Blender 3.1 Documentation #93586
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#93586
Added subscriber: @Blendify
Added subscriber: @dodo-2
Added subscriber: @Alaska
@Blendify can I ask you a question?
Cycles: expose direct light sampling option in Debug panel, tweak panel layout
- This change is only visible in the UI if you build Blender with theWITH_CYCLES_DEBUG
build flag enabled. By default, this flag is disabled, and as such "average users" (people using the release builds, and the builds from the build bot) are going to be unable to see this option.My question is: Should we include documentation about this feature in the manual if it's not there in the "release" build of Blender?
No, I might have missed that when browsing changes to be included, I mostly base the list off the title/message + a short skim of the changes so sometimes I make a mistake here.
Although the commit also has some layout changes which need to ensure https://docs.blender.org/manual/en/latest/render/cycles/render_settings/debug.html is up to date.
Added subscriber: @satishgoda1
