Blender crashing when geometry nodes with a large animated image sequences are used #94738
6 Participants
Reference: blender/blender#94738
Operating system: Linux-5.15.12-artix1-1-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 495.46
32GB Ram
Broken: version: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-16 23:26, hash:
34d424fd64
When using a large animated image sequence (2100 images for example) blender crashes for me somewhere after frame 2000 while playing.
Shorter sequences (<2000) dont seem to cause any crash.
Tested both on RC and stable builds. Seems to be also happening on windows builds.
I have not yet found a way to consistently reproduce this. Sometimes it manages to go through all 6519 Frames, and sometimes
it crashes. The frame count has been > 3000 at the time of the crashes at least. Once crash occured when image was rendered during playback
music test.crash.txt
#94738.crash.txt
music test.blend
I removed any frames after 2100 from this file but the original sequence had ~6800 Frames, so if you need a larger sequence for testing I can provide that too.
Added subscriber: @PaulHaeger
Added subscriber: @mano-wii
Could you provide the sequence of images used?
Apparently the packing of movies and image sequences in the .blend file is not supported. So the file is missing the images.
Added subscriber: @deadpin
From the crash file it looks like it's another duplicate of #92740/T94266 and the fix will go out in 3.0.1 if/when that release is decided.
Note: As of right now, none of the fixes that are being considered have been checked into the 3.0.1 build yet. In order to try out the fix, you'll have to grab a 3.1 build.
Here are the images.
imgdata.tar.gz
I will later today test this in the 3.1 build, thanks for the info!
I have been testing the latest 3.1 Build. Seems a lot more stable and I can use a larger set of images.
However there have still been some sporadic crashes. I have not yet found a way to consistently reproduce this. Sometimes it manages to go through all 6519 Frames, and sometimes
it crashes. The frame count has been > 3000 at the time of the crashes at least. If this is related to this issue or not I dont know.
I attached the log of the last crash I had: music test.crash.txt
If I can find out more I will report it.
Added subscribers: @mont29, @Sergey, @iss
I was able to cause crash too, this happened when I hit render, but I was not able to reproduce this anymore. It is evident from my crash file, that I was fuzzing around. Also my trace is different than previous one so it's possible there are more causes. Will confirm even though this seems to be very hard to reproduce.
#94738.crash.txt
CC @Sergey, @mont29
Also note that I have reduced cache size limit to increase likelyhood of crash, but not quite sure if this did have any effect.
All tracebacks end up to the same point ( movie cache code,
moviecache_valfree -> MEM_CacheLimiter_unmanage
), so I think this is more for the #vfx_video module than #core really?I was unable to reproduce the issue so far, but found an issue in the related area which got addressed in
f4c8b4eb3e
.Took a while for all builds to get ready. Please give it a test again!
Will do!
Unfortunately I'm away for a few days so I can't test it until Wednesday at the soonest.
I tested the
9097c97767
Build since it was the closest to the commitf4c8b4eb3e
.I gave it some stress testing and Blender did not crash once. The issue seems fixed now, thank you very much.
Im going to set this issue to resolved unless anything speaks against it.
Thanks for the report and testing!
