VSE: Memory leak importing bunch of medias #91110
Reference: blender/blender#91110
Operating system: Windows 10
Graphics card: GTX 1070Ti
Broken: 2.93.4
b7205031ce
candidateShort description of error
RAM increases a continuously while importing new movies when new sounds have no impact.
Video Editing
app template and open a script windowNB
Maybe the following observations are related:
Images
I've done some benchs:
Start, save, open recent
Start, delete created seq
Start, save, close blender, open saved .blend
Added subscriber: @Miadim
Added subscribers: @iss, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Isnt this just the memory used to build the Proxies? https://docs.blender.org/manual/en/dev/video_editing/sequencer/sidebar/proxy.html
Once they are done, memory gets slowly freed again.
Opening that file again does not have to build the proxies again, so no memory increase here.
Calling this a
memory leak
is misleading I think since would only be the case if memory is not freed if blender closes etc.Blender would also usually report a real leak if started from the commandline in the console.
@iss: this is expected behavior, no?
Yes I hesitated to call it
Memory not freed
. Maybe it's not a memory leak, but why the memory isn't freed right after the proxies are built? It shouldn't be a flat part remaining until I close, delete or open another .blend. It must freed instantly when the python process is done, no?Also, I've tried the same steps I listed with Proxy Setup to
Manual
and I get the exact same result.Changed status from 'Needs Developer To Reproduce' to: 'Archived'
This is not caused by proxy building, even though proxy building would double memory usage. Issue is, that each movie file handle will allocate some memory within ffmpeg. In my case it is about 200MB. This depends on codec settings, but mainly on movie resolution.
I thought this could be bug, because added files don't have to be kept open, which is technically true, but in practice it doesn't make much sense to add movie, open it(for internal purposes), close it and then open it again, because user will try to render it. Also if you would try to render each movie file this memory would be allocated over time anyway. Trouble is that Blender doesn't have idea about this allocated memory, because it is done by external library, so number of open files can't be managed during runtime. Perhaps if amount of open files is limited, but since amount of memory needed is quite variable, this wouldn't work in practice.
So unfortunately this is not even design limitation, but completely outside of our ability to resolve this issue, so I will close this report.
However, as we talked on blender.chat, importer scripts could have ability to skip file opening, which would resolve this issue partially, editing of large amount of movie files is still possible to limited extent (movies can be unloaded manually by pressing Ctrl+R) and rendering does "close" or free all movies file for every frame, so memory usage is kept low. Minor problem here is, that we have argument
fit_method
that would be disfunctional with fast loading mode (this also can be resolved though).
