align euler to vector doesn't work with distribute points on faces #94680
Reference: blender/blender#94680
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-01 11:50, hash:
4c46203cb5
i have this little sweet node setup in gn:
So this works. A simple default cube with instancing on the edges and the instance rotation is aligned. Works.
But...unmuting the distribute on faces node gives this result:
This looks like or bug to me...or it is a logic i do not understand.
Added subscriber: @LuckyChris
Added subscriber: @RoyTheKoi
I believe this is not a bug. The reason for the behaviour you're seeing is that points do not have a Normal attribute like meshes do, so using the Normal input node does not work.
Luckily the Distribute Points on Faces node outputs the normal of the face on which a point was distributed. This can be used with the Align Euler to Vector node instead:
Or even easier is to use the rotation output directly:
Indeed, like @RoyTheKoi says, this is not a bug. There is a page in the manual about this too: https://docs.blender.org/manual/en/latest/modeling/geometry_nodes/fields.html#field-context
In the future there will be a warning when the input node doesn't work: #94039 That's a goal for 3.1.
