Subsurface scattering broken in Mix Node in Eevee #94466
Reference: blender/blender#94466
Operating system: Windows 10
Graphics card: Nvidia GeForce RTX 2080
Version: 3.0
When you use a mix node between two Principled BSDFs with subsurface in Eevee, it only keeps the subsurface scattering of the shader in the first socket of the mix node. It seems to keep the general color of the subsurface for the second, but it doesn't include the scattering.
Create a cube with a shader that has two identical principled bsdf nodes with visible subscattering, then use a mix node to compare them.
Added subscriber: @Lance-Haug
Added subscriber: @chemicalcrux
I cannot reproduce this in 3.0. I've attached a demo file that mixes two Principled BSDF nodes.
Subsurface #94466.blend
The first one has very low red subsurface scattering; the second one has very intense blue subsurface scattering. Both have zero specular and diffuse components. The mix node blends between them based on the X coordinate of the object, to make it easier to visualize the blending.
As far as I can tell, this is working correctly. Even with zero subsurface strength on the first shader input, the second one's subsurface scattering still works correctly.
Is this the correct setup?
Added subscriber: @EAW
