Knife Project Not Working #90656
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
10 Participants
Reference: blender/blender-manual#90656
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 3.0.0 Alpha, branch: cycles-x, commit date: 2021-08-12 11:03, hash:
blender/blender@425388bc0f
Added subscriber: @Shady.Hamza
blender/blender#92842 was marked as duplicate of this issue
blender/blender#91512 was marked as duplicate of this issue
blender/blender#91130 was marked as duplicate of this issue
blender/blender#90716 was marked as duplicate of this issue
Thanks for the report. This happens after the commit blender/blender@49ea8e4fea made in master.
From Modeling module discussion I noted the steps to use knife project:
Mesh -> Knife Project
May be this report can be closed but will keep open for developers opinion.
I see, that worked thanks, so the old way where I select the cut Obj shift Select the Obj i wanna cut then enter edit mode, that doesn't work anymore huh
Added subscriber: @SteffenD
I can confirm that it works as described in the official workflow in 2.93 but doesn't work any more in 3.0 master
Added subscribers: @Vyach, @deadpin
This comment was removed by @Vyach
@Vyach , I agree that
Sync selection
has to be enabled.Update in manual is expected to describe the new steps so adding #documentation tag.
Added subscriber: @mano-wii
This way it was working was not intentional.
It's even confusing to know which mesh will be cut when more than one mesh can be in edit mode at the same time.
In 2.79 this worked because only the active mesh was in edit mode.
Now you need to select the objects that are not in edit mode. For that you can use Ctrl + Select for example.
The manual, in fact, needs to be updated:
https://docs.blender.org/manual/en/3.0/modeling/meshes/editing/mesh/knife_project.html
Added subscriber: @lichtwerk
Well, as a bug report, this can be closed (functionality works as intended and D12264: Knife Project:: update documentation is accepted).
Just noting that this works in the viewport (dont have to do this in the Outliner).
This issue was referenced by 8325
Added subscriber: @FloridaJo
Removed subscriber: @Vyach
Added subscriber: @NXSK
Added subscriber: @robcarrich
Added subscriber: @1D_Inc
This is happening because multiedit was implemented from homogeneous system without active object paradigm (like 3dsmax, Maya or AutoCAD) into hierarchical system with active object paradigm (to Blender)
As a result, the design faced systemic incompatibility, but instead localizing multiedit, which corrupts different functions and also messes up with instances, it was decided to redesign knife project in 3dsmax way.
The resulting design is quite unsuccessful.
To solve knife project issue it is needed to do the opposite - return knife project behaviour but limit multiedit to special submode, so
Such design will give a space and reconcile both homegemeous system like mutiedit and hierarchical system like knife project, so such behaviour will allow to bypass systemic incompatibility.
It will be more wise solution since multiedit is not supposed to be used very often anyway, the most time you edit just a single object at once, and sometimes, quite rarely, tweak several objects when it is needed - and only if selection doesnot contain instances (linked data objects), otherwise they will be immediately corrupted during multiedit session, which makes multiedit a double limited solution in general.
