3.0 Potential candidates for corrective releases
Confirmed, NormalPublic
To Be Backported
NOTE: When adding items, please add them to the bottom of the list.
ReportCommits in MasterRemarks
T94784rB5703efab886d: Fix T94784: Crop node gizmo doesn't workdoes not apply, unclear if really needed
D13856
Blender 3.0.1
ReportCommits in master Commits in blender-v3.0-releaseRemarks
T91680rB98bb8e6955b1: Fix T91680: viewport selection broken in macOS x86 build with Xcode 13rB8ca4d2087833: Fix T91680: viewport selection broken in macOS x86 build with Xcode 13
-rBcdd61bb6d799: Fix Cycles AVX test failure with x86_64 build running on Arm rBa5b4373f9506: Fix/workaround macOS Rosetta crash running Cycles AVX testsrBd02eecc0ca7e: Fix Cycles AVX test failure with x86_64 build running on Arm rBe78a21afb699: Fix/workaround macOS Rosetta crash running Cycles AVX tests
-rB3692c0521ce5: Fix Asset Browser properties region toggle not showing open/closed staterB2af6cb9dce38: Fix Asset Browser properties region toggle not showing open/closed state
-rB2f7bec04e8e7: Asset Browser: Fix incorrect user messagerB24a79289b01e: Asset Browser: Fix incorrect user message
-rB7336af325937: Fix some shortcut keys not working on macOS with Japanese inputrB8b44b756d850: Fix some shortcut keys not working on macOS with Japanese input
T92561rB02ab4ad99190: Fix T92561: unstable particle distribution with Alembic filesrB77694b571f5b: Fix T92561: unstable particle distribution with Alembic files
T93508rB8cf0d15b6021: Fix T93508: Shift+F1 to switch to asset browser randomly crashesrB256a2d1e986e: Fix T93508: Shift+F1 to switch to asset browser randomly crashes
T93563rB0f89d05848b8: Fix T93563: Crash subdividing with overlapping tri and quadrB490f1648a78d: Fix T93563: Crash subdividing with overlapping tri and quad
T93541rB7c4fc5b58d2e: Fix T93541: Use warning instead of error for exceeding layer limitsrBc37cd3546904: Fix T93541: Use warning instead of error for exceeding layer limits
T93574rBde5d36560f93: Fix T93574: Asset triangulating a meshrB580c603df08a: Fix T93574: Asset triangulating a mesh
T93388rB9a69c456bd85: Fix T93388: dropping object on grid in orthogonal view misses the floor planerB256c1b82f6e3: Fix T93388: dropping object on grid in orthogonal view misses the floor plane
T93732rB3d8dea9ff92d: Fix T93732: Snap Cursor not working after changing Add Object settingsrB4c8b93c5c2d9: Fix T93732: Snap Cursor not working after changing Add Object settings
T93611rB0e52af097f9f: Fix T93611: Curve modifier crash in editmode in certain situationsrB46f5b305e4a6: Fix T93611: Curve modifier crash in editmode in certain situations
T93707rBb9c6ef4e8fcf: Fix T93707: Dragging the tweaked NLA strip causes crashrBfd4c343dcdce: Fix T93707: Dragging the tweaked NLA strip causes crash
-rBa5e389985361: VSE: Fix strip with mask modifier not blendingrB1fd824345d52: VSE: Fix strip with mask modifier not blending
T93314rB7d1a10a9bbf3: Fix T93314: Thumbnails not drawn with default scalerBe29026bb4b4d: Fix T93314: Thumbnails not drawn with default scale
T93521rBee4ed99866fb: Fix T93521: Single point NURBS crash in resample noderB669577a9736a: Fix T93521: Single point NURBS crash in resample node
T93773rB50fb0fd636a4: Docs: Incorrect link to context typerBd009056b0113: Docs: Incorrect link to context type
T93467rB6a9775ec6fd3: Fix T93467: Use world bg color for pose library previewsrBb93127c57b24: Fix T93467: Use world bg color for pose library previews
T93728rB72b39d3f9200: Fix T93728: Greasepencil separate will loose all vertex groupsrB0b7dbff04a4a: Fix T93728: Greasepencil separate will loose all vertex groups
T93869rBcf6be711e2a0: Fix T93869: snap cursor may fail in orthographic viewrBb4c9f8da885a: Fix T93869: snap cursor may fail in orthographic view
T93858rBbe2213472f82: Fix T93858: Zstd-compressed .blend files from external tools aren't recognizedrB56bd7adce74d: Fix T93858: Zstd-compressed .blend files from external tools aren't recognized
T93892rBfc14d02bc596: Fix T93892: Changing bone name leaves non-functional vertex grouprB10d65b821b4e: Fix T93892: Changing bone name leaves non-functional vertex group
T93691rB5ce1c63e1bf0: Fix T93691: Crash when loading custom thumbnail in custom libraryrB88f8b01e669d: Fix T93691: Crash when loading custom thumbnail in custom library
T84710rBb869da0c1089: Fix T84710: Instances with only mesh edges or vertices are invisiblerBa8a9a08bf786: Fix T84710: Instances with only mesh edges or vertices are invisible
T93871rBe427e4dbb125: Fix T93871: Image.has_data returns True for images that failed to loadrB5beadc31d645: Fix T93871: Image.has_data returns True for images that failed to load
T93874rB56fa6f58a0f8: Fix T93874: Cycles crash with fast GI approximationrB55ecdf3195d6: Fix T93874: Cycles crash with fast GI approximation
T93890rB4b00a779ecf8: Fix T93890: Cycles error with shadow catcher + OptiX denoise without passesrBe83df74008b0: Fix T93890: Cycles error with shadow catcher + OptiX denoise without passes
T93498rBad44f22397b0: Fix T93498: Cycles fast GI add method affected by bounces settingsrBdc7ff75ef85a: Fix T93498: Cycles fast GI add method affected by bounces settings
T93591rBf886f293550c: Fix T93591: Random Value node first and last value proportionrB99efb9544138: Fix T93591: Random Value node first and last value proportion
T93430rBab2a7aa0da81: Fix T93438: Auto linking do not work for custom socketsrB61fe0d626441: Fix T93438: Auto linking do not work for custom sockets
T93169rBe549d6c1bd2d: Fix T93169: Weightpaint falloff popover drawn twicerB7d5fa5166667: Fix T93169: Weightpaint falloff popover drawn twice
T94243rB5519a6a52062: Fix T94243: weightpaint gradient panel shown in other placesrB21f02dd85d93: Fix T94243: weightpaint gradient panel shown in other places
T93704rB8709cbb73e7d: Fix T93704: StructRNA.path_resolve fails silently with missing keysrBad4d66580e81: Fix T93704: StructRNA.path_resolve fails silently with missing keys
T93649rBb5c18288f5bd: Fix T93649: Blender freezes when saving with active VR sessionrB58ee4852b6e2: Fix T93649: Blender freezes when saving with active VR session
-rB6a885e5d8959: Fix meta-ball bound-box calculation reading past buffer boundsrB62ce0c60cd5f: Fix meta-ball bound-box calculation reading past buffer bounds
T93971rBe85d7d5a2880: Fix T93971: "Center Cursor & Frame All" fails to redrawrBb9f5e6c0b4cb: Fix T93971: "Center Cursor & Frame All" fails to redraw
T94082rB67b657f07c96: Fix T94082: Curve to point empty evaluated NURBS crashrB0a6b6eb13ba6: Fix T94082: Curve to point empty evaluated NURBS crash
T92838rB7061d1e39fea: Fix T92740: Missing lock around the image CacheLimiterrBff5630b7fafe: Fix T92740: Missing lock around the image CacheLimiter
-rBe8a8bb67fcef: Cleanup: Correct order of guard and lock in moviecache_valfreerB0564b19ff4dd: Cleanup: Correct order of guard and lock in moviecache_valfree
T94115rB0f589f8d3ccc: Fix T94115: Selecting current action in undo history undoes allrB50ecf9dcf5cd: Fix T94115: Selecting current action in undo history undoes all
T94109rB9765ddf4eb1e: Fix T94109: 3d cursor crash when using shortcutrB52905c02ae42: Fix T94109: 3d cursor crash when using shortcut
T94184rB76fd2ff9fa49: Fix T94184: Outliner: Collection dragging tooltip is not updatingrBfa0173f7289a: Fix T94184: Outliner: Collection dragging tooltip is not updating
T94254rB0b697934878e: Fix T94254: Crash using view_all operator in VSErB56d45a297472: Fix T94254: Crash using view_all operator in VSE
T94280rBe4de5b4657d3: Fix T94280: Crash when splitting meta striprB606f6e73b04c: Fix T94280: Crash when splitting meta strip
T94191rB6db09197242c: Fix T94191: correct (time) translation headers not showing DeltaXrB66addab27ac7: Fix T94191: correct (time) translation headers not showing DeltaX
rB978a930d9cf6: Fix: Build issue on 32 bit archsrB6514e4c41807: Fix: Build issue on 32 bit archs
T93408rB586e2face61c: Fix T93408: Snap performance regression at high poll raterBb2e15cb19dab: Fix T93408: Snap performance regression at high poll rate
T94334rB08226693cfa2: Fix T94334: 3DView View Menu Close Error
T94375rBe505957b47a9: Fix T94375: Python error when trying to add Grease Pencil brush presetrB5d80b64d2806: Fix T94375: Python error when trying to add Grease Pencil brush preset
T93620rBe14f8c2dd765: Cycles: Reintroduce device-only memory handling that got lost in Cycles X mergerB3d5dbc1c4490: Cycles: Reintroduce device-only memory handling that got lost in Cycles X merge
T94442rB4cbcfd22f5d2: Fix T94442: Trim curve node can crash with duplicate pointrB512014f04216: Fix T94442: Trim curve node can crash with duplicate point
T94454rBc0fdf1656103: Fix T94454: Python API curve to mesh use after free without depsgraphrB50c39ff8fe04: Fix T94454: Python API curve to mesh use after free without depsgraph
T93163rB49a18cc91e55: Fix T93163: GPencil scale thickness fails in negative scalesrB784c04bcbd33: Fix T93163: GPencil scale thickness fails in negative scales
T93134rB52da1afbf67c: Fix T93134: Set origin broken for curve edit moderBe8a8e953b3d1: Fix T93134: Set origin broken for curve edit mode
T93868rBe0d1e6673215: Fix T93868: GPencil material filter does not work with instancesrB6bd924c748ac: Fix T93868: GPencil material filter does not work with instances
-rBe79b4523b410: LineArt: Correct collection intersection mask logic.rB7339663bbc3c: LineArt: Correct collection intersection mask logic.
-rB97ae08c9fcca: LineArt: Correct clamping of out of bound isect indexrB69c56d2819a3: LineArt: Correct clamping of out of bound isect index
T94392rB818947191256: Fix T94392: 3D Cursor surface projection onto hidden geometryrBcd804fb2e968: Fix T94392: 3D Cursor surface projection onto hidden geometry
T94620rB55842b424477: Fix T94620: GPencil AutoMerge does not work when Draw On Back is enabledrB29c4c78a3896: Fix T94620: GPencil AutoMerge does not work when Draw On Back is enabled
T94169rB8cd6d0fe6876: Fix T94169: Missing grease pencil render with tiled renderingrBe84625dcbcfe: Fix T94169: Missing grease pencil render with tiled rendering
T94169rB5e7e571b0df4: Fix Cycles using Cancel semantic on final result writerB3707a7847198: Fix Cycles using Cancel semantic on final result write
T94169rB3c04b4491373: Fix Cycles allocating result too earlyrBc3457af23f0e: Fix Cycles allocating result too early
-rBf7a0f6a0e4bf: Fix T94563: Cycles standalone build error on with strict float/double castingrB7d26cf01f78c: Fix T94563: Cycles standalone build error on with strict float/double casting
T94506rB924d2b8df601: Fix T94506: Crash in CompositingrBed397ff50786: Fix T94506: Crash in Compositing
T93695rB1dc0bf86bb50: Fix T93695: Discontinuous cutting with the knife toolrB72aefef9d23a: Fix T93695: Discontinuous cutting with the knife tool
T94145rBe3748d7fa557: Fix T94145: Knife tool fails in orthographic moderB9a7b1d22450c: Fix T94145: Knife tool fails in orthographic mode
T93418rBa92805bf24f5: Fix T93418: Cycles shadow terminator Geometry Offset artifacts with translucencyrB4c8740a45217: Fix T93418: Cycles shadow terminator Geometry Offset artifacts with translucency
T94708rBf24854005d86: Fix T94708: negative reference count error with Python API callbacksrB3b686b823353: Fix T94708: negative reference count error with Python API callbacks
T93949rB644eb68524b9: Fix T93949: Preview Image Error When No ScreenrBe53f3954a44b: Fix T93949: Preview Image Error When No Screen
T94600rB1b1e9471625d: Fix T94600: Apply single shrinkwrap constraint failsrB15e4d0f25d75: Fix T94600: Apply single shrinkwrap constraint fails
T93509rBAc60fef38175a: Fix T93509: Unintended navigation on Valve IndexrBA183f92c7d5fa: Fix T93509: Unintended navigation on Valve Index
T94264rBAc08568cc376d: Fix T94264: Pose Library, doubleclick-to-apply only in asset browserrBA5876b7836db4: Fix T94264: Pose Library, doubleclick-to-apply only in asset browser
T94122rBA1679f2fdbb13: Fix T94122: Export to X3D Fails.rBAc7be98348958: Fix T94122: Export to X3D Fails.
T93477rB251c0175349d: Fix T93477: Viewport X-Ray is influencing snapping even in material moderB9d6680e7f9b7: Fix T93477: Viewport X-Ray is influencing snapping even in material mode
T94728rBfc0f315106a6: Cleanup: remove unnecessary 'use_opengl_context' parameterrBedc85e182e38: Cleanup: remove unnecessary 'use_opengl_context' parameter
T94728rB6774cae3f25b: Fix T94728: Auto Depth problem with Cliping RegionrBaafbd7464656: Fix T94728: Auto Depth problem with Cliping Region
T94799rBac3d07ad178d: Fix T94799: GPencil Strokes drawn at 0.0 Strength still visiblerB44ac03785c52: Fix T94799: GPencil Strokes drawn at 0.0 Strength still visible
T92953rBf1a488d0f2d3: Fix T92953: Tool Settings: Drag on Tweak fails with LMB selectrB1d462e172981: Fix T92953: Tool Settings: Drag on Tweak fails with LMB select
T94624rB97c2c3991620: Fix T94624: Object as font instances don't workrB71bc9d47601a: Fix T94624: Object as font instances don't work
rB7a0cf2c72f58: Fix crash caused by exception in Python gizmo target get handlerrB40c5786df330: Fix crash caused by exception in Python gizmo target get handler
T94903rB86b7746e3c31: Fix T94903: GPencil: Copying keys doesn't preserve Keyframe TyperBd7a1fc0868f1: Fix T94903: GPencil: Copying keys doesn't preserve Keyframe Type
T94089rBc0432d5edb23: Fix T94089: GPencil Drawing don't Update after paste in DopesheetrBbcca7bf9755c: Fix T94089: GPencil Drawing don't Update after paste in Dopesheet
T94878rB0cf746c1faff: Fix T94878: LineArt crease threshold logic error.rB5079a460a748: Fix T94878: LineArt crease threshold logic error.
T94827rB85df7036f76b: Fix T94827: Group Input/Output cannot connect to custom socketsrB688713db24b1: Fix T94827: Group Input/Output cannot connect to custom sockets
T94768rBf2fb9a0c59ab: Fix T94768: Crash in VSE prefetchingrB9600f36cfcba: Fix T94768: Crash in VSE prefetchingalso changed behavior, used P2726 only
T94715rBb776c46d2f67: Fix T94715: multiple volumes using the same .vdb causes freezerB0039432cfcc5: Fix T94715: multiple volumes using the same .vdb causes freeze
T94197rB5d7ac749c5f9: Fix T94197: Applying boolean with fast solver clears bevel weightsrBb3fe13585477: Fix T94197: Applying boolean with fast solver clears bevel weights
rB6a8ad00bccdf: Cleanup: Avoid possible NULL pointer errorrB822501d86df9: Cleanup: Avoid possible NULL pointer error
T94202rB2e5aecf557fb: Fix T94202: GPUFrameBuffer: wrong refcount in the buffer passed for read_color…rB63b9e5378b81: Fix T94202: GPUFrameBuffer: wrong refcount in the buffer passed for read_color…
Related Objects
Mentioned In
T94799: Grease Pencil Strokes drawn at 0.0 Strength still visible
T94694: Auto refresh option causes blender to crash.
T94630: crash when assign a preview to a specific asset in the asset browser
T94615: Blender 3.0 consistently crashes when RSS nears 5GiB on Linux (easy to trigger with video playback)
T93620: Cycles X broke OptiX memory pooling via NVLink
T94386: Viewport Crashes with Image Sequence Texture Update
T94319: Selection of objects by clicking on them not working
T94312: Blender 3.0 crashes when motion tracking hits prefetch limit
T94321: Weird selection unwanted offset
T94291: Metaball "Undo" crash
T94130: Blender Camera Background Video Crash
T94266: Crash with Movieclip background in Camera view
T94131: Blender crashes when linking curve modifier in edit mode with vertex group
T93935: Blender 3.0 Motion tracking footage just crashes blender
T94138: FBX files that can be imported in 2.93 fail to import in 3.0
T93704: gltf2 not exporting animations in 3.0
T93430: Custom node sockets don't get relinked when dropping a node on an existing link
T93541: Blender 3.0 cannot import FBX (containing more than 8 UV layers)
T93509: VR Add-on: Unintended navigation when using Valve Index
T93160: Boolean Operation on Mesh Grid Cause "Random Per Island" to Give Unpredictable Results in Cycles
D13434: Fix T93521: Single point NURBS crash in resample node
Mentioned Here
D13856: Mesh: Add versioning in 3.0 for vertex normal refactor
T94202: crash or error when using GPUFrameBuffer.read_color(... data=data)
T94197: Boolean Apply Clearing custom data layers (bevel weight Weight / Vgroup Data)
T94715: Multiple volumes using same data can cause crash/freeze
T94768: Video Sequencer Preview with Prefetch Frames crashes inside Meta Strip
P2726 (An Untitled Masterwork)
T94783: 3Dmouse navigation - Tilt axis are reversed in walk/fly mode
T94827: Regression: Group Input/Output cannot connect to some custom sockets
T94878: Line Art: Per object Override Crease setting does not work
T94089: Grease Pencil Drawing don't Update after paste
T94624: Object As Font not working
T92953: Tool Settings: Drag on Tweak not working
T94243: Spare falloff panel
T92561: Mesh Sequence Cache (ABC) an hair interpolated children distribution issue (triangulate modifier seem to fix it)
T94600: Constraint Shrinkwrap does not applies, it reset all changes
T93949: save_as_mainfile will crash if context has no screen
T94708: New-file causes Python assert with negative reference count
T93418: Shadow Terminator Geometry Offset causes artifacts for translucent shader (Cycles)
T94145: Knife project fails in orthographic mode
T94169: Regression: Grease Pencil does not show up in render past 2049x2049 render resolution
T94620: Grease Pencil AutoMerge does not work when Draw Strokes On Back is enabled
T94392: 3D Cursor surface projection onto hidden faces
T93868: Grease pencil hue and tint modifiers don't work with selected material
T93134: Set Origin causes unexpected offset on Grease Pencil strokes when Curve Editing is enabled
T93163: Scaling Grease Pencil Strokes in Edit Mode Scales Thickness
T94454: Crash in nvoglv64.dll entering edit mode on curve
T94442: Extruding first vertex of a spline with GN modifier enabled causes a crash
T94334: Close Area crashes Blender (3.0.0 and 3.0.1)
D13656: Fix T94334: 3DView View Menu Close Error
D13660: Fix T94334: Area close operator crash in 3D view menu
T94191: DeltaX does not show how many frames you are moving your keyframes
T94264: Blender Crashing While Appending Animation Action
T94280: Crash when cutting meta-meta
T94254: Crash when the Home button is pressed in the VSE
T94115: Selecting current action in Undo History Undoes all the History
T92838: Crash when exceeding memory_cache_limit in the viewport
T94082: Crash on changing curve type from Bezier to NURBS in Geometry Nodes
T93971: 3D Cursor is not in the right place after Shift + C (Center Cursor and Frame All)
T93169: redundant 'falloff' dropdown in weight paint header
T93591: Geometry Nodes: Random Integer min and max values half as frequent
T93498: When render with Cycles' Fast GI Approximation, Method "Add" is affected by bounces in Method "Replace".
T93874: Fast GI Approximation Render Crash
T93890: Shadow Catcher - Cuda Error in Viewport Rendering with Optix Denoiser.
T93871: img.has_data Always returns True since version 3.0
T84710: Instances of only vertices/edges not properly shown in viewport
T93691: Crash when trying to load custom preview in asset browser with user library selected
T93892: Change bone name cause vertex group not working until select another vertex group
T93869: Measure active tool fails in front view with snap incremental enable
T91680: Selection in the 3d view is broken in build from Xcode 13
T93728: When seperating a grease pencil stroke to its own object it will lose all vertex groups
T93467: Use World background color when rendering pose library previews
T93784: [EEVEE] Blender 3.0 - Bug : Text objects AND CURVE objects have no motion blur.
T93773: 3.0 Documentation broken link?
P2648 T93521 Fix 3.0 Branch
T93314: Video editor thumbnails don't show at the default zoom level
T93756: Hiding all points of a spline in curve edit mode does not hide splines
T93707: Dragging the NLA strip cause a crash, if the related action is in tweakmode
T93611: Crash on edit mesh with a curve modifier with both a vertex group assigned and the edit mode display option enabled
T93732: Snap Cursor not working after changing Add Object tool settings
T93388: Asset browser: dropping object on grid in orthogonal view misses the floor plane
T93574: Triangulating a mesh with overlapping tri and quad faces can cause an assertion failure
T93573: Regression: Selection outline of curves in edit mode
T92962: Mesh Boolean node changes vertex indices randomly
rBc26011efcbe1: Fix T92962 Boolean output indices unstable.
T93563: Subdividing with overlapping tri and quad crashes Blender
T93555: Crash When Muting Group Nodes Containing Join Geometry Node
rB198e571e87ea: Fix T93555: crash when muting nodes with multiple internal links
There are a very large number of changes, so older changes are hidden. Show Older Changes
I've now bumped the version to 3.0.1 rc in the release branch, to be able to commit some fixes required for buildbot changes.
OK, thx, I could start committing the list to the branch (was waiting for feedback on #blender-coders regarding that release still)
