blender export fax lost some piece of the model #97416
Closed
opened 2022-04-18 04:35:55 +02:00 by qu quanhe · 14 comments
Operating system:Mac os
Graphics card:M1 Max
Broken: (3.1.0 , c77597cd0e15, master, 2022-03-08)
When I export a model to fbx,it is incomplete when I import it to unity.scene(11).blend
scene.fbx
**System Information** Operating system:Mac os Graphics card:M1 Max **Blender Version** Broken: (3.1.0 , c77597cd0e15, master, 2022-03-08) Worked: (newest version of Blender that worked as expected) **Short description of error** When I export a model to fbx,it is incomplete when I import it to unity.[scene(11).blend](https://archive.blender.org/developer/F13007207/scene_11_.blend) [scene.fbx](https://archive.blender.org/developer/F13007210/scene.fbx)
Author
Added subscriber: @teddy171
Member
Member
Member
Thanks for the report. I don't see any difference after re-importing the model in Blender.
Haven't checked in unity yet. Can you upload screenshot to show how exactly model appear in Unity?
Thanks for the report. I don't see any difference after re-importing the model in Blender. Haven't checked in unity yet. Can you upload screenshot to show how exactly model appear in Unity?
Author
![Screen Shot 2022-04-18 at 11.03.39.png](https://archive.blender.org/developer/F13007371/Screen_Shot_2022-04-18_at_11.03.39.png) ![Screen Shot 2022-04-18 at 11.03.06.png](https://archive.blender.org/developer/F13007373/Screen_Shot_2022-04-18_at_11.03.06.png)
Member
Hi, thanks for the screenshot. Looks like backfaces are not visible in Unity after import.
Do you know how to disable back-face culling in Unity?
Hi, thanks for the screenshot. Looks like backfaces are not visible in Unity after import. Do you know how to disable back-face culling in Unity?
Author
Hi, thanks for your answer. But I don't know how to disable back-face culling in Unity though I search for it in stack overflow and google. Can you tell me how to do it?Many thanks.
Member
Hi, neither I know about this. But you can fix this before exporting the FBX file by flipping normals of inverted faces
Open your scene in blender. In viewport overlays panel, enable face orientation.
enter in edit mode and change to face selection mode
select red colored faces and apply Flip normals to them- {nav Mesh > normals > Flip}
Let me know if that works for you. I'm not sure if this can be done in more clever way.
Hi, neither I know about this. But you can fix this before exporting the FBX file by flipping normals of inverted faces Open your scene in blender. In viewport overlays panel, enable face orientation. enter in edit mode and change to face selection mode select red colored faces and apply Flip normals to them- {nav Mesh > normals > Flip} Let me know if that works for you. I'm not sure if this can be done in more clever way.
Author
This comment was removed by @teddy171
*This comment was removed by @teddy171*
Author
Thank you very much. I have solved the problem by your advice.🙏
Author
![Screen Shot 2022-04-19 at 12.17.27.png](https://archive.blender.org/developer/F13009957/Screen_Shot_2022-04-19_at_12.17.27.png)
Member
Changed status from 'Needs User Info' to: 'Resolved'
Pratik Borhade self-assigned this 2022-04-19 06:22:45 +02:00
Member
Hi, good to hear that. Will close this ticket.
Thanks again for the report.
Hi, good to hear that. Will close this ticket. Thanks again for the report.
Author
2 Participants
Reference: blender/blender-addons#97416
