Shader Editor, default Color Picker, HSL tab, L 0.5 screenshot is Wrong in the manual. #95657
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#95657
Windows 10 Home 1909, HP laptop
AMD Radeon R5 Graphics (latest driver)
Broken: 2.92.0 on forward thru last night's beta (de718605558f) and alpha (452a7f673190).
Worked: 2.91.0 and prior (checked intermittently back thru 2.83.0, Reloaded Factory Defaults each time), worked as expected
In the Shader Editor the default Color Picker says that H 0.00 S 0.00 V 0.50 (half of the scale) is a significantly lighter gray than it should be (according to the Color Picker page in the latest manual, and industry standard), much higher on the value slider than the midpoint.
To reproduce select the Default Cube, go into the Shader Editor, and pull up the Color Picker in any node that'll access it (the Principled BSDF node, for example). In the HSV tab's Value field type 0.50 and enter, observe the Value slider on the right of the Color Picker.
additional info
Please see the topic at Blender Artists for screenshots and more detail:
https://blenderartists.org/t/whats-with-the-value-slider-in-the-hsv-tab-of-the-default-color-picker/1360186
Added subscriber: @KickAir8p
Added subscriber: @EAW
Hi @KickAir8p, thank you for the report.
This was an intentional change, and therefore isn’t considered a bug. See {https://developer.blender.org/rBf193b1afb313bcb937a396f09da2b9903a0d2fc3} I’ll close this report as per the tracker’s policy.
Changed status from 'Archived' to: 'Confirmed'
Sorry, I didn’t notice that the manual had yet to be updated, I’ll reopen this as a documentation task.
Shader Editor, default Color Picker, HSV tab, Value Slider is Wrongto Shader Editor, default Color Picker, HSV tab, V 0.5 screenshot is Wrong in the manual.Shader Editor, default Color Picker, HSV tab, V 0.5 screenshot is Wrong in the manual.to Shader Editor, default Color Picker, HSL tab, L 0.5 screenshot is Wrong in the manual.This comment was removed by @KickAir8p
Added subscriber: @Blendify
Changed status from 'Confirmed' to: 'Needs User Info'
Where exactly I'm the manual does it need an update?
The Color Picker page is no longer accurate.
https://docs.blender.org/manual/en/latest/interface/controls/templates/color_picker.html
The Blender Artists topic I linked above also contains examples of confusion in use:
https://blenderartists.org/t/whats-with-the-value-slider-in-the-hsv-tab-of-the-default-color-picker/1360186/2
Thx!
Added subscriber: @Alaska
I will update the manual.
This issue was referenced by 8945
