10 home
Graphics card: NVIDIA RTX2060
Blender Version2.78
Broken:
(example: 2.79b release)
Short description of error when I click on landscape add-ons it create a default mountain landscape but not showing editor menu how can i fix this...
**System Information** processor-Ryzen 7 3700x, 8gb ram Operating system: Windows 10 home Graphics card: NVIDIA RTX2060 **Blender Version**2.78 Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** when I click on landscape add-ons it create a default mountain landscape but not showing editor menu how can i fix this... **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @juned9751
Added subscriber: @mano-wii
Germano Cavalcante self-assigned this 2021-07-26 17:28:28 +02:00
Before we can determine if this is a bug, did you check the addon documentation?
https://docs.blender.org/manual/en/dev/addons/add_mesh/ant_landscape.html
Before we can determine if this is a bug, did you check the addon documentation? https://docs.blender.org/manual/en/dev/addons/add_mesh/ant_landscape.html
Changed status from 'Resolved' to: 'Needs User Info'
Member
Member
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Reference: blender/blender-addons#90171
