Multires Modifier: Subdivide / Unsubdivide damages UV #92201
7 Participants
Reference: blender/blender#92201
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash:
b7205031ce
Applying subdivisions via modifiers ends up in corrupted UV's
When you apply a subdiv or multires modifier, it will split the UV's at various areas, creating additional UV edges in the process.
This can be easily visualised by tagging Seams in the 3D Viewport.
To tag the seams we can use the menu operator
Seams from Islands
in the UV Editor under the menuUV
.We can use the Monkey primitive as an example since it is created with multiple UV islands.
Here is where Blender tags the Seams before the subdivisions are applied:
And when doing the same thing after the modifier is applied it will look like this:
UV
->Seams from Isalnds
You will see that the UV islands don't match the tagged seams.
If you proceed to drag UV points in the UV Editor around the pupil, you can see that a lot of UV edges have been split when the modifier was applied:
Added subscriber: @Zunio
painting in Mudbox after using Multires ( ugly seams ( probably padding ) at the edges of newly created inner uv islands )
Added subscriber: @iss
I wasn't able to reproduce bad result with monkey, please upload example .blend file
from the left:
Multires_UV_Seams.blend
Added subscriber: @Sergey
Thanks for example file.
When I apply multires on
multires added
object, I get significantly different result:It's not perfect though. @Sergey do you know what can cause this issue? Also I haven't found similar report, so not sure if this is design limitation if seams are not transfered perfectly.
It seems that the root cause happened at the "Apply Modifier" stage. Applying should not destroy UVs.
Unfortunately, I am unable to reproduce the issue (tried 2.93.4, 2.93.5 and the latest master build) and can't really think of what could be causing. Can try usual bizz like running Blender with a single thread and see if the Apply Modifier is behaving wrong.
Checked at 2.93.5 - at first moment uv islands stay the same but for sure uv seams have changed. Also i've done test with texturing in mudbox ( suzanne ). It acts like there are also uv seams inside uv islands ( ) ( it makes padding outside uv seam which bleeds color producing glitches inside uv islands ).
Added subscriber: @OmarEmaraDev
Can you try opening Blender from the command line with
blender.exe --threads 1
and check if the problem persists?Added subscriber: @JulienKaspar
I've been able to reproduce this bug reliably, going back as far as Blender 2.90.
I tested it with a single thread via the terminal and the issue still persists.
I talked with @Sergey about the issue and updated the task description to make the issue clearer. There seemed to be some confusion on how to reproduce the bug.
Just to be clear: Applying the modifier does not lead to corrupted seam tags, but a corrupted UV map.
The red seams just serve as a way to visualise the issue.
Bisected to
b88dd3b8e7
, and with an updated steps from Julien it seems to be same issue as #81065.What I am not sure about is why that report was considered a known limitation: the commit which caused regression does not state any user benefit, there is nothing in the release notes about extra manual steps required to be performed by artists after applying modifiers.
Not really sure there is an easy way to solve this from subsurf code: I might make it so loops which are inned to ptex faces are evaluated only once, but there is no easy way to ensure numerical equality of UVs evaluated at the ptex face boundaries. I'm also not sure this is something to be fixed in a subsurf specifically: subsurf is the most common modifier to be used in the workflow which shows the issue, but it is not the only one. Other modifiers might have same exact issue.
From the possible solutions:
** .. And look into how applying modifiers could be less annoying for artists
Added subscriber: @lichtwerk
Lets continue discussion in #81065 (Applying Subdivision/Multires Modifier De-merges UV's) (and maybe raise prio there again?), will merge reports
Closed as duplicate of #81065
