Blender crushs server #95211
Reference: blender/blender#95211
Operating system: Windows Server 2019 (on virtual machine of Microsoft Hyper-V server 2019 hypervisor)
Graphics card: NVIDIA Tesla V100 16GB (as a virtual GPU with NVIDIA Grid system)
Blender Version 3.0.0
In general, the server has 80 GB of memory, the rendering goes through the Tesla V100 16GB, and there is one model
https://www.cgtrader.com/free-3d-models/vehicle/military/ww
, and now, I open it in Blender under any rdp-user. Then I click the Animation tab, on the right, in the render settings, I specify that the render goes through the GPU (this is in the Cycles engine), I click Render. And when the memory usage in the Task Manager reaches 80 GB, then the entire server freezes, with all the users working there, and it has to be rebooted (virtual server, Microsoft Hyper-V 2019 hypervisor). On the OS server - Microsoft Windows Server 2019.
In Blender Settings, of course, I specified CUDA. And on the same tab
some settings with the paging file. Maybe tweak something there?
At first I thought that it was necessary in the Limit Cache in Memory tab, or put a checkmark on Use Disk Cache. But they are in the item Nonlinear video editor. How can it be solved?
Added subscriber: @Fullname
Added subscriber: @lichtwerk
Out of memory crashes are usually not considered a bug, see:
Sounds a bit suspicious though that the file eats so much RAM.
Please provide the
.blend
file though (there could be many things there too - not only in the model [which is behind a pay-/login-wall btw. which is not accepted here]It could also help if you provide crash logs
blender_system_info.txt
blender_debug_output.txt
uploads_files_629193_FullJeep_20836_autosave.blend
Is it not a simple model?
You write at least will you consider this or not
Added subscriber: @iss
I was able to render the file, but it uses quite a lot of resources (~35GB RAM, and ~10GB VRAM), so it depends on what else server is doing. Please check amount of free memory - RAM and GPU on machine while rendering.
In provided file, there are no materials, so your rendered image will be probably unusable, but shouldn't crash really.
I can not to do this now because system wlll crush again, but users are work now and until evening. If to consider other day then there is free time in Monday, but it's a not fact that I will possible to do this bcecause there are many works and task that can be planned on this free time
Thanks again for the report. If the problem persists please comment again here (we can always reopen in such case)
