Geometry Nodes: Map Range Node documentation needs update #95179
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#95179
The Map Range Geometry Node is a field node, which should be reflected in screenshot and description of the documentation
manual link: https://docs.blender.org/manual/en/3.1/modeling/geometry_nodes/utilities/map_range.html
Added subscriber: @Izak-van-Langevelde
Added subscriber: @wannes.malfait
At the moment the documentation just references the shader documentation of the node. This is because there is no real difference in the way the shader and geometry nodes versions work. The same thing is done for other similar nodes like the math node and the noise texture nodes.
Added subscriber: @Blendify
Yeah I do not consider this a bug, in the future shader nodes will support fields and this won't be an issue.
In the meantime its more of an inconvenience
