Curve: Apply Scale Problems with Dimensions & Shape #90736
Reference: blender/blender#90736
Operating system: Windows
system-info.txt
Broken: Blender 2.93.2,
1eb06de2607a
This mostly pertains to the scale and dimension inputs of the right-hand-side "item" overlay window.
The reference cube demonstrates the proper behavior. Attached is a sample .blend and my system information.
BezierCurve.ShapeChanges.ApplyScale
objecttaper.blend
Added subscriber: @orbisvicis
Added subscriber: @mano-wii
Thanks for the report, but I'm not sure exactly what the steps are to replicate the problem.
In the attached file, should I select the mentioned objects and apply the scale? In this case the information does not match what is observed. As it is said that:
but the dimensions are actually
2.0, 0.222, 0.0
in the .blend file.After selecting it, hit undo then select it again.
I found a problem.
That's not exactly what I did to reproduce it.
Updated the description.
@mano-wii The problem you found was the third item in my report. Please let me know if you were able to reproduce the first two. For example, open the file, select BezierCurve.Size.Wrong.002, undo the selection, select it again. Let me know the dimensions reported in the right-hand-side "item" overlay window.
Ah yes! I can see a problem with the object's bound box.
I will do a separate report as this is an unrelated issue.
This issue was referenced by
4f73d43adc
