When using mask modifier, particles get also generated from the origin #95598
Reference: blender/blender#95598
Operating system: macOS-10.14.4-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GT 750M OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-12.0.23 355.11.10.50.10.103
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
I'm emiting particles from an object. I use the mask modifier so that the particles are generated only in some areas. Particles will be generated from the origin, even if there's no geometry there.
Play the animation from the attached file. You will see a column of particles coming from the origin.
Bug.blend
Added subscriber: @Funnybob
I tried to export an alembic and generate the particles from that instead and I get a similar problem. So look like the issue in on the particles side and not the geometry.
Hi, thanks for the report. Similar issue has been closed before as the design limitation: #32109 (Object with mask modifier emits particles mostly from object center)
Soon particle system will be replaced by new system so I am not sure if developers are going to fix this problem. Will confirm for now.
This comment was removed by @PratikPB2123
Ok thanks.
Added subscriber: @dfelinto
Thanks for the report. Marking this as known issue since it depends on the old particle settings which is end of life .
