Mirror Modifier On Cage Selection Papercut #91124
2 Participants
Reference: blender/blender#91124
Broken: 2.93.4
Worked: Maybe never.
When in edit mode, using the "On Cage" option for the mirror modifier results in some unintuitive behavior when selecting vertices created by the bisect feature. The vertices created by the by the bisection are mapped to the original mesh data in a way that appears to be based on blenders internal representation of the mesh and not based on something observable to the user.
The behavior when selecting should feel consistent to the user. To fix this, I suggest that the vertices created by the bisection should always map to the vertices on the original mesh that are on the removed side of the bisection plane. This way users would be able to tweak the centerline of the mirrored mesh in while using "On Cage." As it is currently implemented, there are vertices that affect the mesh that cannot be accessed through normal click selection unless "On Cage" is off.
Example
Select the +X or -X face of the default cube and scale it by 0.5.
Add the mirror modifier and select bisect for the X axis so that the object is mirrored and bisected about the X axis.
Turn on "On cage" for the mirror modifier then enter edit mode for the object.
When selecting the vertices on plane X=0, you should notice that two of the vertices correspond to visible mirrored vertices and two correspond to vertices removed by the modifier.
Simple scene showing the behavior.
MirrorSelectOnCagePapercut.blend
Added subscriber: @Ethan-Hall
Added subscriber: @lichtwerk
Can confirm.
