Viewport performance drops drastically after switching from atributte visualization to solid view #93440
10 Participants
Reference: blender/blender#93440
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14802 Core Profile Context 21.11.2 30.0.14005.1000
Broken: version: 3.0.0 Release Candidate, branch: master, commit date: 2021-11-25 17:24, hash:
2fb8c6805a
I have a curve with an specific setup of geometry nodes, that for some reason, if I go from solid mode->eevee->solid mode again, it slow downs performance drasticaly for no reason.
The problem also occurs on objects that contain Sculpt Vertex Colors.
Open the file, switch to rendered view and then back to solid view. note that if you go back to eevee again the performace gets back to normal.
In the video below you can see the fps dropping in the corner. It wasn't recorded with default settings, but I tried restoring them and it gave me the same result
2021-11-27 20-52-26.mp4
geometry nodes slowdown.blend
Notes:
Added subscriber: @Diogo_Valadares
#96003 was marked as duplicate of this issue
#95766 was marked as duplicate of this issue
Added subscriber: @deadpin
Confirmed here too. Toggling the GN modifier off/on will also return performance back to normal.
Added subscriber: @costa
Confirmed here too
Added subscriber: @lowpolysaac
This comment was removed by @lowpolysaac
If I apply the modifier, I can still reproduce this issue, so I don't think it's related to geometry nodes.
What I did find is that the tangents are being recalculated on every redraw, with
blender::draw::extract_tan_ex_init
being the main performance culprit here. I'm guessing that switching between EEVEE and workbench somehow messes up the mesh data extraction system. But I don't know much about that area.Geometry nodes reduces viewport performance drasticaly after switching from eevee to solid viewto Viewport performance drops drastically after switching from eevee to solid viewI just got the same problem problem with another file(blender 3.1 alpha):
slowdown2.blend
How did you apply the modifier? Converting it to mesh fixes the problem for me, I can't directly apply the modifier because its a curve and it contains construtive stuff and using a mesh as input and converting it to curves in geometry nodes also doesn't cause me problems.
Added subscriber: @EAW
Reminds me of #78161 (Workbench refactor causes significant performance regression with workbench shadows). I wonder if there is something in Workbench’s code making it susceptible to have updates get called way too often.
Ah, right, yes, I meant that I converted the object to a mesh object. That also initially fixed the problem for me, but then I toggled render and workbench a few more times and the problem came back.
I decided to test this a little bit more and I found some things that might be what is causing the problem.
In both geometry nodes I sent, I'm transfering some attributes to the output of the geometry nodes, and right after I use them on the shader nodes.
Once I remove the attribute groups from the output, the problem doesn't happen anymore. Also, if the groups aren't being used by the shader, the problem does not occur too.
After applying the modifier the problem still occurs because the attributes are still stored on the mesh. Btw I don't know why but it also create those "anonymous attributes" that are the outputs of the geometry nodes even tho those attributes already exist with another name(but I think this is an unrelated problem)
Once you remove the atributes the problem does not occur anymore.
And after a close look I think the type of the attribute and where its stored makes a huge difference on how much the performance is affected. You can take a look at the first example, the only attribute being used is a generated "uvmap" that is a vector stored on face corners, and even tho its much simpler and less poly dense than the second file, it takes the fps to 6. the second file contains 5 float attributes stored on vertices and still have decent fps.
Just noticed today that this glitch also occurs when using the Experimental Sculpt Vertex Colors, since its stored in attributes.
If stored to reguler vertex colors, it does not affect performance, even tho its seems to also be kept in the attributes.
It seems like it doesn't even need to be in eevee for the performance to be affected. If you switch to vertex visualization in the regular solid view and then switch back, it also reduces the performance.
2022-01-12 13-08-55.mp4
Viewport performance drops drastically after switching from eevee to solid viewto Viewport performance drops drastically after switching from atributte visualization to solid viewAdded subscriber: @lictex_1
Added subscribers: @Rawalanche, @PratikPB2123
Added subscriber: @Olliver
With #96003 being fixed I tested to see if the problem here was also fixed, and it seems so.
I tested in both 3.1 and 3.2 alpha but I'd like some confirmation for that in case I tested something wrong.
should be
a911f075d7
fixed thisChanged status from 'Confirmed' to: 'Resolved'
I guess this task can be closed then.
Added subscriber: @GaryRitchie
