Asset Library can be defined with relative path #93774
Reference: blender/blender#93774
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.63
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
Asset Library defined with a relative path looses path and displayed content when the Asset Browser editor is resized
Path to asset library does not exist
message shows upStartup file if relevant userpref.blend
AssetBrowser (1).mp4
Tested on two different windows 10 computers with the same reproducible results. Resizing in any direction has the adverse effect, and changing the Import Type from the dropdown to any value (may even be the same) always triggers a refresh that brings back the content. It doesn't seem to happen if the Asset Library uses an absolute path.
The Asset Browser isn't supposed to work with such relative paths. I can see why this may be super useful, but it's not something the design currently covers. Not sure if it's worth changing that.
If anything needs fixing, it's that the UI code apparently doesn't enforce absolute paths. Anything else would be a design change.
@dr.sybren thoughts?
After discussion with @JulianEisel we decided that relative paths cannot be supported right now. The biggest issue is that when you have any path other than
, let's say*assets
, opening a blend file inside the asset library will not detect it as being in that asset library.To make it more concrete, let's say I have
/home/sybren/blendproject/somefile.blend
. Opening it would load the assets from/home/sybren/blendproject/assets
. So far so good. Now, when I try to edit those assets, I open/home/sybren/blendproject/assets/objects.blend
; when this file is opened, it will expect the asset library to be in/home/sybren/blendproject/assets/assets
and not find anything. This will make the asset browser not find the catalogs, and also it won't be able to show any of the other assets in the library.This task is good to keep open, though, because Blender shouldn't even accept relative paths (it does so now, and to make things worse, the directory select window still has the "relative path" option).
Asset Library looses path when Asset Browser editor is resizedto Asset Library can be defined with relative pathAh I see, thanks for the feedback.
This is indeed super helpful for "local" project exclusive libraries one would link from, rather than append from some "centralized" asset library.
I'd rather keep the possibility to use relative paths along with the bug, rather than enforce absolute paths then XD
There are probably more cases in the code where this will cause issues, relative paths are simply not covered. The upcoming indexing (#91406) will also break I think, since it is designed to work with the registered asset libraries, and not with continuously moving targets.
Note that one of the strategical follow-up projects of the Asset Browser is introducing the concept of a project in Blender. A high-priority one I'd say even. This way we want to support per-project asset libraries, and Blender would be able to identify assets as being part of a project.
Ah I see, real shame we can't keep it, but I can see how this is troublesome.
Looking forward for the concept of a Blender project. Being able to define relative paths is pretty useful for flexibility reasons, so stuff doesn't break easily if file paths are changed.
I'm curious,
Edit: Edited the question for clarity, punctuation, etc.
