Video editing crash #91873
Closed
opened 2021-10-01 13:13:57 +02:00 by fwfeet · 20 comments
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-30 23:27, hash: 3a59ddb292
Caused by 5cebcb415e
When you press N to bring out the side panel in video editing layout blender crashes
  • Open blender and choose video editing
  • Add color in the sequencer
  • Press {key N} when cursor is over the preview tab
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-30 23:27, hash: `3a59ddb292` Caused by 5cebcb415e **Short description of error** When you press N to bring out the side panel in video editing layout blender crashes **Exact steps for others to reproduce the error** - Open blender and choose video editing - Add color in the sequencer - Press {key N} when cursor is over the preview tab
Author
Added subscriber: @costa
#91928 was marked as duplicate of this issue
Member
Member
Member
Hi, thanks for the report. Introduced recently between e81533b25e- 84dcf12ceb
Will search for the exact commit
Hi, thanks for the report. Introduced recently between `e81533b25e`- `84dcf12ceb` Will search for the exact commit
Member
Added subscriber: @filedescriptor
Member
Caused by 5cebcb415e cc @filedescriptor
Added subscriber: @iss
I can't reproduce this issue. @PratikPB2123 can you give stack trace?
In 3rd step, when I press N, it hides side panel, because VSE has side panel open by default. But I don't think this si indicative of anything here.
I can't reproduce this issue. @PratikPB2123 can you give stack trace? In 3rd step, when I press N, it hides side panel, because VSE has side panel open by default. But I don't think this si indicative of anything here.
Member
@iss Are you on windows? This could be a memory corruption issue that only causes a crash on windows. Maybe an ASAN debug build would help.
I am on windows. ASAN here is bit inferior I think it only reveals write past allocated memory on stack.
Added subscriber: @tintwotin
This one is pretty bad. Crashing all the time with anything sidebar or region like swap region(here on Windows)
Member
Hi @iss , I think one step is missing in the description. Try to press {key N} when cursor is over the Preview tab
I am not able to redo this on debug build (lite)
blender.exe         :0x00007FF6B2C410F0  ED_region_panels_draw
blender.exe         :0x00007FF6B2C3FC70  ED_region_do_draw
blender.exe         :0x00007FF6B270DEF0  wm_draw_window_offscreen
blender.exe         :0x00007FF6B270DD40  wm_draw_window
blender.exe         :0x00007FF6B270D840  wm_draw_update
blender.exe         :0x00007FF6B26E88C0  WM_main
blender.exe         :0x00007FF6B236F0E0  main
blender.exe         :0x00007FF6B77C2208  __scrt_common_main_seh
KERNEL32.DLL        :0x00007FFA55A87020  BaseThreadInitThunk
ntdll.dll           :0x00007FFA572E2630  RtlUserThreadStart```
> it hides side panel, because VSE has side panel open by default. Hi @iss , I think one step is missing in the description. Try to press {key N} when cursor is over the Preview tab > can you give stack trace? I am not able to redo this on debug build (lite) ```blender.exe :0x00007FF6B2FEA8D0 UI_panel_category_draw_all blender.exe :0x00007FF6B2C410F0 ED_region_panels_draw blender.exe :0x00007FF6B2C3FC70 ED_region_do_draw blender.exe :0x00007FF6B270DEF0 wm_draw_window_offscreen blender.exe :0x00007FF6B270DD40 wm_draw_window blender.exe :0x00007FF6B270D840 wm_draw_update blender.exe :0x00007FF6B26E88C0 WM_main blender.exe :0x00007FF6B236F0E0 main blender.exe :0x00007FF6B77C2208 __scrt_common_main_seh KERNEL32.DLL :0x00007FFA55A87020 BaseThreadInitThunk ntdll.dll :0x00007FFA572E2630 RtlUserThreadStart```
When adding a color strip, a Strip tab is added to the Preview, when this is exposed Blender crashes when ex. changing the width of the sidebar.
{F10728983,size=full}
When adding a color strip, a Strip tab is added to the Preview, when this is exposed Blender crashes when ex. changing the width of the sidebar. {[F10728983](https://archive.blender.org/developer/F10728983/color_strip_crash.gif),size=full}
@filedescriptor It is caused by missing polls in the color tag patch. This should be dealt with within the operator, but here's some code which does it in the UI code, just for checking: https://developer.blender.org/P2473
Member
@tintwotin Thanks. I'll try and fix it
Member
Added subscriber: @Alumx
This issue was referenced by fc6228bd85
This issue was referenced by fc6228bd8528629da63cd9b5d012b36e0e5e9fee
Member
Falk David self-assigned this 2021-10-04 08:16:11 +02:00
7 Participants
Reference: blender/blender#91873
