Particle emit from vertices for meshes without faces in Geometry Node behaves incorrectly #94571
Reference: blender/blender#94571
Operating system: macOS Monterey 12.0.1
Graphics card: N/A
Broken: 3.0.0
Worked: N/A
Particle emit from vertices for meshes without faces in Geometry Node are not working in the same way as direct creation in Object Mode
VerticesParticleOfFacelessMesh.blend
Added subscriber: @NeverSnow
Added subscriber: @deadpin
Confirmed here. Even if you use the "Use Modifier Stack" option in the Particle system, the particles do not emit correctly until you give the Circle either an ngon face or triangle faces.
Added subscriber: @TheToxicJ
Added subscriber: @dfelinto
The geometry nodes will eventually fully replace the old particles system. Those systems are not supposed to work with each other. Archiving as known issue since it depends on the old particle settings which is end of life.
