VSE stops after moving one frame #90271
8 Participants
Reference: blender/blender#90271
OS: Debian10
CPU: AMD64
GPU: GeForce GTX 1060 6GB
Blender Version w/issue: 2.93.0-1, 3.0 alpha
Short description of error:
VSE plays video one frame forward and then stops (in Blender 2.93-3.0)
After adding video to sequencer, whenever I hit "play animation" button FORWARD the video moves one frame forward and freezes.
Oddly, there is no problem when hitting the "play animation" button REVERSE (see short clip attached for visual description), and I had no issues of any kind in versions 2.92/.91/.90/.80, etc.
vse-playback-issue.mp4
Not sure if this is a bug or an oversight on my part, but curious how to fix.
Thank you,
Added subscriber: @kevinkelly
#90526 was marked as duplicate of this issue
Added subscriber: @iss
Do you use Pulseaudio as output sound device? Check in User preferences > System > Sound.
This may be same issue as #89045 - there is experimental build with possilbe fix, not sure if this is merged in master yet, but in other report we need feedback:
Test this build with Audio Device set to "Pulseaudio" https://builder.blender.org/download/experimental/blender-3.0.0-alpha+master.a112adf16a06-linux.x86_64-release.tar.xz
Yes to PulseAudio as output sound
Yes looks to be identical issue to #89045
Will download experimental build referenced with feedback.
Thank you,
Same issue persists with experimental build but the issue goes away temporarily after saving the file and opening it up again similar to Christoffer's comment in #89045
Playing a saved version of the file will play a few hundred frames with no issue, and then the program freezes and crashes.
If there's any log I can add to be more helpful, please let me know.
Thank you,
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @ChristofferHolmstedt
Added subscriber: @slinkeepie
Hi all, can confirm this with v3 alpha
ede1ce6e9a
.Not sure if it helps, but switching sound from Pulseaudio to Open AL fixed it for me...
David
Changed status from 'Needs Developer To Reproduce' to: 'Needs Triage'
Added subscriber: @neXyon
Thanks for testing.
@neXyon the experimental build is from #89045, does this info help?
I would merge these reports, but I was unsure if they are same issue.
Added subscriber: @RedRock
Hi there!
Same here as described in the first post.
Environment Intel Core i3-3120M, Intel 3rd Gen Core processor Graphics, MX-19.4_x64 patito feo October 21 2019 (MX Linux) based on.... Debian GNU/Linux 10 (buster).
Tested with Blender 2.93.0 and 2.93.1.
Exact same issue (reverse works), exact same fix (Open AL).
Didn't test the beta, it won't start...
Cheers.
Added subscriber: @drip
Added subscriber: @lichtwerk
This and #89045 really seem the same, will merge since we now have a couple of these reports flying around, better to handle this in one place.
Closed as duplicate of #89045
Added subscriber: @Rickyx
This comment was removed by @Rickyx
