Stacking point distribute : repetitive distribution #90359
Reference: blender/blender#90359
Operating system: Windows 10
Graphics card: NVIDIA GTX 1080
Broken: 2.93.1
Worked: /
When stacking point distribute nodes I noticed that the scattering done by the second node is repeated on the instances.
Using Geometry nodes I setup the following model :
(point distribute > point instance > point distribute > point instance)
From this node setup one would expect it to behave as if the output of the 1st distribute+instance was the input mesh and thus have a different distribution for on each scattered object.
Here, for every object placed by the first distribute+instance, the distribution of objects (second distribute+instance) is similar.
as follows :
If this is normal behavior, how can it be circumvented to get the expected behavior ?
distribute_stacking.blend
Thank you for your amazing work
Added subscriber: @ogjee
Removed subscriber: @ogjee
Added subscribers: @ogjee, @MiroHorvath
@ogjee As far as I remember this is a known issue. The setup you used suffers from the fact that you're scattering directly on instances(second Point Distribute node)...
...and that causes randomization to be the same for each instance.
A temporary workaround is to "realize"(convert) instances to a mesh eg. by creating a new attribute, after this node instances become a mesh again and scattering then happens on a mesh(all cubes scattered with first Point Distribute node)
This unfortunately has the down side that you lose possibility to control density on each previous instance as scattering is happening on the mesh as a whole.
You'll understand better if you play with it yourself, here's the example.
Added subscriber: @iss
Thanks @MiroHorvath for providing explanation and workaround.
I will add, that for support or workflow issues please use one of the community websites: https://www.blender.org/community/
Closing, as this is works as intended.
