Merge By Distance Node breaks Motion Blur in Cycles #96463
6 Participants
Reference: blender/blender#96463
Operating system: Win 10 Pro / Version: 10.0.19043 Build 19043
Graphics card: Nvidia 3080Ti / Driver Ver: 511.79
Broken: 3.1.0 Stable & 3.2 master_f6b73966101d
Geometry Nodes -> Merge By Distance Node breaks motion blur in Cycles. Works fine in EV.
1: Take a mesh, split edges,
2. Set Position to give faces motion along their normal vector,
3. Extrude Mesh by faces,
4. Join Geometry with original faces,
5. Merge By Distance
6. Render in cycles with Motion Blur, Mesh Explodes. Now Remove Merge By Distance and render again.
MBTest.blend
Added subscriber: @Giff-Boake
Added subscribers: @HooglyBoogly, @iss
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Looking at spreadsheet editor, I see vertices jumping all over the place, which is why this does not work. This seems to be caused by merge by distance node, which shuffles vertex indices, so cycles thinks, that vertex number n jumped to far from where it was before.
I don't think you need merge by distance node for rendering, but still it would be nice if this could be prevented in first place. But currently it is working as intended and may not be considered as a bug.
@HooglyBoogly Should this be confirmed as known issue perhaps?
Merge by distance is not needed above but you would definitely need it when using Sub Surface which I think would be a pretty common use case.
The Merge by Distance node can not output a consistent topology when the input mesh changes, as would be necessary for motion blur. There could potentially be workarounds using an id on vertices, but that doesn't really work yet, I think. Generally it would be better to do the topology changing operation before the animation here.
Added subscriber: @JacobMerrill-1
Being able to write your own velocity vector could work here too*
maybe we can expose a 'last frame' data node ?
(to compare a objects pos/rot from last frame to generate your own velocity even if faces merged etc)
Added subscriber: @BEHE
I'll close this, since this is expected behavior, it's just because of how motion blur works.
