Broken shadow in solid mode with GPU Subdiv #97877
5 Participants
Reference: blender/blender#97877
Broken: 3.1
Broken: 3.3.0 Alpha, branch: master, commit date: 2022-05-05 10:24, hash:
18bcd8321a
with a certain pose and Subdiv enabled on the GPU, the shadow is displayed incorrectly
with GPU Sibdiv
without gpu sibdiv
open bandit_anim.blend
reports.zip
note disabling the Corrective Smooth modifier in that file seems to get rid of the issue
Added subscriber: @sanek2005
Breken shadow in solid mode with GPU Subdivto Broken shadow in solid mode with GPU SubdivAdded subscribers: @kevindietrich, @lichtwerk
Can confirm.
CC @kevindietrich
Added subscriber: @fclem
@kevindietrich This might happen because of multiple reasons:
DEGENERATE_TRIS_WORKAROUND
) is falsely triggered.That said, I get an assert (or a crash when launching in debug mode) in the opensubdiv code trying to open this file.
@fclem I did briefly investigate this the other day and thought it would be the lines adjacency buffer that is not exactly the same as the one created with CPU subdivision. And some indices (> 1% of total) were indeed different. The GPU code is based on the same subdivision grid traversal as the CPU code to generate the final mesh so all indices/values in all buffers should be the same (I start pretty much all investigations by printing the buffers for CPU and GPU to verify that). I thought it might be because the order in which the polygons appear in the GPU case is different than the CPU case. Maybe we should do a subdivision grid traversal when building the lines adjacency buffer to ensure that it is built in the same order as for the CPU subdivision case and see if that fixes the issue. Otherwise it might be one of the cases you mention, or something else.
The assertion you got looks the same as #97737, and might be caused by different GLEW versions used for Blender and OpenSubDiv (this issue was revealed by the library update).
The lines adjacency extraction tags the data and cache as non-manifold for both with and without subdivision.
There were differences in the output lines adjacency data. For GPU subdivision we always split quads into triangles using (0, 1, 2)/(0, 2, 3) indices, because we can't check the triangles geometry on the CPU side as the position are on the GPU at this point. For the CPU, the MLoopTri will sometimes split using (0, 1, 3), (1, 2, 3) (see
Flip out of degenerate 0-2 state
inmesh_tesselate.c
). This concerns 6 quads in this bug report file. However, turning off this detection so that the adjacency data is generated in the same way for with and without GPU subdivision did not cause drawing issues when GPU subdivision is off, so I would guess this does not make a difference, and the observed difference in adjancency infos is not at fault here.Removing the check in the shader did not solve the issue (I guess if it is falsely triggered, then removing the check should make a difference).
The only thing I did not try is this, because I am not what that means here or how to check:
Simplified file: bandit_anim.blend
This issue was referenced by
a5dcae0c64
