Last Subdivison in modifier stack is not apllied when using object info node #96264
Closed
opened 2022-03-09 16:42:08 +01:00 by Lukas Ziechmann · 4 comments
seems not hardware/ OS specific
(Tested on Windows and Linux-Fedora on different machines)
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: c77597cd0e
Worked at least in official 3.0-release
(version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca3055776)
When using the object info node - the last Subdivison-Surface-Modifier in the modifier stack of the original object is not applied to the geometry object if not called "As Instance". (For Collection info node - the same error persists.).
attached .blend file (as simple as possible)
bugreport-subD-simple-file.blend
**System Information** seems not hardware/ OS specific (Tested on Windows and Linux-Fedora on different machines) **Blender Version** Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: `c77597cd0e` Worked at least in official 3.0-release (version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: `f1cca3055776`) **Short description of error** When using the object info node - the last Subdivison-Surface-Modifier in the modifier stack of the original object is not applied to the geometry object if not called "As Instance". (For Collection info node - the same error persists.). **attached .blend file (as simple as possible)** [bugreport-subD-simple-file.blend](https://archive.blender.org/developer/F12914029/bugreport-subD-simple-file.blend)
Added subscriber: @LukasZiechmann
Member
Member
Hi, thanks for the report.
This is not actually a regression. Unchecking GPU subdivision option will fix the issue: {nav Edit > Preferences > Viewport > Subdivision > GPU Subdivision}
Also a duplicate of- #95700 (GPU subdivision: Referencing object with subdivision surface with Object info node does not work)
Hi, thanks for the report. This is not actually a regression. Unchecking GPU subdivision option will fix the issue: {nav Edit > Preferences > Viewport > Subdivision > GPU Subdivision} Also a duplicate of- #95700 (GPU subdivision: Referencing object with subdivision surface with Object info node does not work)
Member
Closed as duplicate of #95700
2 Participants
Reference: blender/blender#96264
