Regression: Missing update in custom Nodetree #96394
Reference: blender/blender#96394
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 3.1.0, current master
Affected by
7e712b2d6a
If create custom node tree with name "CustomNodeTree" and try update node tree by script:
bpy.data.node_groups["CustomNodeTree"].interface_update(bpy.context)
- tree not updated. In version Blender 3.0 function works goodExact steps for others to reproduce the error
Download archive
batch_render_nodes.zip
Install zip-archive add-on in Blender 3.0 and Blender 3.1
Download test file
Batch_Render_Nodes_UPDATE_TREE_TEST.blend
Open test file in Blender 3.0
Try change sockets values
Sockets output values updated
Open same test file in Blender 3.1
Sockets output values not updated
For update sockets and all node tree i used function https://docs.blender.org/api/current/bpy.types.NodeTree.html#bpy.types.NodeTree.interface_update
Added subscriber: @GregoryS
Hi, thanks for the report. You mean using default python template?
I don't think I understand steps for reproducing the problem. Are you using custom script? Can you attach that?
Also, please test again on latest 3.2 build: https://builder.blender.org/download/daily/
Similar reports I have seen where responsible commit was
7e712b2d6a
Thanks!
I codding add-on for batch rendering using node trees.
Steps:
Download archive batch_render_nodes.zip batch_render_nodes.zip
3.Download test file Batch_Render_Nodes_UPDATE_TREE_TEST.blend Batch_Render_Nodes_UPDATE_TREE_TEST.blend
Open test file Batch_Render_Nodes_UPDATE_TREE_TEST.blend in Blender 3.0
Open test file Batch_Render_Nodes_UPDATE_TREE_TEST.blend in Blender 3.1
I try Blender 3.2. Sockets output information also not updated
Also i upload screen videocapture
Video_Blender_3_0.mp4
Video_Blender_3_1.mp4
Thank you for the information :)
I can confirm now. This is got affected after the same commit. This one-
7e712b2d6a
@JacquesLucke ^
Function - interface_update(context) - from class NodeTree not work in Blender 3.1to Regression: Missing update in custom NodetreeI'm not 100%, but right now this does not feel like a bug in Blender to me.
It seems like you expect Blender to call the
update
method on every node when you callinterface_update
. However, there is no reason why it should do that.interface_update
is a method that was supposed to be called to force an update when the inputs or outputs of a node group changed. However, Blender never calls this function itself anymore, so maybe it should even be removed.From what I can tell, the current update-logic in the addon is very brittle. This is also shown by the fact that you always call
interface_update
three times, so that data can propagate for three nodes. This might give the illusion that it works, but is still unreliable when there are longer chains of nodes.A short term fix would be to just call
node.update()
for all the nodes manually.In addition you might have to loop over the different area/regions in the Blender UI and call
tag_redraw
on them.For a more complete example see P2851.
I highly recommend you to implement a system that gives you control over when and in what order nodes are executed.
Thanks !I have updated the code, thanks to your advice. Update nodes works
