Multiview camera suffix limited to four characters for images in compositor. #97527
5 Participants
Reference: blender/blender#97527
Operating system: Ubuntu 20.04
Graphics card: Nvidia GeForce 1080 Hybrid
Broken: 3.1.2
Worked: Unknown
Error description
When working with multiview, it's possible to set up camera suffixes to import individual images in the compositor to import camera-specific images. One use of this is for camera-specific backgrounds. While camera suffixes are allowed to be of any length in the stereoscopy settings, the same is not true when images are imported in the compositor, being limited to just four characters. If a suffix longer than four characters is used, blender fails to recognize that the image is "multiview", and will render using only one of the images.
This limitation is not called out in the documentation, and no warning is generated. This is especially egregious because multiview images are saved with whatever suffix is given, making the reason for failure completely mysterious. Note that the need for any suffix at all on individual images isn't specified in the documentation either.
multiview_bug.blend
file (You will notice that there are 4 images packed inside the file)Output Properties
, enableStereoscopy
File Suffix
enableUse Multi-View
(note that the image was detected due to the Suffix)multiview_bug.blend
Original Report:
Open the following blend files, then press F12. In the working blend file, multiview outputs separate backgrounds for right and left. In the broken blend file, only the left background is used, despite both files being present.
multiview_broken.blend
multiview_working.blend
Added subscriber: @Clockwork-Muse
Added subscriber: @lichtwerk
Can confirm, will check
Changed status from 'Confirmed' to: 'Needs User Info'
So, while I just discovered #97547 (Regression: Stereoscopy rendering crashes), I tested a bit and I have this file which seems to still work even though it has a suffix longer than 4 characters.
multiview_still_working.blend
I can still repro in your file, but can you also repro my file works?
Then the error might be burried somewhere else...
Yes, I can repro your file works.
What your working file is doing, though, is the original filename (as opposed to the image name) still has a four-character suffix (three plus separator).
I am able to duplicate a working file by;
From other testing, the only time the image filename suffix has to match is during the initial load.
If the extensions don't match during load, it's stuck as a single-view texture, even if you change the camera/multiview suffix to match (you need to force a reload using the "reload" button on the image tag - reloading the blender file itself is insufficient).
This has a more insidious knock-on effect: once the file is loaded, it's locked to the view. If you made an error with your camera setup (swapped two views, say), simply swapping the camera name and suffix is insufficient.
.... this strikes me as incredibly fragile/brittle.
A side note - the real reason my "non working" file repros is because the other file is literally not included. That is, it would appear non-working regardless. In light of that, here's a series of steps to create an example non-working file.
Steps -
If you instead use a pair of four-character suffixes, both images will be part of the render output.
Added subscribers: @brecht, @mano-wii
I can confirm the problem and by analyzing the code it looks like something is wrong here...
For some uncommented reason, the suffix of a stereo image is only compared if its size is less than or equal to the file extension size (in this case
".png"
).Removing this limitation (and using
index_act
for safeness instead), the problem is resolved.This limitation was added in
e608f2e7ec
, so @brecht, is this something for you to take a look at?thx checking @mano-wii
This issue was referenced by
44b318bd22
