Armature widgets from hidden collections are invisible. #93439
5 Participants
Reference: blender/blender#93439
Broken: 3.0
8f2db94627
Worked: 3.0
2cc56495f3
Immediate cause:
a07089dcb1
Armature widgets using objects from a collection that is excluded or hidden in viewport are invisible until the collection is temporarily unhidden.
Secondary, old but likely related issue: even before, modifiers on the widgets didn't work in the same exact circumstances.
Add a Rigify metarig and generate a character rig, or open an existing file with a generated character. All control bone widgets are invisible.
Technical analysis
The root cause of the issue is likely that the widget objects aren't registered as dependencies for the rig, and aren't evaluated. Previously this manifested as modifiers (e.g. subsurf) often not working on such objects. However the referenced commit made the evaluated mesh mandatory for drawing the widgets, thus completely breaking them.
Test Plan
Test file: custom_shape_rigify.blend
d2e6087335
will not show that "widget" visible. This is incorrect.Screenshot of expected state:
Added subscriber: @angavrilov
Added subscribers: @dr.sybren, @dfelinto
Removed subscriber: @angavrilov
Relevance of the commit confirmed by reverting, which fixes the immediate regression.
Maybe a simple fix is using the original mesh if the object is a mesh object and the evaluated mesh isn't found.
Of course the better solution is to figure out the suspected dependency issue. As I said, there is a secondary long-existing issue that modifiers don't work in the same circumstances, and this change likely just made the same root problem worse and more obvious.
Added subscribers: @fclem, @Sergey
Maybe @fclem or @Sergey would have an idea of the proper fix for the suspected dependency issue (TLDR: custom shape objects aren't evaluated unless independently visible).
However unless the fix is obvious and safe it's probably something for master, and 3.0 regression can be safely fixed by temporarily reverting the commit.
Hmm, the commit fixed another import issue though. So I still think a simple fix would be using the original mesh if necessary and possible.
As I mentioned in the commit, I think the proper fix is using the instancing system to generate the widgets. A dependency could be added in the depsgraph, and the instances could be marked to only display in the viewport.
I am confused about the technical analysis. And the lack of simple .blend file makes it harder to investigate from my side. You already have demo file ready to be tested, just upload them here and save some repro steps ;)
The dependency graph ensures that if the rig is visible the object used for the custom shape is evaluated (see the
deg_builder_nodes_rig.cc
around theif (pchan->custom != nullptr) {
).I've tested the system with the attached file and. it seems to work fine in both 2.93 and 3.0. The handling of visibility in depsgraph did not change during 3.0 cycle, so to me is not immediately obvious that the depsgraph side is not doing what it's supposed to.
custom_shape.blend
If someone can upload same level of complexity of file demonstrating the issue that'd make troubleshooting from depsgraph side.
As for reverting I'm not sure about it. I'll trade one regression with another, which isn't very great.
This issue was referenced by
aa7051c8f2
The test file in the task description should really get an explanation, ideally with a screenshot of what it ought to look like. Right now I can open it, and I see only a camera and a light. Should there be custom bone shapes visible? Given the report I think so, but a screenshot would help a lot. If anything else, it would remove guesswork and provide a clear picture (literally) of the expected/correct situation.
@dr.sybren Added a simple test plan with a screenshot of an expected state. Also removed lamp and camera to make things less distracting in the viewport. Hope it clarifies things.
