Blender crashes when beveling many vertices to a sharp point if Lineart is active #94390
Reference: blender/blender#94390
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple
M1
Pro Apple 4.1 Metal - 76.3Blender Version
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
Worked: LTS 2.93.7 hangs for a few seconds, but doesn't seem to crash.
Beveling an n-gon with lots of vertices to a sharp point causes a segfault if a Lineart modifier is using the mesh.
The attached lineart-bevel-crash.blend file is set up; just bevel and drag and it should crash. I have not tested this on other platforms, however.
Full stacktrace: P2682
Added subscriber: @chemicalcrux
I also get a segfault from the latest commit on master,
28a8d434d5
Added subscriber: @ChengduLittleA
I'll take a look
It didn't really crash here on my machine but after I bevel it to a sharp point or go further it immediately becomes much more laggy. I need to take a look on what's causing it, maybe there's too much depth in subdividing image bound box (there are more than 256 triangles concentrating inside 1 point so it kinda confuses the algorithm). From the stack trace it could be a memory issue, however on my machine I didn't really see any memory spike, debug info shows only
allocated 6 Standalone nodes, total 6291456 Bytes.
hummm. This is quite interesting I shall investigate further.Update: I found the cause of this specific crash, which is cause by a duplicated "edge-boundbox" linking, this added too many edge pointers into a tile that overflows the limit. This bug is probably caused by a merge which it automatically modified some code path that I'm unaware of.
HOWEVER After I fix this it still crashes, :/OK it is this problem indeed... And it's fixed now at least for the test file you provided. There's still a internal limit of line art of triangle density, I need to protect that array so it won't get overflowed.
Added a protect condition to not add too many lines in one tiles in case that you got very dense concentration of geometry in one point like the "bevel to one point" situation.
I may also include a check in the loading stage to discard edges that has zero length and triangles that has zero area.
The same fix is now included into
temp-lineart-contained
branch as well to prevent crash. Also it's faster :)
