OptiX kernels fail to load when Ambient Occlusion node is used #92363
5 Participants
Reference: blender/blender#92363
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.13
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-19 23:31, hash:
ef9269bd62
Worked: 3.0.0 Alpha, branch: master, commit date: 2021-10-18 21:38, hash:
d7b231baa8
I have "Cycles Render Devices" set to OptiX. When I switch to rendered mode kernels start to load but fail with this message:
The culprit seems to be the Ambient Occlusion node as other scenes load properly. Interestingly, simply detaching AO node from shader will not help. I need to completely remove AO node from shader window, save and reload.
Switching to CUDA in settings fixes the problem. Note that I don't have an RTX card.
The same file works with yesterday's build, so the problem must have been introduced recently.
Open attached blend file and switch to rendered mode.
optix_fail.blend
Added subscriber: @MarcinTwarowski
Added subscribers: @pmoursnv, @brecht
It doesn't happen for me with an RTX card on Linux, but will mark as confirmed anyway since I have no doubt it's a real bug we should fix.
Presumably
943e73b
,d06828f
orfd77a28
is triggering this internal compiler error.CC @pmoursnv.
This is a driver bug, which can only happen with the current r495 release, so 496.13 on Windows or 495.29.05 on Linux. Fix is in the works.
Added subscriber: @SteffenD
@pmoursnv, thanks, depending on how soon this is fixed we may still want to work around it in Cycles though.
Right. Bug is that the compiler does not handle the
sub.s16
PTX instruction.add.s16
,neg.s16
orsub.s32
etc. work however, so technically just need to change the code so it uses those instead.Fortunately
sub.s16
only occurs in one place in Cycles (in intergator_shade_surface.h dues to a substraction withuint16_t
values). Unfortunately it's rather difficult to convince the optimizer to not use it (tried casting, moving code around, and so on to no success) ... Some inline PTX does the job though:This issue was referenced by blender/cycles@f72bf84eb6
be558d2d97
Ah, thanks for figuring that out. I think I can refactor the logic so we don't need to use a subtraction at all, and avoid the inline PTX.
