Crash when toggling edit mode on object with geometry node modifier, but only if the instanced objects material has a normal map assigned. #91838
6 Participants
Reference: blender/blender#91838
Operating system: Win 10
Graphics card: GTX 1080ti
Broken: 2.93.4/ 2.93.5 / 3.0 alpha
Worked: -
I created a "radial array" geometry node group and have given object "B" this modifier.
Object "A" is being instanced via this node group into a radial array.
When toggling the edit mode on the "B" object, Blender crashes.
Blender does not crash, if i disconnect the normal map socket from the material used on object "A".
crash_packed.blend
Open the blend file and press "tab". (object "B" is preselected).
Blender should crash now.
To not have it crash, disconnect the normal socked in the material.
(I added annotations in the shader editor to highlight the connection.)
I hope thats all, thank you for being awesome :)
Added subscriber: @LinoThomas
Added subscriber: @iss
Can confirm crash on NULL dereference
P2460: (An Untitled Masterwork)
There is a null reference in
GPU_vertformat_safe_attr_name
because theCD_TANGENT
layer does not exist. I'm not sure how related this is to geometry nodes honestly.Added subscriber: @JacquesLucke
Also can't see how geometry nodes could cause this right now, but I also didn't manage to reproduce it without geometry nodes yet.
I was able to reproduce it in a new scene:
With the file just try to enter edit mode on the selected object.
tangent_bug.blend
[EDIT: the bug I found below has been fixed separately]
I also ran into another issue in this setup, but it seems unrelated: P2566. This happens when I leave As Instance off, and when I exit edit mode on the other cube..
Looks like
me->edit_mesh->mesh_eval_cage == me->edit_mesh->mesh_eval_cage->edit_mesh->mesh_eval_cage
for some reason. This leads to infinite recursion.Added subscriber: @fclem
After digging the issue, I came to a point where it seems that
const CustomData *cd_ldata = mesh_cd_ldata_get_from_mesh(me_final);
inmesh_cd_calc_used_gpu_layers
does not contains the same layers as
CustomData *cd_ldata = (mr->extract_type == MR_EXTRACT_BMESH) ? &mr->bm->ldata : &mr->me->ldata;
inextract_tan_ex_init
which makes tangent layer generation to fail.
In
BKE_mesh_calc_loop_tangent_step_0
,DM_TANGENT_MASK_ORCO
is only added to the tangent mask if there is no uv layer.mesh_cd_calc_used_gpu_layers
does not see any UVs, thus query only orco tangent layer. ButBKE_mesh_calc_loop_tangent_step_0
will not create the tangent layer since there is a valid UV layer to query a tangent layer from, but it does not match any requested tangent layer name (because only orco was needed).I tried (P2572) to make tangent orco generation work even in the presence of valid UV layer but couldn't make it work (
CustomData_get_named_layer_index(loopdata_out, CD_TANGENT, "")
still returns -1 even afterCustomData_add_layer_named(loopdata_out, CD_TANGENT, CD_CALLOC, NULL, (int)loopdata_out_len, "");
). It not help because the rest of the generation code also assumes the same thing asBKE_mesh_calc_loop_tangent_step_0
(that orco is only here as fallback).To me all of this is quite fragile since this means everything needs to have the same behavior and be in sync for things to never fail.
The real fix is likely to fix the premise of the issue, which is that
cd_ldata
differs between eval and request. But I wouldn't know how to fix that.Based one what @fclem said and by doing some more digging I managed to reproduce the issue in a more controlled environment (and without geometry nodes, but with a small code change).
New steps to reproduce:
With the file just apply P2574 and try to enter edit mode on the selected object.
removed_uvmap_bug.blend
This may be related to the more fundamental issue that when an object with a shared mesh goes into edit mode, all objects with the same mesh will show the evaluated mesh of the object that went to edit mode:
screen_recording-2021-11-03_19.42.53.mp4
The issue had nothing to do with the Object Info node in my previous post. It was just important the geometry nodes outputs an empty mesh that does not contain the uv map. This should be perfectly legal behavior.
This issue was referenced by
00e4d665f4
