Making a Horizontal Split from the top menu bar is buggy #94071
Reference: blender/blender#94071
Operating system: Linux-5.11.0-41-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: Mesa DRI Intel(R) HD Graphics 2000 (SNB GT1) Intel Open Source Technology Center 3.3 (Core Profile) Mesa 21.3.1 - kisak-mesa PPA
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
Worked: I don't know, but I don't remember having experienced any difficulty using Horizontal Split thing before.
I've identified and was able to reproduce 2 problems:
Start a new blend file, tackling each problem (1 and 2) separatedly:
Thanks! Hope more issues can be found out, if any, from this kind of investigation on the UI.
Added subscriber: @Pxy-Gnomes
Added subscriber: @Harley
When you right-click in the gaps between editors you get a context menu that has some options to join/split/etc areas. But you can't join or split or do anything with the Top Bar (the area with File/Edit/Render/etc and workspace tabs) nor the Status Bar (area at bottom showing keymap info, etc) . Those two areas are fixed.
So right-clicking very high up in the space below top bar will be seen as an attempt to split the top bar, which is not allowed. I can't think of any simple ways of improving that but will keep that in mind. For now I'd say click a little lower when in that area. Or click a lot lower because right-clicking on the entire height of any header as well will give you the same options, which is easer to hit than the gaps.
Added subscriber: @jenkm
What I see here.
Separator between two editors: There are 1 or 2 pixels above and below the separator where the cursor changes to normal but... Right-clicking does nothing here. The editor's header is not highlighted as if you are not in the editor yet. The tab (properties editor) is highlighted. Left-clicking works.
Separator between editor and the top/status bar: If the cursor is close to the Top Bar tabs, the tab is highlighted (hover state) but the cursor is still of the "resize" type. Move the cursor higher and it changes to the default arrow, while Right-clicking still opens the split menu.
I am not sure that there is a case when it will be considered as an attempt to split the top bar. You select a menu item and at that time the cursor is inside the editor below. Well, and I don't see any issues when trying to split the top bar.
Unfortunately it is the mouse position when that menu is launched that determines where the split starts, not the position of the item in the menu. And in this situation you are right-clicking in the top bar’s bounds.
OK... Oh, yes I see sometimes the operator is canceled if it is called too close to top/status bar.
I think this can be fixed. Split is doing lots of checks before it even starts, which is no longer needed now that we allow changing from area to area once you start the modal operation.
I'll mark this as confirmed so I can reference it in a patch. Will take lots of testing though.
This issue was referenced by
fa8c2c7885
