Slow EEVEE timeline scrubbing when using Scene World material #96531
2 Participants
Reference: blender/blender#96531
Operating system: Arch Linux
Graphics card: Intel UHD 620 (
iris
withINTEL_DEBUG=reemit
)Blender Version
Broken:
0781c22ceedc
,2.90
Worked:
Scrubbing through the timeline on an empty scene is slow when viewing through EEVEE and Scene World enabled, even though the node graph for it is a simple Background Shader node.
This also happens when nothing is connected to World's material output.
slow_scrub.mp4
You can see in the first part of the video, when using LookDev and have Scene World disabled, the scrubbing is relatively fluid and very close to the cursor. After enabling Scene World you can see that the scrubbing is lagging behind the cursor.
Note
I have only experienced this on this GPU (probably due to its low-performance), however I still feel this is a weird bug.
Added subscriber: @vignette
Added subscriber: @iss
This could be due to buggy driver too, try updating it or perhaps using some older version. But could be because of HW limitation. I don't have much experience with performance on intel GPUs.
But if this happens only on this particular hardware this is quite unlikely to be bug in Blender. If it is, please check if any older version works well. Older builds can be found at https://www.blender.org/download/previous-versions/
To ensure it wasn't necessarily a buggy driver, I have tried doing the same using
blender-softwaregl
.slow_scrub_sw_render.mp4
You can see the issue is still present using software rendering. I have also tried older versions (2.90 in this instance) and the performance issue was still present.
slow_Scrub_290.mp4
You can still see the timeline cursor to lag behind further in the second part of the video.
Can reproduce this issue on Windows too with Intel(R) HD Graphics 500. Noted, that when I press play, it manages to do it with fairly good framerate. I would also expect scrubbing to have same performance in this case.
So will confirm this, but could be some other limitation causing this issue.
