Draw tool draws a 3D curve even though the curve data is 2D #95954
5 Participants
Reference: blender/blender#95954
Operating system: Linux
Graphics card: intel 520
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: unknown (new comer to blender)
when drawing a bezier spline using "Draw" in BezierCuve->edit mode in 2D , I get a 3D object with 2 surfaces not in the same plane
Object Data Properties
make the curve2D
and optionally withFill Mode
Both
The resulting curve will be 3D instead of 2D
Original Steps from the report:
Tool Settings :
3d cursor is set to "orientation : geometry" (both using the shift+rightClick or 3d cursor tool)
shift+A is set to create object at 3d cursor location
expected : the 2D curve should be constrained into XY plane of 3D cursor (as when doing shift+A -> Mesh -> plane)
what I get : at best a surface that is "twisted" in 3D, at worst a set of bezier splines linked together and not in same plane (as 2D would make me expect)
additional remarks :
eula.blend
Added subscriber: @WoL
#95955 was marked as duplicate of this issue
Added subscriber: @OmarEmaraDev
Aren't 2D curves locally constrained to the XY plane and thus can't arbitrary aligned with a surface when drawing?
The provided files doesn't seem to be related to the issue. Can you upload the correct file or simplify the file to only contain the objects related to the issue in question?
You should also test on a more recent version of Blender as 2.80 is no longer maintained.
sorry I thought I filled the version, I use blender 3.0.1
for my knowledge how can I constrain a locally a curve to a plane?
the produced curves aren't in any plane, in the screenshots I provided, the 2nd one it what i see when drawing the 2d curve, the 3rd one is what is got after hiding the other object that is used as reference and rotating the view, the last one is what I see I go into side view of the "2d" spline (if it was 2d, I would only get a line....
here is a simplified blend file, with 2 2d bezier curves drawn using the method given{F12883971}
here is another screenshot with the reference object, 3d cursor and the "2d spline", viewpoint is perpendicular to the 3d cursor XY plane (the drawing plane)
It is weird because I can't create 2D curves that are not on the XY plan myself. The documentation also specify that, so it is unclear to me how that's possible https://docs.blender.org/manual/en/2.79/modeling/curves/properties/data.html#shape.
Investigating.
I can see the problem in the file you provided, but that curve seems to be corrupted. Are you able to reproduce the issue from scratch on version 3.0+?
I closed blender,
restarted from scratch using blend file provided in intial report,
but I can't be sure... how can I set up "front/left/right/back" views to be in 3d cursor's space (front = 3d cursor XY plane and so on...) ?
same how can I set the view to be "centered on 3d cursor" so that rotating rotate around 3d cursor? '/' center on object's center-point but I don't find it convenient
so, it seems that the bezier draw tool in 2d filled works now as expected and I don't know how I ended with have it missbehave, maybe should give a try with the simplified blend file?
2D curves in Blender can only exist in the local XY plan of the curve object, I am not sure how you ended up with a 2D curve that is not flat, but even moving a vertex in that curve you provided projects it on the XY plan.
It could be that the curve is corrupt somehow. If we can't replicate that from scratch, I am afraid there isn't much we can do. Can you do that now?
yes it can be reproduced from scratch
this created EACH TIME a kind of union of 2 2d spline... i tried on the "star looking" surfaces or on some surface between the 2....
Added subscriber: @mano-wii
I was able to reproduce the problem from scratch using much simpler steps. I'll edit the description of the report...
draw 2d bezier not in planeto Draw tool draws a 3D curve even though the curve data is 2D
