Blender 3.1 CPU/GPU rendering denoise is broken on M1 Mac / Monterey #96656
5 Participants
Reference: blender/blender#96656
Operating system: MacOS Monterey (M1 Max)
Graphics card: Integrated GPU
Blender Version 3.1.0 release for M1 Macs
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (newest version of Blender that worked as expected) 2.93.3
On all my projects, when rendering via the CPU or GPU, the render works as expected, but on completion the entire screen blacks out to a solid color and the render is LOST! I suspected it must be a post render step, and I have confirmed that it is the DENOISER that is broken in this version of blender. When I go into the scene and remove the denoiser, the render completes, and I can save the image!
You need a project that uses denoising as a final compositing step. Attached is a simple matt object set to denoise at the end. Render it, and at the end you get a gray screen. Go into compositing and remove the denoise node, and you get the render.TestRenderWithDenoise.blend
Added subscriber: @Jeff-Diamond
Added subscriber: @Memento
Added subscriber: @Nurb2Kea
Plroblem is here...in the users blend file...
One second - let me check if that is really the issue or if I just screwed up the sample because I keep hooking up / unhooking denoising to test... It would be strange indeed if that was in my original projects yet I never had an issue...
OK, I just confirmed that in the original projects I copied over, the image was indeed hooked up to the denoise node...
Stand by for more info.
OK, this looks like a weird MIGRATION issue - it looks like very blender project I bring from 2.93/Intel to 3.1.0/M1Max has that one connection above to the denoiser broken! I'm not sure why this would happen, but at least it's an easy fix.
Quick update - it looks like I'm having additional migration issues with loading my 2.93 blend files in 3.1 besides that one broken link to the denoise node involving animation, but I need to take some time and characterize it. But it's safe to say this is now a migration issue and not specifically a denoise issue, unless there's something intentional going on - by that I mean, maybe the reason that single link is breaking is because Blender has an issue with the old denoiser node?
Added subscriber: @iss
Seems that noisy image pass is not available unless you enable denoising in cycles properties. Not quite sure if this was intentional and it was decided that nodes won't be re-routed automatically , but I don't see this mentioned in release notes or anywhere else, so will confirm.
As for other issues, please make new report for each new problem.
Added subscriber: @Raimund58
