Both options GPU/CPU checked under preferences cause viewport render crash. (ARM/Metal) #94022
Closed
opened 2021-12-13 16:14:57 +01:00 by Timothy Cook · 28 comments
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 76.3
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-13 12:57, hash: 3f96555123
Worked: N/A
If both option, (GPU/CPU) for render device in the preference option, is checked this will cause a crash for viewport renders only.
Check both option, (GPU/CPU) for render device in the preference option. Try to render in viewport only.
Crash Report:
Translated Report (Full Report Below)
Process:               Blender [2715]
Path:                  /Users/USER/Desktop/*/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               3.1.0 (3.1.0 2021-12-13)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2021-12-13 09:14:17.9996 -0600
OS Version:            macOS 12.1 (21C52)
Report Version:        12
Anonymous UUID:        72CB9E6D-D690-FCFE-9FB8-22D1CAB5A6B1
Time Awake Since Boot: 58000 seconds
System Integrity Protection: enabled
Crashed Thread:        18
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [2715]
VM Region Info: 0 is not in any region.  Bytes before following region: 4365090816
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      1042e0000-10da20000    [151.2M] r-x/r-x SM=COW  ...MacOS/Blender
Kernel Triage:
VM - Fault hit memory shortage
Thread 0:
0   libsystem_kernel.dylib        	       0x1a3cc5990 semaphore_wait_trap + 8
1   libdispatch.dylib             	       0x1a3b4313c _dispatch_sema4_wait + 28
2   libdispatch.dylib             	       0x1a3b437f4 _dispatch_semaphore_wait_slow + 132
3   Blender                       	       0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64
4   Blender                       	       0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64
5   libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
6   libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
0   libsystem_pthread.dylib       	       0x1a3cfc010 start_wqthread + 0
Thread 9:: AMCP Logging Spool
1   caulk                         	       0x1ac6ce8ac caulk::mach::semaphore::wait_or_error() + 28
2   caulk                         	       0x1ac6b165c caulk::concurrent::details::worker_thread::run() + 56
3   caulk                         	       0x1ac6b127c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96
4   libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
5   libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 10:
Thread 11:
Thread 12:
Thread 13:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	       0x1a3cc5954 mach_msg_trap + 8
1   libsystem_kernel.dylib        	       0x1a3cc5d00 mach_msg + 76
2   CoreAudio                     	       0x1a5a07ef0 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 104
3   CoreAudio                     	       0x1a5896e04 HALC_ProxyIOContext::IOWorkLoop() + 3360
4   CoreAudio                     	       0x1a5895ae0 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 100
5   CoreAudio                     	       0x1a5a61420 HALB_IOThread::Entry(void*) + 88
6   libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
7   libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 14::  Dispatch queue: functionsCacheSerialQueue
0   libsystem_kernel.dylib        	       0x1a3cf14d0 fstat + 8
1   libCoreFSCache.dylib          	       0x2050feb08 is_data_file_invalid + 60
2   libCoreFSCache.dylib          	       0x2050ff6a4 fscache_element_get_data + 64
3   Metal                         	       0x1ac5b1164 invocation function for block in MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*) + 140
4   libdispatch.dylib             	       0x1a3b42bac _dispatch_client_callout + 20
5   libdispatch.dylib             	       0x1a3b51e00 _dispatch_lane_barrier_sync_invoke_and_complete + 56
6   Metal                         	       0x1ac591328 MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*) + 308
7   Metal                         	       0x1ac61259c MultiLevelPipelineCache::getElement(MTLUINT256_t const&) const + 188
8   Metal                         	       0x1ac61a008 -[MTLCompiler compileFunctionRequestInternal:frameworkLinking:linkDataSize:reflectionOnly:completionHandler:] + 948
9   AGXMetal13_3                  	       0x2056e9cbc 0x205520000 + 1875132
10  AGXMetal13_3                  	       0x2056e8c34 0x205520000 + 1870900
11  AGXMetal13_3                  	       0x205800024 0x205520000 + 3014692
12  AGXMetal13_3                  	       0x205800dec 0x205520000 + 3018220
13  Metal                         	       0x1ac5b54d8 -[MTLGPUBVHBuilder newPipelineWithKey:] + 864
14  Metal                         	       0x1ac5b55e4 -[MTLGPUBVHBuilder getPipelineWithKey:] + 160
15  Metal                         	       0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784
16  Metal                         	       0x1ac5b7d60 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 708
17  Metal                         	       0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980
18  Metal                         	       0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552
19  Blender                       	       0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924
20  Blender                       	       0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92
21  Blender                       	       0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580
22  Blender                       	       0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060
23  Blender                       	       0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28
24  Blender                       	       0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
25  Blender                       	       0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
26  Blender                       	       0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
27  Blender                       	       0x10487d304 tbb::internal::market::process(rml::job&) + 40
28  Blender                       	       0x10487e5fc tbb::internal::rml::private_worker::run() + 288
29  Blender                       	       0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
30  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
31  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 15:
0   libsystem_kernel.dylib        	       0x1a3cc770c __ulock_wait + 8
1   libsystem_platform.dylib      	       0x1a3d16140 _os_unfair_lock_lock_slow + 228
2   Metal                         	       0x1ac5b557c -[MTLGPUBVHBuilder getPipelineWithKey:] + 56
3   Metal                         	       0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784
4   Metal                         	       0x1ac5b7cc8 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 556
5   Metal                         	       0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980
6   Metal                         	       0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552
7   Blender                       	       0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924
8   Blender                       	       0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92
9   Blender                       	       0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580
10  Blender                       	       0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060
11  Blender                       	       0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28
12  Blender                       	       0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
13  Blender                       	       0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
14  Blender                       	       0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
15  Blender                       	       0x10487d304 tbb::internal::market::process(rml::job&) + 40
16  Blender                       	       0x10487e5fc tbb::internal::rml::private_worker::run() + 288
17  Blender                       	       0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
18  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
19  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 16:
3   Metal                         	       0x1ac5b5a2c -[MTLGPUBVHBuilder getPipeline:] + 56
4   Metal                         	       0x1ac5b6858 -[MTLGPUBVHBuilder setCounterInBuffer:offset:index:value:encoder:] + 80
5   Metal                         	       0x1ac5b8940 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 3748
6   Metal                         	       0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980
7   Metal                         	       0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552
8   Blender                       	       0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924
9   Blender                       	       0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92
10  Blender                       	       0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580
11  Blender                       	       0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060
12  Blender                       	       0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28
13  Blender                       	       0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
14  Blender                       	       0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
15  Blender                       	       0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
16  Blender                       	       0x10487d304 tbb::internal::market::process(rml::job&) + 40
17  Blender                       	       0x10487e5fc tbb::internal::rml::private_worker::run() + 288
18  Blender                       	       0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
19  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
20  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 17:
4   Metal                         	       0x1ac5b70f8 -[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 112
5   Metal                         	       0x1ac5b91b8 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 748
Thread 18 Crashed:
0   Blender                       	       0x1058b2ed8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 308
1   Blender                       	       0x1058b2e84 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 224
10  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
11  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 19:
Thread 20:
0   dyld                          	       0x114f0bc78 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 608
1   dyld                          	       0x114f0bb2c dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 276
2   dyld                          	       0x114ef8ec8 dyld4::APIs::dladdr(void const*, dl_info*) + 200
3   libsystem_c.dylib             	       0x1a3bdaf8c backtrace_symbols + 112
4   Blender                       	       0x10b4efa50 BLI_system_backtrace + 72
5   Blender                       	       0x104423b98 sig_handle_crash + 360
6   libsystem_platform.dylib      	       0x1a3d184e4 _sigtramp + 56
7   Blender                       	       0x1058b2e84 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 224
8   Blender                       	       0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060
9   Blender                       	       0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28
10  Blender                       	       0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440
11  Blender                       	       0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184
12  Blender                       	       0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252
13  Blender                       	       0x10487d304 tbb::internal::market::process(rml::job&) + 40
14  Blender                       	       0x10487e5fc tbb::internal::rml::private_worker::run() + 288
15  Blender                       	       0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12
16  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
17  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 21:
0   libsystem_kernel.dylib        	       0x1a3ccdaa4 __accept + 8
1   _socket.cpython-39-darwin.so  	       0x14f7aa0a4 sock_accept_impl + 32
2   _socket.cpython-39-darwin.so  	       0x14f7aa4b4 sock_call_ex + 492
3   _socket.cpython-39-darwin.so  	       0x14f7a80b4 sock_accept + 120
4   Blender                       	       0x10a3daf1c method_vectorcall_NOARGS + 160
5   Blender                       	       0x10a4a81bc call_function + 416
6   Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
7   Blender                       	       0x10a3d2af4 function_code_fastcall + 112
8   Blender                       	       0x10a4a81bc call_function + 416
9   Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
10  Blender                       	       0x10a3d2af4 function_code_fastcall + 112
11  Blender                       	       0x10a4a81bc call_function + 416
12  Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
13  Blender                       	       0x10a3d2af4 function_code_fastcall + 112
14  Blender                       	       0x10a4a81bc call_function + 416
15  Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
16  Blender                       	       0x10a3d2af4 function_code_fastcall + 112
17  Blender                       	       0x10a3d4acc method_vectorcall + 284
18  Blender                       	       0x10a540180 t_bootstrap + 72
19  Blender                       	       0x10a4f3094 pythread_wrapper + 28
20  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
21  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 22:
0   libsystem_kernel.dylib        	       0x1a3ccfd38 __select + 8
1   Blender                       	       0x10a53d4c4 time_sleep + 128
2   Blender                       	       0x10a414294 cfunction_vectorcall_O + 292
3   Blender                       	       0x10a4a81bc call_function + 416
4   Blender                       	       0x10a4a5834 _PyEval_EvalFrameDefault + 23080
5   Blender                       	       0x10a3d2af4 function_code_fastcall + 112
6   Blender                       	       0x10a4a81bc call_function + 416
7   Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
8   Blender                       	       0x10a3d2af4 function_code_fastcall + 112
9   Blender                       	       0x10a4a81bc call_function + 416
10  Blender                       	       0x10a4a5810 _PyEval_EvalFrameDefault + 23044
11  Blender                       	       0x10a3d2af4 function_code_fastcall + 112
12  Blender                       	       0x10a3d4acc method_vectorcall + 284
13  Blender                       	       0x10a540180 t_bootstrap + 72
14  Blender                       	       0x10a4f3094 pythread_wrapper + 28
15  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
16  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 23:: com.apple.NSEventThread
2   CoreFoundation                	       0x1a3dcced8 __CFRunLoopServiceMachPort + 372
3   CoreFoundation                	       0x1a3dcb390 __CFRunLoopRun + 1212
4   CoreFoundation                	       0x1a3dca734 CFRunLoopRunSpecific + 600
5   AppKit                        	       0x1a6a8dc90 _NSEventThread + 196
Thread 24:
Thread 25:
Thread 26:
Thread 27:
0   dyld                          	       0x114f0bc90 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 632
12  Blender                       	       0x105bb4d2c tbb::internal::task_group_base::wait() + 40
13  Blender                       	       0x108abf9d8 ccl::TaskPool::wait_work(ccl::TaskPool::Summary*) + 24
14  Blender                       	       0x1059ed988 ccl::GeometryManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 3524
15  Blender                       	       0x105a565f8 ccl::Scene::device_update(ccl::Device*, ccl::Progress&) + 1472
16  Blender                       	       0x105a5ac44 ccl::Scene::update(ccl::Progress&) + 164
17  Blender                       	       0x105b01058 ccl::Session::run_update_for_next_iteration() + 1012
18  Blender                       	       0x105b007a8 ccl::Session::run_main_render_loop() + 120
19  Blender                       	       0x105b017d8 ccl::Session::run() + 252
20  Blender                       	       0x108ac0470 ccl::thread::run(void*) + 52
21  libsystem_pthread.dylib       	       0x1a3d01240 _pthread_start + 148
22  libsystem_pthread.dylib       	       0x1a3cfc024 thread_start + 8
Thread 18 crashed with ARM Thread State (64-bit):
    x0: 0x0000000153338800   x1: 0x0000000000000003   x2: 0x0000000000000000   x3: 0x0000000000000005
    x4: 0x0000000042400010   x5: 0x0000000000000000   x6: 0x000000016d816c20   x7: 0x000000016d816b88
    x8: 0x0000000300710ab0   x9: 0x0000000000000000  x10: 0x0000000153338800  x11: 0x0000000000000000
   x12: 0x0000000000000000  x13: 0x00000000ffffffff  x14: 0x00000000db8092f5  x15: 0x000000000000a309
   x16: 0x000000000000a309  x17: 0x0000000040000010  x18: 0x0000000000000000  x19: 0x0000600003c3db00
   x20: 0x0000000000000000  x21: 0x00000002a4c0a010  x22: 0x0000600003c3db80  x23: 0x0000600003c3db50
   x24: 0x0000600003c3db68  x25: 0x0000600003970470  x26: 0x00006000025dcaa0  x27: 0x0000000000000000
   x28: 0x0000600003c3db08   fp: 0x000000016d816b40   lr: 0x00000001058b2e84
    sp: 0x000000016d816a70   pc: 0x00000001058b2ed8 cpsr: 0x20001000
   far: 0x0000000000000000  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x1a3cc4000 -        0x1a3cf9fff libsystem_kernel.dylib (*) <c8b3081a-5081-3a99-bbe3-01413de444c6> /usr/lib/system/libsystem_kernel.dylib
       0x1a3b3f000 -        0x1a3b85fff libdispatch.dylib (*) <3a9e9a1e-72b6-3f66-aa17-d955384c1a39> /usr/lib/system/libdispatch.dylib
       0x1042e0000 -        0x10da1ffff org.blenderfoundation.blender (3.1.0) <498eab2f-987c-30aa-ba13-8c1c2cf99c7e> /Users/USER/Desktop/*/Blender.app/Contents/MacOS/Blender
       0x1a3cfa000 -        0x1a3d06fff libsystem_pthread.dylib (*) <ed328b18-eeef-3b15-8858-798b19b0c2cd> /usr/lib/system/libsystem_pthread.dylib
       0x1ac6af000 -        0x1ac6d6fff com.apple.audio.caulk (1.0) <37a561f9-46f0-37fe-811b-894385645aed> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x1a56ce000 -        0x1a5dfcfff com.apple.audio.CoreAudio (5.0) <fb9c653d-bcad-308b-981b-f2c56c8c17c5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x2050fc000 -        0x205102fff libCoreFSCache.dylib (*) <ee08ff54-c00a-3c6d-a77f-1136383e8963> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
       0x1ac575000 -        0x1ac6aefff com.apple.Metal (258.17) <970fae8e-1769-3816-badf-2b75ec9a9385> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
       0x205520000 -        0x205a33fff com.apple.AGXMetal13-3 (187.59) <1bf04df7-1d70-32e4-a26c-91b3bf4ec942> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
       0x1a3d14000 -        0x1a3d1bfff libsystem_platform.dylib (*) <ef6555f4-7a8e-3e51-9b40-5381482dee4d> /usr/lib/system/libsystem_platform.dylib
       0x114ed4000 -        0x114f33fff dyld (*) <7e92b284-4b90-3b68-b31a-3ddc4c0e8d40> /usr/lib/dyld
       0x1a3bc5000 -        0x1a3c45fff libsystem_c.dylib (*) <00fc01c7-36bc-3193-86a3-5c03046b45fb> /usr/lib/system/libsystem_c.dylib
       0x14f7a4000 -        0x14f7b3fff _socket.cpython-39-darwin.so (*) <994eed94-a9fe-3bce-88ab-4ea5710e5de9> /Users/USER/Desktop/*/Blender.app/Contents/Resources/3.1/python/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
       0x1a3d48000 -        0x1a428bfff com.apple.CoreFoundation (6.9) <f5ea9592-4ef9-3d35-b23d-5c21283acc52> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x1a68df000 -        0x1a7792fff com.apple.AppKit (6.9) <a8bbc643-113d-310f-96b6-77a973bf2dba> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=11.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=11.7G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               640K        5
Activity Tracing                   256K        1
CG backing stores                 2880K        4
CG image                          1296K       12
ColorSync                          528K       25
CoreAnimation                      320K       11
CoreGraphics                        32K        2
CoreImage                           16K        1
CoreUI image data                 1056K        8
Foundation                          16K        1
IOAccelerator                      3.1G      206
IOKit                              352K       22
IOSurface                        122.3M        5
Kernel Alloc Once                   32K        1
MALLOC                             7.5G      462
MALLOC guard page                  192K        9
MALLOC_MEDIUM (reserved)         352.0M        8         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                        448K       28
Stack                             88.4M       29
Stack Guard                         16K        1
VM_ALLOCATE                      214.4M      815
VM_ALLOCATE (reserved)           128.0M        1         reserved VM address space (unallocated)
__AUTH                            1881K      177
__AUTH_CONST                      10.4M      332
__DATA                            70.7M      366
__DATA_CONST                      18.3M      377
__DATA_DIRTY                       879K      119
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       629.2M       47
__OBJC_CONST                      1770K      149
__OBJC_RO                         82.0M        1
__OBJC_RW                         3104K        1
__TEXT                           405.7M      393
__UNICODE                          588K        1
dyld private memory               1024K        1
mapped file                      222.7M       88
shared memory                      928K       13
TOTAL                             13.1G     3728
TOTAL, minus reserved VM space    12.4G     3728
Full Report
{"app_name":"Blender","timestamp":"2021-12-13 09:14:18.00 -0600","app_version":"3.1.0","slice_uuid":"498eab2f-987c-30aa-ba13-8c1c2cf99c7e","build_version":"3.1.0 2021-12-13","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"72472D20-7A5D-483F-91EE-9D0C48B4DCC8","name":"Blender"}
  "uptime" : 58000,
  "procLaunch" : "2021-12-13 09:08:56.3539 -0600",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "Macmini9,1",
  "procStartAbsTime" : 1394230362821,
  "coalitionID" : 2497,
  "osVersion" : {
    "train" : "macOS 12.1",
    "build" : "21C52",
    "releaseType" : "User"
  "captureTime" : "2021-12-13 09:14:17.9996 -0600",
  "incident" : "72472D20-7A5D-483F-91EE-9D0C48B4DCC8",
  "bug_type" : "309",
  "pid" : 2715,
  "procExitAbsTime" : 1401948528696,
  "translated" : false,
  "cpuType" : "ARM-64",
  "procName" : "Blender",
  "procPath" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/MacOS\/Blender",
  "bundleInfo" : {"CFBundleShortVersionString":"3.1.0","CFBundleVersion":"3.1.0 2021-12-13","CFBundleIdentifier":"org.blenderfoundation.blender"},
  "storeInfo" : {"deviceIdentifierForVendor":"4680F7E3-F771-54C7-A8DA-0554CE618F11","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "org.blenderfoundation.blender",
  "crashReporterKey" : "72CB9E6D-D690-FCFE-9FB8-22D1CAB5A6B1",
  "sip" : "enabled",
  "vmRegionInfo" : "0 is not in any region.  Bytes before following region: 4365090816\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1042e0000-10da20000    [151.2M] r-x\/r-x SM=COW  ...MacOS\/Blender",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2715},
  "ktriageinfo" : "VM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\n",
  "vmregioninfo" : "0 is not in any region.  Bytes before following region: 4365090816\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1042e0000-10da20000    [151.2M] r-x\/r-x SM=COW  ...MacOS\/Blender",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 18,
  "threads" : [{"id":259880,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259881,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259882,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259883,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259884,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259885,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259886,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259887,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259888,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259890,"name":"AMCP Logging Spool","frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":129196,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":28,"imageIndex":4},{"imageOffset":9820,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":56,"imageIndex":4},{"imageOffset":8828,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":96,"imageIndex":4},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259907,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259910,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259911,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259915,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":0},{"imageOffset":3383024,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":104,"imageIndex":5},{"imageOffset":1871364,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3360,"imageIndex":5},{"imageOffset":1866464,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":100,"imageIndex":5},{"imageOffset":3748896,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":88,"imageIndex":5},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259942,"queue":"functionsCacheSerialQueue","frames":[{"imageOffset":185552,"symbol":"fstat","symbolLocation":8,"imageIndex":0},{"imageOffset":11016,"symbol":"is_data_file_invalid","symbolLocation":60,"imageIndex":6},{"imageOffset":13988,"symbol":"fscache_element_get_data","symbolLocation":64,"imageIndex":6},{"imageOffset":246116,"symbol":"invocation function for block in MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*)","symbolLocation":140,"imageIndex":7},{"imageOffset":15276,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":1},{"imageOffset":77312,"symbol":"_dispatch_lane_barrier_sync_invoke_and_complete","symbolLocation":56,"imageIndex":1},{"imageOffset":115496,"symbol":"MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*)","symbolLocation":308,"imageIndex":7},{"imageOffset":644508,"symbol":"MultiLevelPipelineCache::getElement(MTLUINT256_t const&) const","symbolLocation":188,"imageIndex":7},{"imageOffset":675848,"symbol":"-[MTLCompiler compileFunctionRequestInternal:frameworkLinking:linkDataSize:reflectionOnly:completionHandler:]","symbolLocation":948,"imageIndex":7},{"imageOffset":1875132,"imageIndex":8},{"imageOffset":1870900,"imageIndex":8},{"imageOffset":3014692,"imageIndex":8},{"imageOffset":3018220,"imageIndex":8},{"imageOffset":263384,"symbol":"-[MTLGPUBVHBuilder newPipelineWithKey:]","symbolLocation":864,"imageIndex":7},{"imageOffset":263652,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":160,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":273760,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":708,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259943,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":273608,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":556,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259944,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264748,"symbol":"-[MTLGPUBVHBuilder getPipeline:]","symbolLocation":56,"imageIndex":7},{"imageOffset":268376,"symbol":"-[MTLGPUBVHBuilder setCounterInBuffer:offset:index:value:encoder:]","symbolLocation":80,"imageIndex":7},{"imageOffset":276800,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":3748,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259945,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":270584,"symbol":"-[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":112,"imageIndex":7},{"imageOffset":278968,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":748,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"triggered":true,"id":259946,"threadState":{"x":[{"value":5690853376},{"value":3},{"value":0},{"value":5},{"value":1111490576},{"value":0},{"value":6132165664},{"value":6132165512},{"value":12892310192},{"value":0},{"value":5690853376},{"value":0},{"value":0},{"value":4294967295},{"value":3682636533},{"value":41737},{"value":41737},{"value":1073741840},{"value":0},{"value":105553179433728},{"value":0},{"value":11354021904},{"value":105553179433856},{"value":105553179433808},{"value":105553179433832},{"value":105553176495216},{"value":105553155967648},{"value":0},{"value":105553179433736}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4387974788},"cpsr":{"value":536875008},"fp":{"value":6132165440},"sp":{"value":6132165232},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4387974872,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":22884056,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":308,"imageIndex":2},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259947,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":270584,"symbol":"-[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":112,"imageIndex":7},{"imageOffset":278968,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":748,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259948,"frames":[{"imageOffset":228472,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":608,"imageIndex":10},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":10},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":10},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":11},{"imageOffset":119601744,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":2},{"imageOffset":1325976,"symbol":"sig_handle_crash","symbolLocation":360,"imageIndex":2},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":9},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259950,"frames":[{"imageOffset":39588,"symbol":"__accept","symbolLocation":8,"imageIndex":0},{"imageOffset":24740,"symbol":"sock_accept_impl","symbolLocation":32,"imageIndex":12},{"imageOffset":25780,"symbol":"sock_call_ex","symbolLocation":492,"imageIndex":12},{"imageOffset":16564,"symbol":"sock_accept","symbolLocation":120,"imageIndex":12},{"imageOffset":101691164,"symbol":"method_vectorcall_NOARGS","symbolLocation":160,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259951,"frames":[{"imageOffset":48440,"symbol":"__select","symbolLocation":8,"imageIndex":0},{"imageOffset":103142596,"symbol":"time_sleep","symbolLocation":128,"imageIndex":2},{"imageOffset":101925524,"symbol":"cfunction_vectorcall_O","symbolLocation":292,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520884,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23080,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259969,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":0},{"imageOffset":544472,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":372,"imageIndex":13},{"imageOffset":537488,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":13},{"imageOffset":534324,"symbol":"CFRunLoopRunSpecific","symbolLocation":600,"imageIndex":13},{"imageOffset":1764496,"symbol":"_NSEventThread","symbolLocation":196,"imageIndex":14},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":262047,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":262203,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":262324,"frames":[{"imageOffset":48440,"symbol":"__select","symbolLocation":8,"imageIndex":0},{"imageOffset":103142596,"symbol":"time_sleep","symbolLocation":128,"imageIndex":2},{"imageOffset":101925524,"symbol":"cfunction_vectorcall_O","symbolLocation":292,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520884,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23080,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":262439,"frames":[{"imageOffset":228496,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":632,"imageIndex":10},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":10},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":10},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":11},{"imageOffset":119601744,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":2},{"imageOffset":1325976,"symbol":"sig_handle_crash","symbolLocation":360,"imageIndex":2},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":9},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":26037548,"symbol":"tbb::internal::task_group_base::wait()","symbolLocation":40,"imageIndex":2},{"imageOffset":75364824,"symbol":"ccl::TaskPool::wait_work(ccl::TaskPool::Summary*)","symbolLocation":24,"imageIndex":2},{"imageOffset":24172936,"symbol":"ccl::GeometryManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&)","symbolLocation":3524,"imageIndex":2},{"imageOffset":24602104,"symbol":"ccl::Scene::device_update(ccl::Device*, ccl::Progress&)","symbolLocation":1472,"imageIndex":2},{"imageOffset":24620100,"symbol":"ccl::Scene::update(ccl::Progress&)","symbolLocation":164,"imageIndex":2},{"imageOffset":25301080,"symbol":"ccl::Session::run_update_for_next_iteration()","symbolLocation":1012,"imageIndex":2},{"imageOffset":25298856,"symbol":"ccl::Session::run_main_render_loop()","symbolLocation":120,"imageIndex":2},{"imageOffset":25303000,"symbol":"ccl::Session::run()","symbolLocation":252,"imageIndex":2},{"imageOffset":75367536,"symbol":"ccl::thread::run(void*)","symbolLocation":52,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7043039232,
    "size" : 221184,
    "uuid" : "c8b3081a-5081-3a99-bbe3-01413de444c6",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7041445888,
    "size" : 290816,
    "uuid" : "3a9e9a1e-72b6-3f66-aa17-d955384c1a39",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4365090816,
    "CFBundleShortVersionString" : "3.1.0",
    "CFBundleIdentifier" : "org.blenderfoundation.blender",
    "size" : 158597120,
    "uuid" : "498eab2f-987c-30aa-ba13-8c1c2cf99c7e",
    "path" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/MacOS\/Blender",
    "name" : "Blender",
    "CFBundleVersion" : "3.1.0 2021-12-13"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7043260416,
    "size" : 53248,
    "uuid" : "ed328b18-eeef-3b15-8858-798b19b0c2cd",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7187656704,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 163840,
    "uuid" : "37a561f9-46f0-37fe-811b-894385645aed",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7070343168,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7532544,
    "uuid" : "fb9c653d-bcad-308b-981b-f2c56c8c17c5",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8674852864,
    "size" : 28672,
    "uuid" : "ee08ff54-c00a-3c6d-a77f-1136383e8963",
    "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Libraries\/libCoreFSCache.dylib",
    "name" : "libCoreFSCache.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7186370560,
    "CFBundleShortVersionString" : "258.17",
    "CFBundleIdentifier" : "com.apple.Metal",
    "size" : 1286144,
    "uuid" : "970fae8e-1769-3816-badf-2b75ec9a9385",
    "path" : "\/System\/Library\/Frameworks\/Metal.framework\/Versions\/A\/Metal",
    "name" : "Metal",
    "CFBundleVersion" : "258.17"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8679194624,
    "CFBundleShortVersionString" : "187.59",
    "CFBundleIdentifier" : "com.apple.AGXMetal13-3",
    "size" : 5324800,
    "uuid" : "1bf04df7-1d70-32e4-a26c-91b3bf4ec942",
    "path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3",
    "name" : "AGXMetal13_3",
    "CFBundleVersion" : "187.59"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7043366912,
    "size" : 32768,
    "uuid" : "ef6555f4-7a8e-3e51-9b40-5381482dee4d",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4646060032,
    "size" : 393216,
    "uuid" : "7e92b284-4b90-3b68-b31a-3ddc4c0e8d40",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7041994752,
    "size" : 528384,
    "uuid" : "00fc01c7-36bc-3193-86a3-5c03046b45fb",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 5628379136,
    "size" : 65536,
    "uuid" : "994eed94-a9fe-3bce-88ab-4ea5710e5de9",
    "path" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/Resources\/3.1\/python\/lib\/python3.9\/lib-dynload\/_socket.cpython-39-darwin.so",
    "name" : "_socket.cpython-39-darwin.so"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7043579904,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5521408,
    "uuid" : "f5ea9592-4ef9-3d35-b23d-5c21283acc52",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1856.105"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7089287168,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15417344,
    "uuid" : "a8bbc643-113d-310f-96b6-77a973bf2dba",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.20.111"
  "sharedCache" : {
  "base" : 7040090112,
  "size" : 3089596416,
  "uuid" : "66c33c62-48a9-31e5-b8b5-7a71c9760d07"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=11.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=11.7G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               640K        5 \nActivity Tracing                   256K        1 \nCG backing stores                 2880K        4 \nCG image                          1296K       12 \nColorSync                          528K       25 \nCoreAnimation                      320K       11 \nCoreGraphics                        32K        2 \nCoreImage                           16K        1 \nCoreUI image data                 1056K        8 \nFoundation                          16K        1 \nIOAccelerator                      3.1G      206 \nIOKit                              352K       22 \nIOSurface                        122.3M        5 \nKernel Alloc Once                   32K        1 \nMALLOC                             7.5G      462 \nMALLOC guard page                  192K        9 \nMALLOC_MEDIUM (reserved)         352.0M        8         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                        448K       28 \nStack                             88.4M       29 \nStack Guard                         16K        1 \nVM_ALLOCATE                      214.4M      815 \nVM_ALLOCATE (reserved)           128.0M        1         reserved VM address space (unallocated)\n__AUTH                            1881K      177 \n__AUTH_CONST                      10.4M      332 \n__DATA                            70.7M      366 \n__DATA_CONST                      18.3M      377 \n__DATA_DIRTY                       879K      119 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       629.2M       47 \n__OBJC_CONST                      1770K      149 \n__OBJC_RO                         82.0M        1 \n__OBJC_RW                         3104K        1 \n__TEXT                           405.7M      393 \n__UNICODE                          588K        1 \ndyld private memory               1024K        1 \nmapped file                      222.7M       88 \nshared memory                      928K       13 \n===========                     =======  ======= \nTOTAL                             13.1G     3728 \nTOTAL, minus reserved VM space    12.4G     3728 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "601d9415f79519000ccd4b69",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "6193e7ae2171a2330e561ea2"
      "deploymentId" : 250000320
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 250000063
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 250000007
      "rolloutId" : "60356660bbe37970735c5624",
      "factorPackIds" : {
      "deploymentId" : 250000016
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "60ef663fa2f864203caf575c"
      "deploymentId" : 250000055
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 250000172
      "rolloutId" : "602ad4dac86151000cf27e46",
      "factorPackIds" : {
        "SIRI_DICTATION_ASSETS" : "61a7b71b37dce5558831d479"
      "deploymentId" : 250000288
  "experiments" : [
Model: Macmini9,1, BootROM 7429.61.2, proc 8:4:4 processors, 16 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: LG HDR 4K, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Memory Module: LPDDR4
AirPort: Wi-Fi, wl0: Oct 26 2021 16:10:41 version 18.20.310.15.7.8.120 FWID 01-5d6c3867
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
USB Device: USB31Bus
USB Device: Portable SSD T5
USB Device: USB30Bus
USB Device: USB Receiver
USB Device: Razer Tartarus V2
Thunderbolt Bus: Mac mini, Apple Inc.
**System Information** Operating system: macOS-12.1-arm64-arm-64bit 64 Bits Graphics card: Apple M1 Apple 4.1 Metal - 76.3 **Blender Version** Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-13 12:57, hash: `3f96555123` Worked: N/A **Short description of error** If both option, (GPU/CPU) for render device in the preference option, is checked this will cause a crash for viewport renders only. **Exact steps for others to reproduce the error** Check both option, (GPU/CPU) for render device in the preference option. Try to render in viewport only. Crash Report: ```lines=10 ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: Blender [2715] Path: /Users/USER/Desktop/*/Blender.app/Contents/MacOS/Blender Identifier: org.blenderfoundation.blender Version: 3.1.0 (3.1.0 2021-12-13) Code Type: ARM-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2021-12-13 09:14:17.9996 -0600 OS Version: macOS 12.1 (21C52) Report Version: 12 Anonymous UUID: 72CB9E6D-D690-FCFE-9FB8-22D1CAB5A6B1 Time Awake Since Boot: 58000 seconds System Integrity Protection: enabled Crashed Thread: 18 Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Codes: 0x0000000000000001, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process: exc handler [2715] VM Region Info: 0 is not in any region. Bytes before following region: 4365090816 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL UNUSED SPACE AT START ---> __TEXT 1042e0000-10da20000 [151.2M] r-x/r-x SM=COW ...MacOS/Blender Kernel Triage: VM - Fault hit memory shortage VM - Fault hit memory shortage VM - Fault hit memory shortage VM - Fault hit memory shortage VM - Fault hit memory shortage Thread 0: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 1: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 2: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 3: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 4: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 5: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 6: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 7: 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 libdispatch.dylib 0x1a3b4313c _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x1a3b437f4 _dispatch_semaphore_wait_slow + 132 3 Blender 0x109d315c0 IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 Blender 0x109d301c8 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 6 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 8: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 9:: AMCP Logging Spool 0 libsystem_kernel.dylib 0x1a3cc5990 semaphore_wait_trap + 8 1 caulk 0x1ac6ce8ac caulk::mach::semaphore::wait_or_error() + 28 2 caulk 0x1ac6b165c caulk::concurrent::details::worker_thread::run() + 56 3 caulk 0x1ac6b127c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96 4 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 5 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 10: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 11: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 12: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 13:: com.apple.audio.IOThread.client 0 libsystem_kernel.dylib 0x1a3cc5954 mach_msg_trap + 8 1 libsystem_kernel.dylib 0x1a3cc5d00 mach_msg + 76 2 CoreAudio 0x1a5a07ef0 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 104 3 CoreAudio 0x1a5896e04 HALC_ProxyIOContext::IOWorkLoop() + 3360 4 CoreAudio 0x1a5895ae0 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 100 5 CoreAudio 0x1a5a61420 HALB_IOThread::Entry(void*) + 88 6 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 7 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 14:: Dispatch queue: functionsCacheSerialQueue 0 libsystem_kernel.dylib 0x1a3cf14d0 fstat + 8 1 libCoreFSCache.dylib 0x2050feb08 is_data_file_invalid + 60 2 libCoreFSCache.dylib 0x2050ff6a4 fscache_element_get_data + 64 3 Metal 0x1ac5b1164 invocation function for block in MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*) + 140 4 libdispatch.dylib 0x1a3b42bac _dispatch_client_callout + 20 5 libdispatch.dylib 0x1a3b51e00 _dispatch_lane_barrier_sync_invoke_and_complete + 56 6 Metal 0x1ac591328 MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*) + 308 7 Metal 0x1ac61259c MultiLevelPipelineCache::getElement(MTLUINT256_t const&) const + 188 8 Metal 0x1ac61a008 -[MTLCompiler compileFunctionRequestInternal:frameworkLinking:linkDataSize:reflectionOnly:completionHandler:] + 948 9 AGXMetal13_3 0x2056e9cbc 0x205520000 + 1875132 10 AGXMetal13_3 0x2056e8c34 0x205520000 + 1870900 11 AGXMetal13_3 0x205800024 0x205520000 + 3014692 12 AGXMetal13_3 0x205800dec 0x205520000 + 3018220 13 Metal 0x1ac5b54d8 -[MTLGPUBVHBuilder newPipelineWithKey:] + 864 14 Metal 0x1ac5b55e4 -[MTLGPUBVHBuilder getPipelineWithKey:] + 160 15 Metal 0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784 16 Metal 0x1ac5b7d60 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 708 17 Metal 0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980 18 Metal 0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552 19 Blender 0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924 20 Blender 0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92 21 Blender 0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580 22 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 23 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 24 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 25 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 26 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 27 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 28 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 29 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 30 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 31 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 15: 0 libsystem_kernel.dylib 0x1a3cc770c __ulock_wait + 8 1 libsystem_platform.dylib 0x1a3d16140 _os_unfair_lock_lock_slow + 228 2 Metal 0x1ac5b557c -[MTLGPUBVHBuilder getPipelineWithKey:] + 56 3 Metal 0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784 4 Metal 0x1ac5b7cc8 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 556 5 Metal 0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980 6 Metal 0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552 7 Blender 0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924 8 Blender 0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92 9 Blender 0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580 10 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 11 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 12 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 13 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 14 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 15 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 16 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 17 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 18 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 19 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 16: 0 libsystem_kernel.dylib 0x1a3cc770c __ulock_wait + 8 1 libsystem_platform.dylib 0x1a3d16140 _os_unfair_lock_lock_slow + 228 2 Metal 0x1ac5b557c -[MTLGPUBVHBuilder getPipelineWithKey:] + 56 3 Metal 0x1ac5b5a2c -[MTLGPUBVHBuilder getPipeline:] + 56 4 Metal 0x1ac5b6858 -[MTLGPUBVHBuilder setCounterInBuffer:offset:index:value:encoder:] + 80 5 Metal 0x1ac5b8940 -[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 3748 6 Metal 0x1ac5b92a0 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 980 7 Metal 0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552 8 Blender 0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924 9 Blender 0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92 10 Blender 0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580 11 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 12 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 13 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 14 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 15 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 16 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 17 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 18 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 19 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 20 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 17: 0 libsystem_kernel.dylib 0x1a3cc770c __ulock_wait + 8 1 libsystem_platform.dylib 0x1a3d16140 _os_unfair_lock_lock_slow + 228 2 Metal 0x1ac5b557c -[MTLGPUBVHBuilder getPipelineWithKey:] + 56 3 Metal 0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784 4 Metal 0x1ac5b70f8 -[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 112 5 Metal 0x1ac5b91b8 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 748 6 Metal 0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552 7 Blender 0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924 8 Blender 0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92 9 Blender 0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580 10 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 11 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 12 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 13 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 14 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 15 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 16 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 17 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 18 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 19 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 18 Crashed: 0 Blender 0x1058b2ed8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 308 1 Blender 0x1058b2e84 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 224 2 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 3 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 4 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 5 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 6 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 7 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 8 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 9 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 10 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 11 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 19: 0 libsystem_kernel.dylib 0x1a3cc770c __ulock_wait + 8 1 libsystem_platform.dylib 0x1a3d16140 _os_unfair_lock_lock_slow + 228 2 Metal 0x1ac5b557c -[MTLGPUBVHBuilder getPipelineWithKey:] + 56 3 Metal 0x1ac5b59cc -[MTLGPUBVHBuilder getPipeline:descriptor:] + 784 4 Metal 0x1ac5b70f8 -[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:] + 112 5 Metal 0x1ac5b91b8 -[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:] + 748 6 Metal 0x1ac5ffe1c -[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:] + 552 7 Blender 0x1058b50b0 ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool) + 1924 8 Blender 0x1058bc2dc ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 92 9 Blender 0x1058b2fe8 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 580 10 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 11 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 12 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 13 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 14 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 15 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 16 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 17 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 18 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 19 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 20: 0 dyld 0x114f0bc78 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 608 1 dyld 0x114f0bb2c dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 276 2 dyld 0x114ef8ec8 dyld4::APIs::dladdr(void const*, dl_info*) + 200 3 libsystem_c.dylib 0x1a3bdaf8c backtrace_symbols + 112 4 Blender 0x10b4efa50 BLI_system_backtrace + 72 5 Blender 0x104423b98 sig_handle_crash + 360 6 libsystem_platform.dylib 0x1a3d184e4 _sigtramp + 56 7 Blender 0x1058b2e84 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 224 8 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 9 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 10 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 11 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 12 Blender 0x10487424c tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 252 13 Blender 0x10487d304 tbb::internal::market::process(rml::job&) + 40 14 Blender 0x10487e5fc tbb::internal::rml::private_worker::run() + 288 15 Blender 0x10487e4d0 tbb::internal::rml::private_worker::thread_routine(void*) + 12 16 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 17 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 21: 0 libsystem_kernel.dylib 0x1a3ccdaa4 __accept + 8 1 _socket.cpython-39-darwin.so 0x14f7aa0a4 sock_accept_impl + 32 2 _socket.cpython-39-darwin.so 0x14f7aa4b4 sock_call_ex + 492 3 _socket.cpython-39-darwin.so 0x14f7a80b4 sock_accept + 120 4 Blender 0x10a3daf1c method_vectorcall_NOARGS + 160 5 Blender 0x10a4a81bc call_function + 416 6 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 7 Blender 0x10a3d2af4 function_code_fastcall + 112 8 Blender 0x10a4a81bc call_function + 416 9 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 10 Blender 0x10a3d2af4 function_code_fastcall + 112 11 Blender 0x10a4a81bc call_function + 416 12 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 13 Blender 0x10a3d2af4 function_code_fastcall + 112 14 Blender 0x10a4a81bc call_function + 416 15 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 16 Blender 0x10a3d2af4 function_code_fastcall + 112 17 Blender 0x10a3d4acc method_vectorcall + 284 18 Blender 0x10a540180 t_bootstrap + 72 19 Blender 0x10a4f3094 pythread_wrapper + 28 20 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 21 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 22: 0 libsystem_kernel.dylib 0x1a3ccfd38 __select + 8 1 Blender 0x10a53d4c4 time_sleep + 128 2 Blender 0x10a414294 cfunction_vectorcall_O + 292 3 Blender 0x10a4a81bc call_function + 416 4 Blender 0x10a4a5834 _PyEval_EvalFrameDefault + 23080 5 Blender 0x10a3d2af4 function_code_fastcall + 112 6 Blender 0x10a4a81bc call_function + 416 7 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 8 Blender 0x10a3d2af4 function_code_fastcall + 112 9 Blender 0x10a4a81bc call_function + 416 10 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 11 Blender 0x10a3d2af4 function_code_fastcall + 112 12 Blender 0x10a3d4acc method_vectorcall + 284 13 Blender 0x10a540180 t_bootstrap + 72 14 Blender 0x10a4f3094 pythread_wrapper + 28 15 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 16 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 23:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x1a3cc5954 mach_msg_trap + 8 1 libsystem_kernel.dylib 0x1a3cc5d00 mach_msg + 76 2 CoreFoundation 0x1a3dcced8 __CFRunLoopServiceMachPort + 372 3 CoreFoundation 0x1a3dcb390 __CFRunLoopRun + 1212 4 CoreFoundation 0x1a3dca734 CFRunLoopRunSpecific + 600 5 AppKit 0x1a6a8dc90 _NSEventThread + 196 6 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 7 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 24: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 25: 0 libsystem_pthread.dylib 0x1a3cfc010 start_wqthread + 0 Thread 26: 0 libsystem_kernel.dylib 0x1a3ccfd38 __select + 8 1 Blender 0x10a53d4c4 time_sleep + 128 2 Blender 0x10a414294 cfunction_vectorcall_O + 292 3 Blender 0x10a4a81bc call_function + 416 4 Blender 0x10a4a5834 _PyEval_EvalFrameDefault + 23080 5 Blender 0x10a3d2af4 function_code_fastcall + 112 6 Blender 0x10a4a81bc call_function + 416 7 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 8 Blender 0x10a3d2af4 function_code_fastcall + 112 9 Blender 0x10a4a81bc call_function + 416 10 Blender 0x10a4a5810 _PyEval_EvalFrameDefault + 23044 11 Blender 0x10a3d2af4 function_code_fastcall + 112 12 Blender 0x10a3d4acc method_vectorcall + 284 13 Blender 0x10a540180 t_bootstrap + 72 14 Blender 0x10a4f3094 pythread_wrapper + 28 15 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 16 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 27: 0 dyld 0x114f0bc90 dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 632 1 dyld 0x114f0bb2c dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const + 276 2 dyld 0x114ef8ec8 dyld4::APIs::dladdr(void const*, dl_info*) + 200 3 libsystem_c.dylib 0x1a3bdaf8c backtrace_symbols + 112 4 Blender 0x10b4efa50 BLI_system_backtrace + 72 5 Blender 0x104423b98 sig_handle_crash + 360 6 libsystem_platform.dylib 0x1a3d184e4 _sigtramp + 56 7 Blender 0x1058b2e84 ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool) + 224 8 Blender 0x1059e5454 ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int) + 1060 9 Blender 0x108abf9b0 tbb::internal::function_task<std::__1::function<void ()> >::execute() + 28 10 Blender 0x1048844fc tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) + 440 11 Blender 0x104883bac tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 184 12 Blender 0x105bb4d2c tbb::internal::task_group_base::wait() + 40 13 Blender 0x108abf9d8 ccl::TaskPool::wait_work(ccl::TaskPool::Summary*) + 24 14 Blender 0x1059ed988 ccl::GeometryManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 3524 15 Blender 0x105a565f8 ccl::Scene::device_update(ccl::Device*, ccl::Progress&) + 1472 16 Blender 0x105a5ac44 ccl::Scene::update(ccl::Progress&) + 164 17 Blender 0x105b01058 ccl::Session::run_update_for_next_iteration() + 1012 18 Blender 0x105b007a8 ccl::Session::run_main_render_loop() + 120 19 Blender 0x105b017d8 ccl::Session::run() + 252 20 Blender 0x108ac0470 ccl::thread::run(void*) + 52 21 libsystem_pthread.dylib 0x1a3d01240 _pthread_start + 148 22 libsystem_pthread.dylib 0x1a3cfc024 thread_start + 8 Thread 18 crashed with ARM Thread State (64-bit): x0: 0x0000000153338800 x1: 0x0000000000000003 x2: 0x0000000000000000 x3: 0x0000000000000005 x4: 0x0000000042400010 x5: 0x0000000000000000 x6: 0x000000016d816c20 x7: 0x000000016d816b88 x8: 0x0000000300710ab0 x9: 0x0000000000000000 x10: 0x0000000153338800 x11: 0x0000000000000000 x12: 0x0000000000000000 x13: 0x00000000ffffffff x14: 0x00000000db8092f5 x15: 0x000000000000a309 x16: 0x000000000000a309 x17: 0x0000000040000010 x18: 0x0000000000000000 x19: 0x0000600003c3db00 x20: 0x0000000000000000 x21: 0x00000002a4c0a010 x22: 0x0000600003c3db80 x23: 0x0000600003c3db50 x24: 0x0000600003c3db68 x25: 0x0000600003970470 x26: 0x00006000025dcaa0 x27: 0x0000000000000000 x28: 0x0000600003c3db08 fp: 0x000000016d816b40 lr: 0x00000001058b2e84 sp: 0x000000016d816a70 pc: 0x00000001058b2ed8 cpsr: 0x20001000 far: 0x0000000000000000 esr: 0x92000006 (Data Abort) byte read Translation fault Binary Images: 0x1a3cc4000 - 0x1a3cf9fff libsystem_kernel.dylib (*) <c8b3081a-5081-3a99-bbe3-01413de444c6> /usr/lib/system/libsystem_kernel.dylib 0x1a3b3f000 - 0x1a3b85fff libdispatch.dylib (*) <3a9e9a1e-72b6-3f66-aa17-d955384c1a39> /usr/lib/system/libdispatch.dylib 0x1042e0000 - 0x10da1ffff org.blenderfoundation.blender (3.1.0) <498eab2f-987c-30aa-ba13-8c1c2cf99c7e> /Users/USER/Desktop/*/Blender.app/Contents/MacOS/Blender 0x1a3cfa000 - 0x1a3d06fff libsystem_pthread.dylib (*) <ed328b18-eeef-3b15-8858-798b19b0c2cd> /usr/lib/system/libsystem_pthread.dylib 0x1ac6af000 - 0x1ac6d6fff com.apple.audio.caulk (1.0) <37a561f9-46f0-37fe-811b-894385645aed> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk 0x1a56ce000 - 0x1a5dfcfff com.apple.audio.CoreAudio (5.0) <fb9c653d-bcad-308b-981b-f2c56c8c17c5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x2050fc000 - 0x205102fff libCoreFSCache.dylib (*) <ee08ff54-c00a-3c6d-a77f-1136383e8963> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x1ac575000 - 0x1ac6aefff com.apple.Metal (258.17) <970fae8e-1769-3816-badf-2b75ec9a9385> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x205520000 - 0x205a33fff com.apple.AGXMetal13-3 (187.59) <1bf04df7-1d70-32e4-a26c-91b3bf4ec942> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3 0x1a3d14000 - 0x1a3d1bfff libsystem_platform.dylib (*) <ef6555f4-7a8e-3e51-9b40-5381482dee4d> /usr/lib/system/libsystem_platform.dylib 0x114ed4000 - 0x114f33fff dyld (*) <7e92b284-4b90-3b68-b31a-3ddc4c0e8d40> /usr/lib/dyld 0x1a3bc5000 - 0x1a3c45fff libsystem_c.dylib (*) <00fc01c7-36bc-3193-86a3-5c03046b45fb> /usr/lib/system/libsystem_c.dylib 0x14f7a4000 - 0x14f7b3fff _socket.cpython-39-darwin.so (*) <994eed94-a9fe-3bce-88ab-4ea5710e5de9> /Users/USER/Desktop/*/Blender.app/Contents/Resources/3.1/python/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so 0x1a3d48000 - 0x1a428bfff com.apple.CoreFoundation (6.9) <f5ea9592-4ef9-3d35-b23d-5c21283acc52> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x1a68df000 - 0x1a7792fff com.apple.AppKit (6.9) <a8bbc643-113d-310f-96b6-77a973bf2dba> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 0 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%) Writable regions: Total=11.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=11.7G(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 640K 5 Activity Tracing 256K 1 CG backing stores 2880K 4 CG image 1296K 12 ColorSync 528K 25 CoreAnimation 320K 11 CoreGraphics 32K 2 CoreImage 16K 1 CoreUI image data 1056K 8 Foundation 16K 1 IOAccelerator 3.1G 206 IOKit 352K 22 IOSurface 122.3M 5 Kernel Alloc Once 32K 1 MALLOC 7.5G 462 MALLOC guard page 192K 9 MALLOC_MEDIUM (reserved) 352.0M 8 reserved VM address space (unallocated) MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated) OpenGL GLSL 256K 3 STACK GUARD 448K 28 Stack 88.4M 29 Stack Guard 16K 1 VM_ALLOCATE 214.4M 815 VM_ALLOCATE (reserved) 128.0M 1 reserved VM address space (unallocated) __AUTH 1881K 177 __AUTH_CONST 10.4M 332 __DATA 70.7M 366 __DATA_CONST 18.3M 377 __DATA_DIRTY 879K 119 __FONT_DATA 4K 1 __GLSLBUILTINS 5176K 1 __LINKEDIT 629.2M 47 __OBJC_CONST 1770K 149 __OBJC_RO 82.0M 1 __OBJC_RW 3104K 1 __TEXT 405.7M 393 __UNICODE 588K 1 dyld private memory 1024K 1 mapped file 222.7M 88 shared memory 928K 13 =========== ======= ======= TOTAL 13.1G 3728 TOTAL, minus reserved VM space 12.4G 3728 ----------- Full Report ----------- {"app_name":"Blender","timestamp":"2021-12-13 09:14:18.00 -0600","app_version":"3.1.0","slice_uuid":"498eab2f-987c-30aa-ba13-8c1c2cf99c7e","build_version":"3.1.0 2021-12-13","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"72472D20-7A5D-483F-91EE-9D0C48B4DCC8","name":"Blender"} { "uptime" : 58000, "procLaunch" : "2021-12-13 09:08:56.3539 -0600", "procRole" : "Foreground", "version" : 2, "userID" : 501, "deployVersion" : 210, "modelCode" : "Macmini9,1", "procStartAbsTime" : 1394230362821, "coalitionID" : 2497, "osVersion" : { "train" : "macOS 12.1", "build" : "21C52", "releaseType" : "User" }, "captureTime" : "2021-12-13 09:14:17.9996 -0600", "incident" : "72472D20-7A5D-483F-91EE-9D0C48B4DCC8", "bug_type" : "309", "pid" : 2715, "procExitAbsTime" : 1401948528696, "translated" : false, "cpuType" : "ARM-64", "procName" : "Blender", "procPath" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/MacOS\/Blender", "bundleInfo" : {"CFBundleShortVersionString":"3.1.0","CFBundleVersion":"3.1.0 2021-12-13","CFBundleIdentifier":"org.blenderfoundation.blender"}, "storeInfo" : {"deviceIdentifierForVendor":"4680F7E3-F771-54C7-A8DA-0554CE618F11","thirdParty":true}, "parentProc" : "launchd", "parentPid" : 1, "coalitionName" : "org.blenderfoundation.blender", "crashReporterKey" : "72CB9E6D-D690-FCFE-9FB8-22D1CAB5A6B1", "sip" : "enabled", "vmRegionInfo" : "0 is not in any region. Bytes before following region: 4365090816\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1042e0000-10da20000 [151.2M] r-x\/r-x SM=COW ...MacOS\/Blender", "isCorpse" : 1, "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"}, "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":2715}, "ktriageinfo" : "VM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\nVM - Fault hit memory shortage\n", "vmregioninfo" : "0 is not in any region. Bytes before following region: 4365090816\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1042e0000-10da20000 [151.2M] r-x\/r-x SM=COW ...MacOS\/Blender", "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, "faultingThread" : 18, "threads" : [{"id":259880,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259881,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259882,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259883,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259884,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259885,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259886,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259887,"frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":16700,"symbol":"_dispatch_sema4_wait","symbolLocation":28,"imageIndex":1},{"imageOffset":18420,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":132,"imageIndex":1},{"imageOffset":94705088,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":64,"imageIndex":2},{"imageOffset":94699976,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":64,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259888,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259890,"name":"AMCP Logging Spool","frames":[{"imageOffset":6544,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":129196,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":28,"imageIndex":4},{"imageOffset":9820,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":56,"imageIndex":4},{"imageOffset":8828,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":96,"imageIndex":4},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259907,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259910,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259911,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":259915,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":0},{"imageOffset":3383024,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":104,"imageIndex":5},{"imageOffset":1871364,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3360,"imageIndex":5},{"imageOffset":1866464,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":100,"imageIndex":5},{"imageOffset":3748896,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":88,"imageIndex":5},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259942,"queue":"functionsCacheSerialQueue","frames":[{"imageOffset":185552,"symbol":"fstat","symbolLocation":8,"imageIndex":0},{"imageOffset":11016,"symbol":"is_data_file_invalid","symbolLocation":60,"imageIndex":6},{"imageOffset":13988,"symbol":"fscache_element_get_data","symbolLocation":64,"imageIndex":6},{"imageOffset":246116,"symbol":"invocation function for block in MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*)","symbolLocation":140,"imageIndex":7},{"imageOffset":15276,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":1},{"imageOffset":77312,"symbol":"_dispatch_lane_barrier_sync_invoke_and_complete","symbolLocation":56,"imageIndex":1},{"imageOffset":115496,"symbol":"MTLCompilerFSCache::getElement(MTLUINT256_t, void**, unsigned long*)","symbolLocation":308,"imageIndex":7},{"imageOffset":644508,"symbol":"MultiLevelPipelineCache::getElement(MTLUINT256_t const&) const","symbolLocation":188,"imageIndex":7},{"imageOffset":675848,"symbol":"-[MTLCompiler compileFunctionRequestInternal:frameworkLinking:linkDataSize:reflectionOnly:completionHandler:]","symbolLocation":948,"imageIndex":7},{"imageOffset":1875132,"imageIndex":8},{"imageOffset":1870900,"imageIndex":8},{"imageOffset":3014692,"imageIndex":8},{"imageOffset":3018220,"imageIndex":8},{"imageOffset":263384,"symbol":"-[MTLGPUBVHBuilder newPipelineWithKey:]","symbolLocation":864,"imageIndex":7},{"imageOffset":263652,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":160,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":273760,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":708,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259943,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":273608,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":556,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259944,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264748,"symbol":"-[MTLGPUBVHBuilder getPipeline:]","symbolLocation":56,"imageIndex":7},{"imageOffset":268376,"symbol":"-[MTLGPUBVHBuilder setCounterInBuffer:offset:index:value:encoder:]","symbolLocation":80,"imageIndex":7},{"imageOffset":276800,"symbol":"-[MTLGPUBVHBuilder buildWithEncoder:descriptor:scratchBuffer:scratchBufferOffset:fragmentBuffer:fragmentBufferOffset:sourceFragmentIndexBuffer:sourceFragmentIndexBufferOffset:destinationFragmentIndexBuffer:destinationFragmentIndexBufferOffset:nodeBuffer:nodeBufferOffset:childIndexBuffer:childIndexBufferOffset:counterBuffer:counterBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":3748,"imageIndex":7},{"imageOffset":279200,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":980,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259945,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":270584,"symbol":"-[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":112,"imageIndex":7},{"imageOffset":278968,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":748,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"triggered":true,"id":259946,"threadState":{"x":[{"value":5690853376},{"value":3},{"value":0},{"value":5},{"value":1111490576},{"value":0},{"value":6132165664},{"value":6132165512},{"value":12892310192},{"value":0},{"value":5690853376},{"value":0},{"value":0},{"value":4294967295},{"value":3682636533},{"value":41737},{"value":41737},{"value":1073741840},{"value":0},{"value":105553179433728},{"value":0},{"value":11354021904},{"value":105553179433856},{"value":105553179433808},{"value":105553179433832},{"value":105553176495216},{"value":105553155967648},{"value":0},{"value":105553179433736}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4387974788},"cpsr":{"value":536875008},"fp":{"value":6132165440},"sp":{"value":6132165232},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4387974872,"matchesCrashFrame":1},"far":{"value":0}},"frames":[{"imageOffset":22884056,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":308,"imageIndex":2},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259947,"frames":[{"imageOffset":14092,"symbol":"__ulock_wait","symbolLocation":8,"imageIndex":0},{"imageOffset":8512,"symbol":"_os_unfair_lock_lock_slow","symbolLocation":228,"imageIndex":9},{"imageOffset":263548,"symbol":"-[MTLGPUBVHBuilder getPipelineWithKey:]","symbolLocation":56,"imageIndex":7},{"imageOffset":264652,"symbol":"-[MTLGPUBVHBuilder getPipeline:descriptor:]","symbolLocation":784,"imageIndex":7},{"imageOffset":270584,"symbol":"-[MTLGPUBVHBuilder getPolygonFragmentsWithEncoder:descriptor:fragmentBuffer:fragmentBufferOffset:fragmentCountBuffer:fragmentCountBufferOffset:boundsMinBuffer:boundsMinBufferOffset:boundsMaxBuffer:boundsMaxBufferOffset:boundsEndMinBuffer:boundsEndMinBufferOffset:boundsEndMaxBuffer:boundsEndMaxBufferOffset:boundsEndTimeBuffer:boundsEndTimeBufferOffset:boundsStartTimeBuffer:boundsStartTimeBufferOffset:resourceBuffer:]","symbolLocation":112,"imageIndex":7},{"imageOffset":278968,"symbol":"-[MTLGPUBVHBuilder buildGenericBVHWithEncoder:descriptor:outputBuffer:outputBufferOffset:scratchBuffer:scratchBufferOffset:]","symbolLocation":748,"imageIndex":7},{"imageOffset":568860,"symbol":"-[_MTLSWRaytracingAccelerationStructureCommandEncoder buildAccelerationStructure:descriptor:scratchBuffer:scratchBufferOffset:]","symbolLocation":552,"imageIndex":7},{"imageOffset":22892720,"symbol":"ccl::BVHMetal::build_BLAS_mesh(ccl::Progress&, id<MTLDevice>, id<MTLCommandQueue>, ccl::Geometry*, bool)","symbolLocation":1924,"imageIndex":2},{"imageOffset":22921948,"symbol":"ccl::MetalDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":92,"imageIndex":2},{"imageOffset":22884328,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":580,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259948,"frames":[{"imageOffset":228472,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":608,"imageIndex":10},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":10},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":10},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":11},{"imageOffset":119601744,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":2},{"imageOffset":1325976,"symbol":"sig_handle_crash","symbolLocation":360,"imageIndex":2},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":9},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":5849676,"symbol":"tbb::internal::arena::process(tbb::internal::generic_scheduler&)","symbolLocation":252,"imageIndex":2},{"imageOffset":5886724,"symbol":"tbb::internal::market::process(rml::job&)","symbolLocation":40,"imageIndex":2},{"imageOffset":5891580,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":288,"imageIndex":2},{"imageOffset":5891280,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259950,"frames":[{"imageOffset":39588,"symbol":"__accept","symbolLocation":8,"imageIndex":0},{"imageOffset":24740,"symbol":"sock_accept_impl","symbolLocation":32,"imageIndex":12},{"imageOffset":25780,"symbol":"sock_call_ex","symbolLocation":492,"imageIndex":12},{"imageOffset":16564,"symbol":"sock_accept","symbolLocation":120,"imageIndex":12},{"imageOffset":101691164,"symbol":"method_vectorcall_NOARGS","symbolLocation":160,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259951,"frames":[{"imageOffset":48440,"symbol":"__select","symbolLocation":8,"imageIndex":0},{"imageOffset":103142596,"symbol":"time_sleep","symbolLocation":128,"imageIndex":2},{"imageOffset":101925524,"symbol":"cfunction_vectorcall_O","symbolLocation":292,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520884,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23080,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":259969,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6484,"symbol":"mach_msg_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":7424,"symbol":"mach_msg","symbolLocation":76,"imageIndex":0},{"imageOffset":544472,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":372,"imageIndex":13},{"imageOffset":537488,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":13},{"imageOffset":534324,"symbol":"CFRunLoopRunSpecific","symbolLocation":600,"imageIndex":13},{"imageOffset":1764496,"symbol":"_NSEventThread","symbolLocation":196,"imageIndex":14},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":262047,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":262203,"frames":[{"imageOffset":8208,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":262324,"frames":[{"imageOffset":48440,"symbol":"__select","symbolLocation":8,"imageIndex":0},{"imageOffset":103142596,"symbol":"time_sleep","symbolLocation":128,"imageIndex":2},{"imageOffset":101925524,"symbol":"cfunction_vectorcall_O","symbolLocation":292,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520884,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23080,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":102531516,"symbol":"call_function","symbolLocation":416,"imageIndex":2},{"imageOffset":102520848,"symbol":"_PyEval_EvalFrameDefault","symbolLocation":23044,"imageIndex":2},{"imageOffset":101657332,"symbol":"function_code_fastcall","symbolLocation":112,"imageIndex":2},{"imageOffset":101665484,"symbol":"method_vectorcall","symbolLocation":284,"imageIndex":2},{"imageOffset":103154048,"symbol":"t_bootstrap","symbolLocation":72,"imageIndex":2},{"imageOffset":102838420,"symbol":"pythread_wrapper","symbolLocation":28,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]},{"id":262439,"frames":[{"imageOffset":228496,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":632,"imageIndex":10},{"imageOffset":228140,"symbol":"dyld3::MachOLoaded::findClosestSymbol(unsigned long long, char const**, unsigned long long*) const","symbolLocation":276,"imageIndex":10},{"imageOffset":151240,"symbol":"dyld4::APIs::dladdr(void const*, dl_info*)","symbolLocation":200,"imageIndex":10},{"imageOffset":89996,"symbol":"backtrace_symbols","symbolLocation":112,"imageIndex":11},{"imageOffset":119601744,"symbol":"BLI_system_backtrace","symbolLocation":72,"imageIndex":2},{"imageOffset":1325976,"symbol":"sig_handle_crash","symbolLocation":360,"imageIndex":2},{"imageOffset":17636,"symbol":"_sigtramp","symbolLocation":56,"imageIndex":9},{"imageOffset":22883972,"symbol":"ccl::MultiDevice::build_bvh(ccl::BVH*, ccl::Progress&, bool)","symbolLocation":224,"imageIndex":2},{"imageOffset":24138836,"symbol":"ccl::Geometry::compute_bvh(ccl::Device*, ccl::DeviceScene*, ccl::SceneParams*, ccl::Progress*, int, int)","symbolLocation":1060,"imageIndex":2},{"imageOffset":75364784,"symbol":"tbb::internal::function_task<std::__1::function<void ()> >::execute()","symbolLocation":28,"imageIndex":2},{"imageOffset":5915900,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long)","symbolLocation":440,"imageIndex":2},{"imageOffset":5913516,"symbol":"tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*)","symbolLocation":184,"imageIndex":2},{"imageOffset":26037548,"symbol":"tbb::internal::task_group_base::wait()","symbolLocation":40,"imageIndex":2},{"imageOffset":75364824,"symbol":"ccl::TaskPool::wait_work(ccl::TaskPool::Summary*)","symbolLocation":24,"imageIndex":2},{"imageOffset":24172936,"symbol":"ccl::GeometryManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&)","symbolLocation":3524,"imageIndex":2},{"imageOffset":24602104,"symbol":"ccl::Scene::device_update(ccl::Device*, ccl::Progress&)","symbolLocation":1472,"imageIndex":2},{"imageOffset":24620100,"symbol":"ccl::Scene::update(ccl::Progress&)","symbolLocation":164,"imageIndex":2},{"imageOffset":25301080,"symbol":"ccl::Session::run_update_for_next_iteration()","symbolLocation":1012,"imageIndex":2},{"imageOffset":25298856,"symbol":"ccl::Session::run_main_render_loop()","symbolLocation":120,"imageIndex":2},{"imageOffset":25303000,"symbol":"ccl::Session::run()","symbolLocation":252,"imageIndex":2},{"imageOffset":75367536,"symbol":"ccl::thread::run(void*)","symbolLocation":52,"imageIndex":2},{"imageOffset":29248,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":3},{"imageOffset":8228,"symbol":"thread_start","symbolLocation":8,"imageIndex":3}]}], "usedImages" : [ { "source" : "P", "arch" : "arm64e", "base" : 7043039232, "size" : 221184, "uuid" : "c8b3081a-5081-3a99-bbe3-01413de444c6", "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", "name" : "libsystem_kernel.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 7041445888, "size" : 290816, "uuid" : "3a9e9a1e-72b6-3f66-aa17-d955384c1a39", "path" : "\/usr\/lib\/system\/libdispatch.dylib", "name" : "libdispatch.dylib" }, { "source" : "P", "arch" : "arm64", "base" : 4365090816, "CFBundleShortVersionString" : "3.1.0", "CFBundleIdentifier" : "org.blenderfoundation.blender", "size" : 158597120, "uuid" : "498eab2f-987c-30aa-ba13-8c1c2cf99c7e", "path" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/MacOS\/Blender", "name" : "Blender", "CFBundleVersion" : "3.1.0 2021-12-13" }, { "source" : "P", "arch" : "arm64e", "base" : 7043260416, "size" : 53248, "uuid" : "ed328b18-eeef-3b15-8858-798b19b0c2cd", "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", "name" : "libsystem_pthread.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 7187656704, "CFBundleShortVersionString" : "1.0", "CFBundleIdentifier" : "com.apple.audio.caulk", "size" : 163840, "uuid" : "37a561f9-46f0-37fe-811b-894385645aed", "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk", "name" : "caulk" }, { "source" : "P", "arch" : "arm64e", "base" : 7070343168, "CFBundleShortVersionString" : "5.0", "CFBundleIdentifier" : "com.apple.audio.CoreAudio", "size" : 7532544, "uuid" : "fb9c653d-bcad-308b-981b-f2c56c8c17c5", "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio", "name" : "CoreAudio", "CFBundleVersion" : "5.0" }, { "source" : "P", "arch" : "arm64e", "base" : 8674852864, "size" : 28672, "uuid" : "ee08ff54-c00a-3c6d-a77f-1136383e8963", "path" : "\/System\/Library\/Frameworks\/OpenGL.framework\/Versions\/A\/Libraries\/libCoreFSCache.dylib", "name" : "libCoreFSCache.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 7186370560, "CFBundleShortVersionString" : "258.17", "CFBundleIdentifier" : "com.apple.Metal", "size" : 1286144, "uuid" : "970fae8e-1769-3816-badf-2b75ec9a9385", "path" : "\/System\/Library\/Frameworks\/Metal.framework\/Versions\/A\/Metal", "name" : "Metal", "CFBundleVersion" : "258.17" }, { "source" : "P", "arch" : "arm64e", "base" : 8679194624, "CFBundleShortVersionString" : "187.59", "CFBundleIdentifier" : "com.apple.AGXMetal13-3", "size" : 5324800, "uuid" : "1bf04df7-1d70-32e4-a26c-91b3bf4ec942", "path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3", "name" : "AGXMetal13_3", "CFBundleVersion" : "187.59" }, { "source" : "P", "arch" : "arm64e", "base" : 7043366912, "size" : 32768, "uuid" : "ef6555f4-7a8e-3e51-9b40-5381482dee4d", "path" : "\/usr\/lib\/system\/libsystem_platform.dylib", "name" : "libsystem_platform.dylib" }, { "source" : "P", "arch" : "arm64e", "base" : 4646060032, "size" : 393216, "uuid" : "7e92b284-4b90-3b68-b31a-3ddc4c0e8d40", "path" : "\/usr\/lib\/dyld", "name" : "dyld" }, { "source" : "P", "arch" : "arm64e", "base" : 7041994752, "size" : 528384, "uuid" : "00fc01c7-36bc-3193-86a3-5c03046b45fb", "path" : "\/usr\/lib\/system\/libsystem_c.dylib", "name" : "libsystem_c.dylib" }, { "source" : "P", "arch" : "arm64", "base" : 5628379136, "size" : 65536, "uuid" : "994eed94-a9fe-3bce-88ab-4ea5710e5de9", "path" : "\/Users\/USER\/Desktop\/*\/Blender.app\/Contents\/Resources\/3.1\/python\/lib\/python3.9\/lib-dynload\/_socket.cpython-39-darwin.so", "name" : "_socket.cpython-39-darwin.so" }, { "source" : "P", "arch" : "arm64e", "base" : 7043579904, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.CoreFoundation", "size" : 5521408, "uuid" : "f5ea9592-4ef9-3d35-b23d-5c21283acc52", "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation", "name" : "CoreFoundation", "CFBundleVersion" : "1856.105" }, { "source" : "P", "arch" : "arm64e", "base" : 7089287168, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.AppKit", "size" : 15417344, "uuid" : "a8bbc643-113d-310f-96b6-77a973bf2dba", "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", "name" : "AppKit", "CFBundleVersion" : "2113.20.111" } ], "sharedCache" : { "base" : 7040090112, "size" : 3089596416, "uuid" : "66c33c62-48a9-31e5-b8b5-7a71c9760d07" }, "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=11.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=11.7G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 640K 5 \nActivity Tracing 256K 1 \nCG backing stores 2880K 4 \nCG image 1296K 12 \nColorSync 528K 25 \nCoreAnimation 320K 11 \nCoreGraphics 32K 2 \nCoreImage 16K 1 \nCoreUI image data 1056K 8 \nFoundation 16K 1 \nIOAccelerator 3.1G 206 \nIOKit 352K 22 \nIOSurface 122.3M 5 \nKernel Alloc Once 32K 1 \nMALLOC 7.5G 462 \nMALLOC guard page 192K 9 \nMALLOC_MEDIUM (reserved) 352.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)\nOpenGL GLSL 256K 3 \nSTACK GUARD 448K 28 \nStack 88.4M 29 \nStack Guard 16K 1 \nVM_ALLOCATE 214.4M 815 \nVM_ALLOCATE (reserved) 128.0M 1 reserved VM address space (unallocated)\n__AUTH 1881K 177 \n__AUTH_CONST 10.4M 332 \n__DATA 70.7M 366 \n__DATA_CONST 18.3M 377 \n__DATA_DIRTY 879K 119 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 629.2M 47 \n__OBJC_CONST 1770K 149 \n__OBJC_RO 82.0M 1 \n__OBJC_RW 3104K 1 \n__TEXT 405.7M 393 \n__UNICODE 588K 1 \ndyld private memory 1024K 1 \nmapped file 222.7M 88 \nshared memory 928K 13 \n=========== ======= ======= \nTOTAL 13.1G 3728 \nTOTAL, minus reserved VM space 12.4G 3728 \n", "legacyInfo" : { "threadTriggered" : { } }, "trialInfo" : { "rollouts" : [ { "rolloutId" : "601d9415f79519000ccd4b69", "factorPackIds" : { "SIRI_TEXT_TO_SPEECH" : "6193e7ae2171a2330e561ea2" }, "deploymentId" : 250000320 }, { "rolloutId" : "5ffde50ce2aacd000d47a95f", "factorPackIds" : { }, "deploymentId" : 250000063 }, { "rolloutId" : "60da5e84ab0ca017dace9abf", "factorPackIds" : { }, "deploymentId" : 250000007 }, { "rolloutId" : "60356660bbe37970735c5624", "factorPackIds" : { }, "deploymentId" : 250000016 }, { "rolloutId" : "607844aa04477260f58a8077", "factorPackIds" : { "SIRI_MORPHUN_ASSETS" : "60ef663fa2f864203caf575c" }, "deploymentId" : 250000055 }, { "rolloutId" : "5fc94383418129005b4e9ae0", "factorPackIds" : { }, "deploymentId" : 250000172 }, { "rolloutId" : "602ad4dac86151000cf27e46", "factorPackIds" : { "SIRI_DICTATION_ASSETS" : "61a7b71b37dce5558831d479" }, "deploymentId" : 250000288 } ], "experiments" : [ ] } } Model: Macmini9,1, BootROM 7429.61.2, proc 8:4:4 processors, 16 GB, SMC Graphics: Apple M1, Apple M1, Built-In Display: LG HDR 4K, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online Memory Module: LPDDR4 AirPort: Wi-Fi, wl0: Oct 26 2021 16:10:41 version 18.20.310.15.7.8.120 FWID 01-5d6c3867 Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports Network Service: Ethernet, Ethernet, en0 Network Service: Wi-Fi, AirPort, en1 USB Device: USB31Bus USB Device: USB31Bus USB Device: Portable SSD T5 USB Device: USB30Bus USB Device: USB Receiver USB Device: Razer Tartarus V2 Thunderbolt Bus: Mac mini, Apple Inc. Thunderbolt Bus: Mac mini, Apple Inc. ```
Author
Added subscriber: @CookItOff
Timothy Cook changed title from Both option GPU/CPU checked under preferences cause viewport crash. (ARM/Metal) to Both options GPU/CPU checked under preferences cause viewport render crash. (ARM/Metal) 2021-12-13 16:15:21 +01:00
Added subscriber: @Pixla
Added subscriber: @Memento
Thanks! Same behaviour here.
Added subscriber: @hatchli
Added subscriber: @davidmikucki
Author
@LazyDodo
Here is a screen recording of the actions...
Blender Metal Viewport Crash .mov
@LazyDodo Here is a screen recording of the actions... [Blender Metal Viewport Crash .mov](https://archive.blender.org/developer/F12737835/Blender_Metal_Viewport_Crash_.mov)
Author
Added subscriber: @LazyDodo
Added subscriber: @Steve-Hanff
Member
Removed subscriber: @LazyDodo
Member
I just edited your post so the crash log wouldn't take up 5 pages, someone who actually has a mac will have to look at this :)
Same thing here, even on the default start cube.
Added subscriber: @brecht
Michael Jones (Apple) was assigned by Brecht Van Lommel 2021-12-13 21:27:46 +01:00
Marking as high priority, meaning it's something to fix before the 3.1 release.
Added subscriber: @BryanGreen
I'm also experiencing this. Blender does not crash when you output a cycles render, but does crash when you change the viewport to cycles 'rendered' mode.
There's another (possibly?) related issue. If you ONLY have 'GPU' checked in system preferences (and 'Cycles' selected as the rendering device), you can render in the viewport just fine, but Blender will crash after you output a render, close the render view, then click in the viewport. So it's the opposite of the above reported issue; it'll render in the viewport, but crash after you output a Cycles render.
Should this be reported as as separate bug?
Bryan
There's another (possibly?) related issue. If you ONLY have 'GPU' checked in system preferences (and 'Cycles' selected as the rendering device), you can render in the viewport just fine, but Blender will crash after you output a render, close the render view, then click in the viewport. So it's the opposite of the above reported issue; it'll render in the viewport, but crash after you output a Cycles render. Should this be reported as as separate bug? Bryan
Added subscriber: @antoine.grasset
This issue was referenced by blender/cycles@0d59450bb0
This issue was referenced by blender/cycles@0d59450bb0b7837a9c4095e1ec0843a57a0f7053
This issue was referenced by e688c927eb
This issue was referenced by e688c927eb3a82b21ba744ec57540ea2cd4f44c8
@BryanGreen, if that other issue still exists in the next daily build, please make a new bug report.
OK, thanks!
Bryan
OK, thanks! Bryan
Works beautifully now! A thing of beauty!
Awesome performance and completely silent 90% of the time and just a whisper the last 10%.
Much love to all involved. Can't wait to see what performance will be like on my 2019 Mac Pro later and perhaps more importantly the new ones coming down the road.
And I want to underline how much it's appreciated, the speed with which this was addressed.
Works beautifully now! A thing of beauty! Awesome performance and completely silent 90% of the time and just a whisper the last 10%. Much love to all involved. Can't wait to see what performance will be like on my 2019 Mac Pro later and perhaps more importantly the new ones coming down the road. And I want to underline how much it's appreciated, the speed with which this was addressed.
Added subscriber: @Carter-LaSalle
I am also having this issue am I am using:
Blender Version: 3.2.0 Alpha, master, 2022-02-20 02:31, 1f79132287
OS: macOS-12.3-arm64-arm-64bit
GPU: Apple M1 Pro Apple 4.1 Metal - 76.3
I am also having this issue am I am using: Blender Version: 3.2.0 Alpha, master, 2022-02-20 02:31, 1f7913228779 OS: macOS-12.3-arm64-arm-64bit GPU: Apple M1 Pro Apple 4.1 Metal - 76.3
Removed subscriber: @antoine.grasset
13 Participants
Reference: blender/blender#94022
