Hair particle distribution can be extremely slow #91568
Reference: blender/blender#91568
Graphics card: Quadro RTX 3000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.96
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash:
b7205031ce
Worked: ?
Depending on the mesh topology, the particule distribution can be extremely slow (render time varying from 9 seconds to 94 seconds for the same number of particles).
From my understanding while debugging the source code, most of the time is spent in particle distribution :
BLI_qsort_r
function called bypsys_thread_context_init_distribute
function.This is done in the section which states :
It seems that here,
BLI_qsort_r
hits the worst case O(n²) complexity case, which can happen depending on the input value distribution (see https:*research.swtch.com/qsort or http:*calmerthanyouare.org/2014/06/11/algorithmic-complexity-attacks-and-libc-qsort.html for more information)Exact steps for others to reproduce the error
Added subscriber: @rotoglup
Particle distribution can be extremely slowto Hair particle distribution can be extremely slowAdded subscribers: @Sergey, @iss
I can confirm this, though not sure how to classify, since I don't know the system well enough, hair system is marked as EOL and performance improvements are not considered bug. Disabling sorting does seem to have effect on final image so not sure what would be the solution to this problem even.
@Sergey I saw you involved in this area, do you think we should investigate possible improvements here?
If this is indeed an issue with worst-case complexity hit in the
BLI_qsort_r
this wouldn't be a hair system problem. Possible that the implementation of qsort we got from FreeBSD is susceptible to the problem.@rotoglup, while you're at it, did you try replacing
BLI_qsort_r
call with different qsort implementation?I'm far from being an expert in quicksort issues, or sorting algorithms, but my understanding is that it is the pivot selection strategy that can lead to worst-case scenarios.
I tried to change that strategy in the existing code (see attached diff) by changing the
med3
function, so that it modifies/sorts the values in place, before returning the median value.This removed the issue in my test scene, all tests seemed to pass - but - I'm not able to tell how it really impacts the worst-case scenarios.
I was inspired by this stackoveflow answer which says :
I also though that
timsort
could be a good alternative to quicksort, being stable and worst-case O(n log n) time complexity, or maybe particles, coming in very large numbers, could benefit from some custom sorting (radix sort maybe?)sort_pivot_swap_in_place.diff
Added subscriber: @mano-wii
Revisiting some older reports, I found this one.
Generally, performance issues are not treated as bugs (especially involving particles that are in the "End of Life" state).
But a drop from 9 to 94 seconds in a situation where you would expect a faster render (since the subdivision modifier has been removed), seems to be something to keep track.
So I'm confirming it as a Bug for now.
I did a rudimentary test non threadsafe with
qsort
. The result was even worse:
