Hang when opening a geometry nodes file #96733
7 Participants
Reference: blender/blender#96733
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14802 Core Profile Context 22.2.1 30.0.14023.7007
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
I have a Geometry nodes file that whenever open with the startup dialog or when reloaded, it hangs blender. The file also has a problem that might be related that is randomly hanging whenever changing atributtes order or changing multiple times values that shouldn't be hanging blender.
I'll sent two files, the first one I only noticed some hangs whenever changing values/attributes order, but its not that common. The second file is the more problematic one, and its a more recent version of the first one
For now the most consistent way to reproduce this is:
2022-03-23 12-12-49.mp4
Other way to hang, less consistenly
sometimes it hangs.
And other way, also hangs the file but may not be the same problem and also doesn't happen consistenly
0001-1547.mp4
After two minutes trying to change values and reorder attributes blender hanged changing the RGB curves
GeoFeathers1.0.blend
GeoFeathers1.1.blend
Added subscriber: @Diogo_Valadares
Empy report, closing.
blender hanto Hang when opening a geometry nodes fileChanged status from 'Archived' to: 'Needs Triage'
I'm sorry I missclicked enter while typing the title
No problem, thanks for re-opening it.
@Diogo_Valadares hi, thanks for the report. I'm not able to reproduce this on current master.
So can you check if problem still persists in latest buildbot build?: https://builder.blender.org/download/daily/
Speaking about 3.1, I'm not even able to open the file... (so I force stopped Blender instance)
If you tried to open directly, that also hangs blender, the way I found around that was to open as described above
I tried the release candidate for 3.1.1, still hangs.
in 3.2 alpha it seems to open, but weirdly, there is a part of the nodes that is not working, maybe it's a problem for another report...
Added subscriber: @OmarEmaraDev
I can open both files in the way described in both 3.1 and master without any hangs.
Weirdly enough, while testing I noticed that if you save the file in 3.2 and try to open in 3.1, it starts working again, but then, even if you don't save, the next time you try to open it with 3.1, it hangs again.
In 3.1.1, it stops hanging after you save in 3.2 and stays like that until you save in 3.1.1
I also found what was causing the problem above, it may not be important for the bug report but I'll leave here as a note if it's somehow related.
What that was doing there was basically getting the radius * curve parameter * some function and trying to transfer that to the "fur"
but that can be resumed to just the length of the each fur strand.
Added subscriber: @lichtwerk
me, too
Added subscriber: @iss
I was able to reproduce once just opening file
Unfortunately I did not save full trace but it crashed in
curvemap_make_table()
onMEM_freeN()
@Diogo_Valadares does this happen when you run Blender from console with
-t 1
argument? So it would beblender.exe -t 1
.I think adding -t 1 stops the hangs.. I tried sometimes with and without it.
Also I may add, it usually hangs after saving the file and restarting blender, and it also hangs if I just downloaded the file and try to directly open it.
@HooglyBoogly Can you check this? I think I was only able to reproduce once so this may be tricky one. Also could be broken file somehow.
I have a more recent version of this file where these hangs are a lot less frequent, I just can't pinpoint what I changed to reduce the hangs, probably a change in the nodes.
I've opened this file many times and haven't observed a hang or crash or an assert in a debug build. I'm not sure how much more I can find from this personally. Maybe it's just an issue on Windows? Not sure.
Now I can't reproduce this either (in both 3.1 and 3.1.2)
Hang is only seen in 3.1 builds and there are no plans to push bug fixes for 3.1. So is it fine to close this report?
@Diogo_Valadares hi, If you're seeing a different issue in 3.2 then file a new report for it.
In that case I think it makes sense to close this. Can be reopened if it becomes reproducible at some point.
