Rendering window is displaying wrongly result during rendering. #93155
Closed
opened 2021-11-17 12:25:01 +01:00 by Erick (Arkadiusz Pych) · 24 comments
Graphics card: NVIDIA GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.0.0 Beta, branch: master, commit date: 2021-11-16 22:49, hash: f829b86039
Rendering window is displaying wrongly result during rendering when world background is transparent with shadow catcher and tile size 128 or 256.
After render is finished, rendered image is normal and not corrupted
Outliner -> Plane (selected)
Object properties -> Visibility -> Shadow catcher "on"
Render engine: Cycles
Device GPU Compute
Render properties -> Render -> Max sample 32; Denoise "on"
Film -> Transparent "on"
Performance -> Memory -> Auto Tiles "on"; Tile size 128 or 256
bug.blend
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76 **Blender Version** Broken: version: 3.0.0 Beta, branch: master, commit date: 2021-11-16 22:49, hash: `f829b86039` Worked: (newest version of Blender that worked as expected) **Short description of error** Rendering window is displaying wrongly result during rendering when world background is transparent with shadow catcher and tile size 128 or 256. After render is finished, rendered image is normal and not corrupted **Exact steps for others to reproduce the error** Outliner -> Plane (selected) Object properties -> Visibility -> Shadow catcher "on" Render engine: Cycles Device GPU Compute Render properties -> Render -> Max sample 32; Denoise "on" Film -> Transparent "on" Performance -> Memory -> Auto Tiles "on"; Tile size 128 or 256 [Based on the default startup or an attached .blend file (as simple as possible)] [bug.blend](https://archive.blender.org/developer/F11818898/bug.blend)
Added subscriber: @aron16DotOne
Member
Added subscriber: @EAW
Member
Member
Thank you for the report.
It isn’t clear what you mean by “wrongly.” Can you please take a screenshot during rendering and afterwards, and upload them here showing the difference?
Thank you for the report. It isn’t clear what you mean by “wrongly.” Can you please take a screenshot during rendering and afterwards, and upload them here showing the difference?
Added subscriber: @brecht
I didn't see anything necessarily wrong testing this on Linux with an RTX A6000.
What I did see is that for every tile, it shows the results from rendering 1 sample, which is very noisy and looks a bit odd. Maybe that can be improved but I wouldn't call it corrupted, so I'm not sure if that is what you are seeing.
I didn't see anything necessarily wrong testing this on Linux with an RTX A6000. What I did see is that for every tile, it shows the results from rendering 1 sample, which is very noisy and looks a bit odd. Maybe that can be improved but I wouldn't call it corrupted, so I'm not sure if that is what you are seeing.
Hi, I did the screenshots. I stacked 4 photos one under another in to one picture. Picture also contain arrows and short info about tile size.
Currently for work i am using 2.93.6 now. And such problem doesn't exist over there.
As you can see I am using bit old Nvidia card with Cuda.
What I see and kind of trying to understand it is like rendering tile square doesn't display properly result in real time in the screen (and this only happens with transparent parts) and later moves to another tile leavening behind this unfinished look.
Now I know when I let render finish final render will be correct without any this kind of artefacts.
When I saw this for the first time, I thought my rendering is corrupted with such unfinished tiles so I stopped rendering.
Hi, I did the screenshots. I stacked 4 photos one under another in to one picture. Picture also contain arrows and short info about tile size. Currently for work i am using 2.93.6 now. And such problem doesn't exist over there. As you can see I am using bit old Nvidia card with Cuda. ![rendering.jpg](https://archive.blender.org/developer/F11822338/rendering.jpg) What I see and kind of trying to understand it is like rendering tile square doesn't display properly result in real time in the screen (and this only happens with transparent parts) and later moves to another tile leavening behind this unfinished look. Now I know when I let render finish final render will be correct without any this kind of artefacts. When I saw this for the first time, I thought my rendering is corrupted with such unfinished tiles so I stopped rendering.
I still can't reproduce this. Maybe someone in the bug triaging team can reproduce it?
Member
Added subscriber: @lichtwerk
Member
Not seeing this either
Operating system: Linux-5.13.0-0.rc6.45.fc35.x86_64-x86_64-with-glibc2.34.9000 64 Bits
Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.31
version: 3.1.0 Alpha, branch: master, commit date: 2021-11-21 16:37, hash: `rBfb470c256aac` also checked rB7e82c840b7a4
Not seeing this either ``` **System Information** Operating system: Linux-5.13.0-0.rc6.45.fc35.x86_64-x86_64-with-glibc2.34.9000 64 Bits Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.31 version: 3.1.0 Alpha, branch: master, commit date: 2021-11-21 16:37, hash: `rBfb470c256aac` also checked rB7e82c840b7a4 ```
Contributor
Added subscriber: @Raimund58
Contributor
Contributor
I can confirm with his bug.blend in Blender 3.0 and Blender 3.1. The trick is to enable either CUDA+CPU or OPTIX+CPU.
system-info.txt
I can confirm with his bug.blend in Blender 3.0 and Blender 3.1. The trick is to enable either CUDA+CPU or OPTIX+CPU. [system-info.txt](https://archive.blender.org/developer/F11858314/system-info.txt) ![2021-11-22 23_55_09-Blender_ [C__Users_raimu_Downloads_bug.blend].png](https://archive.blender.org/developer/F11858456/2021-11-22_23_55_09-Blender___C__Users_raimu_Downloads_bug.blend_.png)
Added subscriber: @Sergey
CC @Sergey
CC @Sergey
@brecht Thanks for bringing my attention. Unfortunately I can not reproduce neither of the issues here. For the 1st sample only visible, can you try P2615 to see whether it is caused by timing which makes it so no update i scheduled?
For the corrupter tile display, does it only happen when rendering to new window, or is also happening when rendering into fullscreen/image editor ?
@brecht Thanks for bringing my attention. Unfortunately I can not reproduce neither of the issues here. For the 1st sample only visible, can you try [P2615](https://archive.blender.org/developer/P2615.txt) to see whether it is caused by timing which makes it so no update i scheduled? For the corrupter tile display, does it only happen when rendering to new window, or is also happening when rendering into fullscreen/image editor ?
Contributor
It is also happening when rendering into the image editor. What do you mean with "fullscreen"?
> For the corrupter tile display, does it only happen when rendering to new window, or is also happening when rendering into fullscreen/image editor ? It is also happening when rendering into the image editor. What do you mean with "fullscreen"?
Oops, is called "Maximized area".
@Sergey, P2615 does not change anything as far as I can tell.
@Sergey, [P2615](https://archive.blender.org/developer/P2615.txt) does not change anything as far as I can tell.
Sergey Sharybin self-assigned this 2021-11-24 16:23:18 +01:00
Ah, i see now. The 1st sample thing mentioned by Brecht is how it is currently expected to work: 1st sample is shown very quickly, and then at the next render work the tile is done and displayed at final number of samples, but the highlight is moved to the next tile. With such quick rendering I'm not sure we can do anything without hurting render time.
For the originally reported issue I can reproduce it now once I've realized having CPU+GPU rendering is essential to reproduce the issue.
Ah, i see now. The 1st sample thing mentioned by Brecht is how it is currently expected to work: 1st sample is shown very quickly, and then at the next render work the tile is done and displayed at final number of samples, but the highlight is moved to the next tile. With such quick rendering I'm not sure we can do anything without hurting render time. For the originally reported issue I can reproduce it now once I've realized having CPU+GPU rendering is essential to reproduce the issue.
This issue was referenced by blender/cycles@2c99ca1eb8
This issue was referenced by blender/cycles@2c99ca1eb8da6d787ba7423448e80f37485417f2
This issue was referenced by 726bc3a46b
This issue was referenced by 726bc3a46b2fcf6ba36c3e3484b344340f83e53e
7 Participants
Reference: blender/blender#93155
