Preferences Interface Line Width "Thick" turns Viewport blurry #93023
Reference: blender/blender#93023
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash:
a791bdabd0
Worked: I have only experimented with Line Width "Thick" the past week and only noticed issues yesterday. I did a clean install of Blender today because of issues with the Viewport Render view in my older 2.93 version. Before installing Blender 2.93.5 I updated Nvidia driver and Windows updates. It was not till this new Blender version was installed I realized it was the Line Width that messed with the rendered view.
With Line Width set to "Thick" the Viewport Rendered View will turn a blurry grainy version compared to when Line Width is set to Default. The "effect" can be toggled on and off changing the Line Width.
I have that default material tester sphere in the scene. A camera and a HDRI set up as World Lighting. + 3 materials for the three objects in the scene.
The Blender version is downloaded and installed a few hours ago. I am using my own theme from my old Blender version, but this issue happens in the "Blender Dark" theme too.
I am Rendering with Cycles + GPU Compute and OptiX turned on for NVIDIA GeForce GTX 1070 and Intel Core i7-4770K CPU @ 3.50GHz
Added subscriber: @MaleneThyssen
Added subscriber: @lichtwerk
Can confirm, it is not just in rendered view, I can see the same in solid (first is bad, second is good):
{F11796098 size=full}
{F11796103 size=full}
Preferences Interface Line Width "Thick" turns Viewport Shading Rendered View blurryto Preferences Interface Line Width "Thick" turns Viewport blurryAdded subscriber: @Harley
This might be a issue, but I'm not yet convinced its an issue...
When testing in solid view, be careful of the "outline" option as that will respect line width. It puts an outline of line-width around objects so that is meant to be wider with wide lines.
But with that option turned off in sold view, or when in rendered view....
The primary thing that changes as you toggle "wide lines" on and off is the space between editors and (sometimes) the height of headers, etc. The result of this is that the size of the 3DView gets smaller and the view compensates for this. It isn't that the rendered view remains identical, but it zooms in slightly, the same way the view resizes when you drag to make the window smaller. It is difficult to compare images of slightly different zoom level. But generally if you compare an image at 100% against an identical image reduced to 99.9% you would prefer the larger if you compare them carefully. This is mostly because our brains are better at finding those parts that look worse - parts of greater noise or where parts might align better with the pixel grid. But we aren't as good as seeing the parts that are actually better.
So again, not saying this is not a problem. It might be.
But the only way to test this properly is take a capture at a known size of 3D editor. Then turn on wide lines and then resize the editor to compensate, so that the view sizes are identical. Then take a capture to compare. Overlay one onto the other as layers in a program like Gimp, temporarily putting the top layer at 50% to ensure that they align features perfectly.
I'd guess if the view is identical and the viewport visible size is identical that they'd be pixel-to-pixel identical.
I also noticed this recently. In case of Cycles rendered view forcing 1x pixel size in
Render Properties > Performance > Pixel Size
fixes this. It seems that automatic option of detecting pixel size is respecting the line width setting for some reason and set it to 2x.
