Rotation bug. Export Y up, -Z forward FBX with parenting. #97043
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#97043
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
blender/blender@cc66d1020c
Model rotation and sometimes scale bugs out on exporting FBX with parenting and different axis{F12970749}
Create 3 cubes and 2 empty objects. Make 2 cubes in some meaningful shape such as drawer and place them at the top of the default cube (reset transforms and set origin at the centre of each object). Place 1 empty at the "drawer" cubes location. Parent "drawer" cubes to the top empty. Select only top empty and the default cube and parent them to the 2nd empty which is at the default 0.0.0 location. Export everything as FBX with settings: Apply scallings -> FBX Unit scale, Forward -> -Z, UP -> Y. Deselect Apply unit, Select Use space transform, Select Apply Transform. Leave everything else as default.
The export should have all pivot points at Y Up, -Z forward, but if you would import this FBX, the child objects are rotated and sometimes get scaled down. While the main empty (0.0.0) and the default cube is displayed correctly with correct pivot point.
Attaching the blend file and how it looks on import at Blender and 3dsMax
This work.blend
Added subscriber: @Warkarma
Closed as duplicate of #65478
Added subscriber: @OmarEmaraDev
Just don't use the Apply Transform as it is known to not work on those cases.
It doesn't save the pivot rotation if you don't use Apply Transform. I need it to be Y up on import.
