Material glitches at joints when using Bevel modifier #97000
Reference: blender/blender#97000
Operating system: Ubuntu 20.04.3 LTS
Graphics card: GeForce RTX 2060
Broken: 3.1.2,
cc66d1020c
, master, 2022-03-31Worked:
I know people experience no end of unexpected Bevel behavior due to issues with their geometry. But I think this is a genuine bug - as do people who responded to my Blender SE question: https://blender.stackexchange.com/q/258493/124535
Robin Betts commented there that "it looks like a bug. But at least a consistent, and therefore traceable bug. It seems to be in the 'Automatic' (-1) material offset setting, which should split the bevel down the middle at material boundaries. It's getting the boundary 1-off at the end of a patch/arc spread of faces."
At joints where two materials meet, the Bevel modifier seems to miscalculate which faces of the bevel should contain one material and which the other, as shown here:
If I apply the modifier, I can then correct the issue by hand.
The above picture is from Blender 3.1.2. The problem seems to have been there for a long time, things look different but are still incorrect in 2.93.7:
The complete mesh is fairly simple (I cut it out of a larger object for this bug report) and I've confirmed there are no overlapping vertices etc.:
I actually started with a much simpler mesh but converted to triangles to ensure the issue wasn't somehow n-gon related (it isn't):
Create a simple shape like the one shown in the last image above and use two different materials for your object, e.g. above, I've applied one material to the darker colored faces and the other to the lighter colored faces.
Then apply a Bevel modifier and then look at the object in a Viewport Shading mode that shows materials, e.g. Material Preview or Rendered (you can even see the issue with Solid viewport shading if you set the Viewport Display for one of the materials to be a different color to the default grey).
Here are two small
.blend
files - the first created in Blender 3.1.2 and the second in Blender 2.93.7:bevel-3.1.2.blend
bevel-2.93.7.blend
You can find a larger
.blend
file containing the original full mesh in my Blender SE question: https://blender.stackexchange.com/q/258493/124535Added subscriber: @GeorgeHawkins
Added subscriber: @OmarEmaraDev
Minimal file to reproduce the issue. Defaults with Miter Outer -> Arc.
bevelMaterialBleed.blend
Added subscriber: @thefoofighter
This issue is still present in 3.2
As mentioned it only appears to happen when Miter Outer is set to Arc
