Baking lighting for transformed objects is broken (3.0) #91968
5 Participants
Reference: blender/blender#91968
Operating system: openSUSE Tumbleweed
Graphics card: N/A, using CPU rendering
Broken: 3.0 alpha
18959c502d62
(official build) - didn't bisect; probably introduced much earlierWorked: Prior to Cycles-X merge
Similar to #91894, but now I realized that not just the normal pass is broken. Combined, AO, and Shadow passes are definitely also affected.
While the Normal pass was mostly fixed in
fc4886a314
, it still produces incorrect results when the Position output of the Geometry shader node is used (this affects all other passes as well). Let me know if this warrants a separate bug report.Exact steps for others to reproduce the error
Also try the above with the Normal bake pass instead.
Here is the result with unapplied transformations:
After applying:
Test file: baketest.blend
Added subscriber: @Akaricchi
This issue was referenced by blender/cycles@1a7a07a393
04857cc8ef
Added subscriber: @SteffenD
Added subscriber: @leesonw
I selected Suzanne but it would not bake, it kept complaining about an uninitialized image. Is there something else I have to setup?
You have to switch the "Image Source" on the upper left from "Single Image" to "Generated":
Thanks that worked.
Added subscriber: @brecht
This is fixed by D12766: Cycles: fully decouple triangle and curve primitive storage from BVH2.
