Regression: very long input delay when dragging some gizmos handles in macOS #96435
12 Participants
Reference: blender/blender#96435
Broken: 3.1.1 Release Candidate, branch: master, commit date: 2022-03-24 13:38, hash:
fb2cb0324a
Worked: 3.1.0
When dragging some gizmo handles, the user has to drag the mouse cursor over a huge distance before the drag is registered as an input. That is even if the drag threshold is set to the minimum level. Used to work normally in 3.1 and earlier releases. This makes using the gizmos extremely slow and unresponsive.
Some gizmo handles work better, such as the move gizmo handles. Not sure why there is such a difference.
See the below video recording. As you can see, drag threshold is set to the minimum amount here, and you can see the cursor traveling very far before it starts to scale
Added subscriber: @WilliamReynish
#96789 was marked as duplicate of this issue
#96811 was marked as duplicate of this issue
Added subscriber: @HDMaster84
Cannot reproduce on linux.
Can you reproduce it with a factory settings?
Operating system: Linux-5.15.0-2-amd64-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.86
version: 3.2.0 Alpha, branch: master, commit date: 2022-03-14 15:13, hash:
cff6eb6580
Yes. Should have mentioned. Factory settings.
Added subscribers: @mano-wii, @PratikPB2123
Hi @WilliamReynish , can't reproduce either. Probably Mac specific this issue is? @mano-wii , can you confirm?
Maybe got affected by
1f1dcf41d5
Added subscriber: @ideasman42
I can't replicate on mac.
But I feel that the report also needs to inform:
@ideasman42, is this something for you to take a look at?
Operating system:
macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card:
Apple M1 Apple 4.1 Metal - 76.3
Added subscriber: @lichtwerk
Also cannot reproduce here.
@WilliamReynish : can you fill the information gap?
Now we also have #96811, #96789 (both reported on Mac OS)
Hard to tell if 3.2 is the first version where gizmo dragging is affected. Other reports are claiming exact same issue on previous release versions.
Added subscribers: @veily, @p1x3l
Having the same issue with apple magic trackpad or a logitech mouse. However DPI is more interesting, I just tried to turn down the resolution of one of my external monitor to low resolution mode and it's a lot less noticible (to a degree that I feel like I can live with it if it's not fixed at all). Looks like it definitely has something to do with DPI. I can simply drag the blender window between low and high DPI monitors and the delay is different when the window is on the high DPI monitor than when it's on low DPI monitor.
To know what's going on, I think we should check what happens inside
WM_event_drag_test_with_delta
.Is this function not being called when it should? Is the value of
drag_threshold
ordrag_delta
being calculated wrong?I tested it on screens with different DPIs but I still couldn't replicate the problem :\
I also can't redo the error, tried with UI scale set to 2.0 & 4.0.
Since this is reported to be working in 3.1.0 and not in 3.1.1 there aren't so many commits that could have caused this. Checking over the commits I don't see any likely candidates.
It's unfortunate this got into the 3.1 release, it would help a lot if someone on macOS could bisect the error to find when this broke.
@PratikPB2123 most of the changes to dragging were not included in 3.1x (
1f1dcf41d5
will only be in 3.2x for e.g.).It's also strange this only impacts macOS as most of the code in this area is the same for all platforms.
Edit: other reports listed as duplicates of this say that 3.0.1 was the last working version, could someone confirm this definitely worked in 3.1.0?
Very long input delay when dragging some gizmos handlesto Regression: very long input delay when dragging some gizmos handles in macOSAre you reproducing with a high DPI monitor? To clarify, for me changing UI scale inside the blender does not affect it, only OS level scaling does. My guess is that it's related to how macOS handles UI scaling in high DPI monitor.
Added subscriber: @didi404
This comment was removed by @didi404
I am a macOS user and have encountered this problem in use.
There is a noticeable delay when dragging Gizmo to move, scale, or rotate, especially when along a particular axial and axial plane.
Added subscriber: @Sergey
I can reproduce this issue on Mac Pro 2019 AMD W6800X, but NOT on MacBook with Intel Iris GPU.
Issues I observe on the Mac Pro:
Added subscriber: @Nurb2Kea
I can confirm this also for blender 3.2
version: 3.2.0 Alpha, branch: master, commit date: 2022-04-24 12:33, hash:
17eb8a9ceb
(macos 12.3.1 + latest brew updates + xcode 13.2) + magic mouse
Will consider this confirmed.
Since I dont have the hardware it would be super nice if someone could bisect this.
So is this issue only happening when multiple monitors are involved? There seem people suggesting that, and it's not uncommon to have DPI issues on setups with multiple monitors and different DPIs. OTOH some comments (esp. Sergey's) sound more like a GPU driver issue. Only people with AMD cards seem to have the issue.
I cannot reproduce a strong lag like shown in the video. However, with the combined transform manipulators I do get a bit of a lag:
Operating system: macOS-12.3.1-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5700 XT OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.15
All things considered this does seem more like a GPU driver issue.
Okay, Sergey noticed there's also quite a big lag when trying to rotate the view quickly while hovering specific gizmos. I can confirm that, even though for me it's only happening with the combined transform manipulator. So same symptom under slightly different conditions.
At this point I think it's safe to consider this a GPU driver issue. Marking as responsibility of the #eevee_viewport module.
@JulianEisel, the dual-monitor might be a factor here, but in my case it happens on a single monitor setup. Although, it is a high-res display.
Bisected the issue I am having here to
0cb5eae9d0
.Changed status from 'Confirmed' to: 'Resolved'
Committed
5045968f24
as this caused problems for both macOS and Windows+NVidia.
