Out-of-bounds memory access due to malformed HDR image file #94572
Reference: blender/blender#94572
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.14761 Core Profile Context 21.10.3 30.0.13031.1001
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-31 20:32, hash:
6844304dda
Broken: version: 2.93.8 Release Candidate, branch: master, commit date: 2021-12-15 14:37, hash:
59a48cc43d
Worked: -
An HDR image (loaded as a texture, for example) may specify a negative width or height, leading to invalid size and address calculations.
Cause
The parsing in
imb_loadhdr
declaresint width
and parses it from the input file usingsscanf
with the%d
format at source/blender/imbuf/intern/radiance_hdr.c:252. There is no check for negative sizes such as -1.Allocation of the ImBuf structure succeeds, since the internal
MEM_callocN
adds the size of a small structure before callingmalloc()
, thus ensuring thatmalloc
is called with a reasonable (small) size parameter.The end result is that a small pixel buffer is allocated, and
ImBuf->x
orImBuf->y
are negative.Exact steps for others to reproduce the error
The following input file illustrates the problem.
oobw_rotate_54.hdr
The interesting fields are on the third line: "-Y" indicates that the image needs to be flipped. 64 is the height and -1 is the width.
oobw_rotate_54.hdr
.Impact
Depending on the input file and the
flags
parameter toimb_loadhdr
, this can have one of several effects. The most severe is the potential for malicious code execution, as a consequence of out-of-bounds memory access.Input file with "-Y" and a negative width
The call to
IMB_flipy()
at line 307 will lead to an out of bounds write.Input file with "Y" and flag
IB_rect
usedThe call to
IMB_rect_from_float()
at line 311 will lead to an out of bounds write.Input file with "Y", negative width and flag
IB_floatrect
usedimb_loadhdr
will fail to identify the fault and return an invalidImBuf
, which has a small pixel buffer allocated and negative dimensions. The potential impact of this ranges from a crash (out of bounds reads due to the small buffer) to potential code execution (out of bounds write on the small buffer).Proposed mitigation
Check
width
andheight
right after parsing them withsscanf
. There appears to be no reason to allow negative values.Added subscriber: @eldstal
Added subscriber: @deadpin
Confirmed, and it would be fixed with D11952. I'll push to get that committed sometime soon.
Thanks for taking a look at this so quickly!
I can confirm that the patch in D11952 includes a fix for this issue.
This issue was referenced by
1ee4e6bf31
77616082f4
This vulnerability has been assigned CVE-2022-0546 by the Red Hat CNA.
