Inconsistent name separator used for duplicate node sockets names. #91826
7 Participants
Reference: blender/blender#91826
Operating system: Linux-5.4.0-84-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA RTX A6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.42.01
Broken: version: 3.0.0 Alpha, branch: master, hash:
1d47885
Introduced by
756c22b
, it's not properly connecting the second image socket in mix RGB nodes on load.I suspect it's because the duplicate socket naming convention changed between .001 and _001 at some point.
Added subscriber: @brecht
#92636 was marked as duplicate of this issue
Added subscriber: @Blendify
If no quick solution can be found for this, I suggest to revert the changes for such nodes with multiple sockets that have the same name, since this leads to data loss when resaving .blend files that you may not notice until later.
I can reproduce but not with a file saved in recent versions of Blender, I wonder if the same can happen with some shader nodes that were also converted?
The problem might stem from https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/node.cc$1515
The proposed solution would be to make this an underscore, there also seems to need some versioning code to check existing nodes for the
seperator.Added subscribers: @JacquesLucke, @HooglyBoogly
Cycles handles both
_001
and.001
, Eevee does not use these identifiers so works regardless. So shader nodes are not an issue for Blender's own renderers, but for external engines this is still messy.I'm confused about what the current convention is. And it's not clear to me if geometry nodes have a similar issues or if they avoid it, and if so why?
Looks like for some reason different conventions are used throughout
node.cc
.BLI_uniquename_cb
is used three times, sometimes with.
and sometimes with_
.Some versioning code just use one convention would be great. We really don't want that the same socket has different identifiers in different cases. That's also why I'm moving towards explicit socket identifiers with the socket declarations instead of some automatically generated identifiers.
I think we should revert the breaking commit for now, then add versioning to make sure that built-in nodes are consistent (i.e. the same socket does not have different identifiers in different nodes). Then we can commit the socket declarations again. I don't really care if the convention is to use
_
or.
or both, it should just should be consistent for different nodes of the same type.Added subscriber: @Raimund58
The affecting nodes have been reverted in
0bc4056455
I'm leaving this task open until we figure out how to deal with the root cause.Compositor Mix RGB node has broken links opening old .blend filesto Inconsistent name separator used for duplicate node sockets names.Added subscribers: @Ed-H, @PratikPB2123
This issue was referenced by
d845ba481c
